I have a amp that runs on 8 ohms ,and i want to connect 5 speakers on only one channel(making my own central speaker). I have two speakers(woofers)/each 4ohms, two (tweeters)/each 6ohms and (mid) 4ohms . So how do i connect thous 5 speakers to make a total impedance of approximately 8 ohms ? tnx
    Sergeant:
  • 436 Answers
Use a passive crossover network, this is a box of tricks that will divide the correct frequencies in to each speaker and run at 8 ohm.
Posted on Dec 09, 2009
Can I connect two 4 ohm speakers to make it play on single 8 ohm speaker channel on a receiver
Yes, two 4 ohm speakers wired in series will present an 8 ohm load, though even with matched speakers they are likely to produce different volume levels.
It is probable the receiver will be quite happy using a single 4 ohm speaker if only modest volume levels are used. Many popular hi-fi amps quote power outputs for both 4 and 8 ohm indicating either could be used.
Mar 14, 2017 | Yamaha Audio Players & Recorders
What is the impedance of the midrange speaker and the tweeter speaker in the Pioneer cs r5100 ? I have the crossovers and the woofers I use for my front channels (L&R)
If you are running three 8 ohm speakers in parallel then the total impedance would be 2.667. If running two 8 ohm and one 6 ohm speaker in parallel you would have 2.4 ohms. This will burn out your amp pretty quick. And very possible won't play at all. Though I have never attempted to play a home amp down that low in ohms. Guessing you may have an older model Denon type amp.
Aug 01, 2014 | Pioneer Audio Players & Recorders
Do you bridge a 850.4 four channel amp when it is 2 ohm stable and ur subs are wired up as series/ parallel and there 2 ohm dual voice coil speakers
If you wire 2 ohm dvc speaker parallel that would give you a 1 ohm load. If your amp is only 2 ohm stable that would not work. You would have to wire the speaker in series giving you a 4 ohm load. Then you can bridge the 4 channels into 2 with each speaker running at 4 ohms.
If you want to run a 2 ohm load use all 4 channels on amp and speakers. No need to bridge.
For 2 ohm DVC:
Parallel = connect both + and - together. = 1 ohm
Series = connect + from 1 channel to - from the other channel. = 4 ohm.
Jul 06, 2014 | Car Audio & Video
Wiring a crossfire vr602 at 4ohm
OK what you are saying now is that your speakers are dual voice coil; models? 4 Ohms per Coil? I have always used single 4 Ohm Voice ciol speakers since amps are mostly based on 4 Ohm outputs. but you can get 8 Ohm dual voice coil subs also. With 8 Ohms per coil you can get 4 Ohms if you parallel the wires. What is best for you and will get you the most stable power and still will be in the specs of that amp is to run the amp in BRIDGED MODE running each subs voice coils in series with each other then run those 2 subs in parallel to the amplifier giving it a 4 Ohm load. So, your will have two sets of wires from your amp 1 for each speaker. Then you will take a short piece of wire that will connect the + to the - of each voice coil then hook up the wires from your amp to each sub What it will be is 4 Ohms + 4 Ohms = 8 Ohms per speaker the 8 Ohms in parallel each speaker to the Bridged amp output using just the + from one channel and the - from the other will give you a total of 4 ohms and power out put of 600 Watts so that ends up being 150 watts per voice coil or 300 watts each speaker
Apr 04, 2013 | Crossfire VR602 Car Audio Amplifier
Put new pa speakers in church 2 1000 watt tied 2gether and 2 300 watt. tied 2gether. the pa amp only has 250 watts with 6 mics connected and a cd player which plays fine. every time the mics are used if...
hi,
You have to check the ohms of the speakers all spekers should be 8 Ohms or above. if not it will overload the amplifier at high level. The minium ohms impedence of the amplifier is 4 ohms. If you connect two 8 ohms speakers together then the effective ohms will be 4 OHMS then the amp will handle the speakers. If you connect two 4 ohms spekers together then the effective ohms will be 2 Ohms, this will overload the amplifier. You will be able to connect two 8 ohms speaker to left channel or right channel of the amplifier. Check the speaker spesifiction to know its ohms. Make sure all the speakers have an impedence of 8 OHMS or above
OK
Aug 19, 2011 | Radio Shack 250 Watt PA Amplifier...
Is a Adcom GFA-7500 5 channel power amplifier bridgable?
no this AMP is not bridgable to get more power out of this amp you need 4 ohm speakers.
