Question about Samsung S8300 Ultra Touch platinium-red Cell Phone
Phone rings 3 times then says missed call
Phone only rings 3 times then says missed call how do I change to ring longer, also how do I access voice mail to set up message, and retrieve messages. ( sorry new phone and not up on this technology )
Panasonic kx tga 642 manual
My phone is only ringing once before going to voice mail.How can I increase the rings to 3 rings
Sep 04, 2014 | Uniden DECT 6.0 Cordless Telephone...
Hi there I would like my Nokia 5800 XpressMusic phone to ring longer before it goes to voicemail. How do I change it? Thanks in advance
I also have Nokia 5800 XM. From my own experience, the time from the beginning of incoming call until voice mail is provider setting so we can't change it manually. I think you can just increase your ringing tones so you can notice every incoming call faster.
If this helpful, RATE please !
Jan 20, 2011 | Nokia 5800 XpressMusic Smartphone
My phone only rings 3 times then stops how can i make it ring longer thanks brian
When it stops ringing, the caller goes to your voice mail, right?
If so, then you need to contact your phone company and have them change your "Ring Cycle" -- that's the number of rings before the voice mail system picks up.
Some phone companies have a way for you to do this yourself from their website, other require that you call up the customer service line. Either way, the thing you want to adjust is your voice mail ring cycle.
Sep 27, 2010 | Doro Cell Phones
How to extend the rintone length on my binatone 2210 it is far too short. when it rings I can't get to in time it only rings about 3 times, and the person thinks i am not there.
Sep 27, 2010 | Lands Phones
Need more rings
You have to change the rings from the voice mail server. If you don't know your way around the server, its best to get a local NEC tech although it is fairly simple to navigate. Depends on your skill. Typical default password for the server is NEC
Oct 16, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Extending Ring Time
You can try the steps below:
A) The simplest method is to call your carrier and request a longer ring time, up to 30 seconds.
B) If you have a GSM based phone, some have had success by dialing this number from your phone: **61*XXXXXXXXXXX**30#
  • Replace XXXXXXXXXXX with the number of your carrier voice mail center (find it by looking at your Phone Dialer > Options > VoiceMail > Access Number. Put your access number in place of the Xs above.
For example, the T-Mobile voice mail access number is 18056377243, and thus the string to dial would be **61*18056377243**30#
  • Replace the 30 at the end of the string with your desired seconds. For most carriers, 30 seconds is the longest allowed.
  • NOTE: Has been reported this doesn't work for Rogers (8700r) . 6/17/2005. Morser
Sep 21, 2008 | RIM BlackBerry Pearl 8100
How to change number of rings
Not sure how to change the number of time it rings but to change your voice message call yourself, put in your pass when it tells you to then press 4. Now press 3. Now press 1. To have a standard greeting with your number press 1, to have one with your name press 2, and to make your own press 3. Hope this helped.
Feb 22, 2008 | Motorola Mobility V325 Cellular Phone
Number of rings
press *94, then press the number of rings you want 1-9. The tone will change and thats it.
Nov 29, 2007 | Siemens Gigaset S455 Cordless Phone
Missed calls
i voice mail setup.close the timings options...or chk in phone settings....
Oct 16, 2007 | Samsung SGH-D600 Cellular Phone
Samsung S8300 Ultra Touch platinium-red Cell Phone Logo
236 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
