Question about Nokia N73 Cellular Phone
Loudspeaker - hardware
While talking on my N73 n keeping loudspeak on, it starts producing echo n humming sound
  • Anonymous Mar 26, 2014
    Echo when talking
Dear sir,
u go to the NOKIA CARE CENTRE, & ask him to upgrade the software of the mobile phone.
&if not solved than change the ihf ringer.if not than change RETU ic.
Posted on Jan 20, 2008
6ya staff
SOURCE:
My nokia n73 radio is not working what can i do for this problem.
There is the possibility that the earpiece of your headset is bad. Try putting the rdaoi on loudspeaker, if it works, then you either listen to the radio on loudspeaker, or get another headset that is in perfect shape.
But if putting it on loudspeaker still does not work, then you have to entirely change your headset to another.
Hope that was helpful?
Thank you for using FixYa.
Aug 30, 2011 | Nokia N73 Cellular Phone
I hear my voice echo some of the time (no particular relation to location) when I talk to someone. Why and how do I get it fixed? Thanks
This has no problem to do with the phone as far as i know.
It occurs normally when you are talking to someone who happens to be in a very quite and large room without that it empty. this is due to the empty vaccumm that causes the sound that is produced to be reflected back into themic of the phone and as a result causes you to hear your voice.
Also, another thing that causes it is when you talk to someone who puts the call on loudspeaker and there are multiple surfaces causing the reflection of the sounds you make.
In summary, there is nothing wrong with your phone and you just need to tell whoever you are talking to to try and move to an area that is a bit occupied so as to prevent echoes.
Dec 24, 2010 | Samsung Convoy Cell Phone
Nokia n73 speaker problem
if your speaker it sound broked when you listen music it need replacement, also check witch one is not working properly because n73 has 2 speakers
Aug 15, 2009 | Nokia N73 Cellular Phone
Loudspeaker
tap the speaker icon on the status bar and then tap the speaker phone check box to play sound via the speaker phone
Jul 11, 2009 | Nokia 6708 Cellular Phone
In my mobile there is no loudspeaker option in Nokia 6681
For volume and loudspeaker control increasing or decreasing the volume level when you have an active call or are listening to a sound, press left or right scroll, respectively. Sound applications use the loudspeaker by default.
To use the loudspeaker during a call, start a call, and press the button with the talking face icon and press again to return to earpiece.
If it does not work the speaker, or amp circuit is bad or there is a glitch in the firmware. Replacing the speaker is the only economically viable repair. If the amp circuit or firmware has malfunctioned a new phone is in order.
Jul 05, 2009 | Nokia 6681 Cellular Phone
There is no more sound from my Toshiba laptop loudspeakers
Try to use different players like windows media player and winamp
and check if it is not muted by standart software or 3rd party
Mar 19, 2009 | Toshiba (4CH-VOUT) Sound Card
I cant hear them talking Nokia N73
There should be either a mute or volume control you're missing. If not, get it replaced.
Jan 09, 2009 | Nokia N73 Cellular Phone
Sound
could be two things, either the sound file is corrupt. or more likely, especially if you have multiple sound files producing the same results, your loudspeaker is torn or damaged.
You can most likely go to youtube and search for a video on how to take your phone apart. go to ebay and shop for a loudspeaker for that phone and replace it.
Oct 20, 2008 | Sony Ericsson Cyber-shot C902 Cellular...
Volume
Volume control
• When you have an active call or are listening to a sound, press o) or (o to
increase or decrease the volume level, respectively.
Voice volume icons:
- for earpiece mode,
- for loudspeaker mode.
Loudspeaker
Your phone has a loudspeaker for handsfree use. The loudspeaker allows you to
speak and listen to the phone from a short distance without having to hold the
phone to your ear, for example, having it on a table nearby. The loudspeaker can
be used during a call, with sound and video applications, and when viewing
multimedia messages. Sound and video applications use the loudspeaker by
default. Using the loudspeaker makes it easier to use other applications while in a
call.
Apr 02, 2008 | Nokia 6600
Nokia N73 Cellular Phone Logo
57 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
ASHRAF CA
ASHRAF CA