Power rating
1 - 150 watts into 8 ohm speakers
1 - 225 watts into 4 ohm speakers
Feb 23, 2011 | Adcom GFA-7500 5-Channel Amplifier
I have a power acoustik 0V4-1200 amp and 2-12" kicker cvr dual 2 ohms. My amp keeps getting really hot and turning off. I have two pair of rca jacks from my cd player to the amp. One speaker hooked up...
i have found the specs to your amp. 1. Amplifier connections: Lets make things simple. As we look at the amplifier speaker connections, we will number the outputs 1 2 3 4 from left to right for the top connections and again 5 6 7 8 from left to right for the bottom connections. 1 should be connected to a positive (RED) (+) on sub woofer A on voice coil (a) 4 should be connected to a negative (BLACK) (-) on sub woofer A on voice coil (b) Now using a small piece of cable, connect negative of voice coil (a) to positive of voice coil (b) Follow the same procedure for the other sub woofer using 5 and 8 as 1 and 4 This configuration should make the amp run at 4 OHM BRIDGED x 2. i hope this helps. dreamsystems
Feb 07, 2011 | Car Audio & Video
Hello, I have a 2000 VW passat with a Monsoon radio system. How do you install a new head unit and speakers while maintaining the factory amp? If this is impossible, Can I use the current speaker wires...
Hello ctr1russo,
While it's not impossible to install a new head unit and speakers and leave the factory amp, it'll be a real bear of an install.
In order to work, the Monsoon amp needs 6v which is provided on the speaker leads. An aftermarket head unit will not provide that. Best to just install a new amp.
You should be able to use the wiring, including the speaker wiring, with no problems.
Check out www.bestkits.com for the appropriate adapters and wiring harness for Monsoon equipped vehicles. Just enter your vehicle info and it should bring up the required adapters and harnesses to make everything work properly.
There are three ways to connect more than one speaker to a single channel: 1) Parallel - both speaker +'s and -'s wired together - load impedance will be halved (2 4-ohm speakers in parallel equal a 2-ohm load). 2) Series - The + of one speaker wired to the - on the other speaker and the remaining + and - going to the channel output - load impedance will be doubled (2 4-ohm speakers wired in series equal an 8-ohm load). 3) Using a crossover - connect the bass speaker (woofer) and the input of a high-pass filter directly to the channel output and the treble (tweeter) speaker to the output side of the filter. In any of these connections, you want to make sure that the load (ohms) your amp "sees" is not less than it is rated for. Most amps will work into a 4-ohm or a 2-ohm load with no problems. Going below 2-ohms is bad, because it will cause the amp to overheat and possible fail. Going above 4-ohms is no problem for the amp, but it won't produce as much power (watts) at the higher impedance and your speakers will not be as loud as they could be.
Hope this helps. If it does, please rate as "FixYa:. Thanks!
Apr 21, 2009 | Car Audio & Video
Legend Amp hook up manual.
Pretty Straight Forward get a 8 or 4 gauge amp wiring kit.
Run your hot wire to the +12V from the battery make sure to install the supplied inline fuse near the battery don't connect to the battery until installation is complete.
Run the REM to your stereo power ant. Wire. if available.
Run the GND to Metal Chassis Ground keep it as short as possible.
Run the RCA Cable from the back of the Stereo to the RCA Inputs or Low Level on the amp.
This amp is 2 Ohm Stereo Stable which means you can connect 2 (4 ohm) speakers in parallel to each channel or 1 (4 ohm) speaker on each channel or you can connect 1 (4 ohm) Speaker in bridged mode.
There are other speaker configurations you could use but you cannot drop the load below 2 Ohm in stereo mode and no lower than 4 ohm in bridged mode.
Hope this helps
Mar 25, 2009 | Legend LA1490 - American Legacy Series 2 -...
Help me...
If you had 4 single voice coil speakers you can create either of those 2 ohm or 4 ohm setups. If you run 2 of them in parallel you will get the 4 ohms. If you run 4 of them in parallel you will get the 2 ohms. In parallel I mean that you connect the positives together and run them to the positive on the amp and the connect the negatives together and run them to the negative on the amp. Let me know if you need more help. Good Luck.
-Andrew Hawkins
Jun 24, 2008 | Cadence TXA 6004 4 Channel High Power...
57 people viewed this question
 Grubhead
Grubhead
