Question about Samsung CLP 300 Laser Printer
Samsung CLP-300 Laser Printer
My printer will not pull the paper all the way. It grabs the paper, pulls it halfway, and stops. Any suggestions?
  • 2 more comments
  • mrpayne1549 Jan 22, 2009
    Same problem on a HP Deskjet 5740
  • cblp_01 Jan 23, 2009
    When i close the doors, my 300 runs two pages through, almost a third page and the fourth page jams in the back. When I clear it, it automatically does the same thing. Help anyone.
  • STEVE BICO Jan 24, 2009
    Same problem but it stops after one and one half sheets.Clear the jam ,turn on the machine and the same thing happens?? .I've had the machine for six months and it just started doing this.
  • gfx3d
    gfx3d Jan 24, 2009
    I have a Samsung CLP-300 for about a year and used rarely. It's almost new. It's been 1-2 months and when I send a printing, printer pulls paper and then at some point stops. Some times after starting printing something, sometimes before.
    Always, red light turns on and does not return back to green unless I turn off the printer and back on. But then the same situation occurs. Too bad for Samsung printer !
  • 417 Answers
Try changing the printer toner cartridge first if not make sure that the paper of where the paper is stuck if under the toner cartridge check that there if there is any print on it and that it is entering the fuser section. If it has stopped at the fuser section then the possibility is that the fuser drive gear is broken or some teeth missing. If the paper is stuck before the toner cartridge then there maybe the pickup tyre dirty and not feeding correctly the other thing there maybe a sensor arm stuck down.
Try the above
Thanks J
Posted on Jan 20, 2008
Samsung clp 300 starts to feed paper but stops feeding (jams?) midway
This is a common problem with both this and the Xerox phaser 6110 (a rebadged Samsung)
It is due to the pickup roller "tyre" that is the rubber roller that pulls the paper from the tray.
It gets shiny and slips on the paper.
The cure is to "rough up" the roller with some sand paper or emery cloth.
The best way is to remove the imager unit and store it in a cupboard or a box IN THE DARK.
This stops toner getting everywhere.
Remove the paper tray turn the printer on its side you will see the roller underneath, using some sand paper or similar carefully rough up the rubber roller all round.
now put the machine back together and try printing it should be ok, if the problem persists try repeating the process.
Jan 05, 2011 | Samsung CLP 300 Laser Printer
I have samsung printer 1600. The printer not pick
The above is for the clp-300 laser printer.
You say you have a samsung print 1600 but when I searched I found a blue ray player with that number.
Is this the right link?
Jul 20, 2010 | Samsung CLP 300 Laser Printer
Paper jams. I can see no real jams but the printer stops and i have to take the sheet out to go on.
Pull the paper tray out and try to clean the rubber feed roller with alcohol or water.
Oct 03, 2009 | Samsung CLP 300 Laser Printer
The printer will not pick up the paper!
Suggest you clean the pick-up rubber that lifts the paper.
And also lift up the front of your CLP-300 by about 3 inches. I put a box under the front. The paper will fed slightly downhill into the printer.
It works for me.
May 04, 2009 | Samsung CLP 300 Laser Printer
Samsung Color Laser CLP-300
change paper,nothing to clean on printer.
Apr 17, 2009 | Samsung CLP 300 Laser Printer
Paper feeding halfway through then stops
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 03, 2009 | Samsung CLP 300 Laser Printer
Won't complete cycle
we have Samsung color printer, model CLP-500, not working. Please suggest Samsung service centre in India.
Feb 02, 2008 | Samsung CLP 300 Laser Printer
Samsung CLP 300 Laser Printer Logo
184 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
