Question about Craftsman 4 Cycle Blower/Vac
Hi, I have a Craftsman 8hp snow-blower and on auger spins freely and doesn't move with the other. How do I fix it? Thanks, Paul
You need to replace the shear pin on the free side
Posted on Dec 22, 2009
    President:
  • 1,627 Answers
You need to take it apart in the middle and replace the friction wheel.
Posted on Dec 09, 2009
Auger belt burns out
un-seize the auger action
replace rusted bearings
Feb 07, 2016 | Garden
The snow blower orger gets stuck when trying to remove snow
Check to see if the shear pins are broken off if so remove any fragments and replace. if not..With the engine off, try moving the auger with the handle engaged (you may need to have someone hold the handle while you wiggle the auger. If the auger spins freely without moving the belt mechanism you have either a shear pin issue or shaft breakage if it will not move or moves with great difficulty work your way back through the machine looking for the obstruction or damage. If the auger moves freely and the belt pulleys etc. move with it you likely need to adjust/ replace the tensioner, control handle or belt.
Feb 28, 2014 | Mtd Garden
Left auger does not engage/spins freely
The shear pin is sheared off. Somewhere along the auger, you'll find a hole drilled all the way through it. The shaft inside also has a hole drilled all the way through it. Compare the two augers - the holes are USUALLY in a straight line with each other (when one is up/down, the other is also up/down).
Get a replacement shear pin (DO NOT use a hardened bolt!) and put it through the holes when the auger holes are lined up with the axle holes.
Feb 19, 2014 | Toro Power Max 724 OE 24 inch 205cc Two...
On my craftsman snow thrower the auger is stuck (jamed)
you bent it straighten it out as to where it works as it should , easy fix , did you get the bad tile out
Feb 14, 2014 | Garden
I have a 3 yr old 26" snow blower. I ran the machine up against hard packed snow/ice and now the auger spins freely and all shear pins are still in place. The secondary impellor functions fine. I...
I am going to assume the belt is good if the impeller it running. You can check the belt by removing the plastic cover in the center of the snow blower.
With the unit safely turned off reach in and turn the blower by hand while putting a little resistance with your other hand on the impeller. Does the shaft from the impeller to the gear box turn?
Does the shaft that the augers are attached to turn? If the impeller shaft turns but the auger shaft doesn't, the gearbox in the front is bad and will have to be replaced.
I the auger shaft turns, check your shear pins again. Sometimes they will break but still stay stuck in the holes. Actually take one out and check it.
If it is a Craftsman you can get a manual from managemyhome.com and parts from searspartsdirect.com. You will need the model number of the snowblower. The number looks like 247.123456.
Any other questions please ask. Do't forget to rate this answer!
Jan 16, 2011 | Craftsman Garden
Craftsman Snowblower. One auger is disengaged...turns freely when touched....does not push snow
the augers on many craftsman snowblowers have a sheer bolt. If the auger encounters too much resistance, ie, a foreign object like a piece of wood or even a newspaper buried in the snow, this bolt will break off preventing damage to the gear box, which is a lot more expensive to repair than replacing the bolt.
This bolt requires not tools to install, just insert and secure with a cotter pin.
The parts dept at sears can sell you the replacement bolts with the correct sheer force rating. Have your snow blower model number handy when you call or go in.
Dec 27, 2010 | Craftsman Garden
I have craftsman snow blower 5 hp 24inch model #
does the impeller spin and not the augers.if so check sheer bolts.if neither impeller or auger spins check auger belt.
Feb 22, 2009 | Craftsman 16" High Garden Tractor Snow and...
On my two stage snow blower--main auger stops turning .
Hi, I figured out the problem. The gear transfer case between the augers must be broke. The auger spins slowly until it hits snow and then stops-- The discharge fan continues to spin fast. I will try to get a local handyman to fix it or else but a new machine, this one must be at least 15-16 years old.
I thank you for your help, it is a great service. ojohn
Dec 10, 2008 | Garden
Craftsman 4 Cycle Blower/Vac Logo
213 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
