Question about Garden
My poulan wild thing has always been hrd to start. last week, i cut a trailor load of wood. at the end it got harder and harder to start. i cleaned the air filter. primed it etc. it almost starts after heavy priming and full choke. i suspect carb needs adjusting. i don't know what setting is required for the 2 knuled knobs/screws. larry in benson,az
  • 14 Answers
SOURCE: 2375 ''wild thing'' poulan saw hard starting after carb rebuild
Through trial and error on fairly new Poulin Pro, found that the usual 3-half turns for both high and low was too much (flooded) (Used to be good starting point on weed eaters years ago. So, turned both all the way in, and only backed out 1-full turn. (2-halves) Saw fired up perfectly, and ran wide open just fine. Try that.
Posted on Nov 19, 2008
slohry
  • 87 Answers
SOURCE: Poulan Pro 260 42cc. Need a manual.
For parts manual
http://www.ordertree.com/cms/Illustrated-Parts-List/64.html
Hi and low speed jets are both 1 1/2 turns open, fine tune from there.
Posted on Apr 09, 2009
dontbother10
  • 2220 Answers
SOURCE: Craftman Chainsaw do not run
Extreme Flooding by Dolfoff
Please follow this link, http://www.fixya.com/support/t3226410-no_spark_new_plug_but_continues_flood cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button HTH
Lou
Posted on Oct 20, 2009
rwvanlue
  • 486 Answers
SOURCE: i HAVE A POULAN CHAIN SAW MODEL P4018 WILD THING.
That should be the throttle plate. If it came loose, it may/should be laying in the intake manifold or it may be on top of the piston. You need to find the parts before trying to start. A small screw that fastens the plate, when it becomes lougged in the top of the piston can destroy the cylinder.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 13, 2009
  • 4088 Answers
SOURCE: My poulan wild thing 2375 bogs out when throttle
Make sure that the air cleaner and muffler are not plugged. Check the carburetor screws and nuts for tightness. After turning both needles CW to stops (lightly), back them out CCW 1-1/2 turns each. Start the engine and allow to warm up. Open the throttle and adjust the H needle CW somewhat until the engine speeds up, but is 4-stroking. Correct adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Release the throttle and adjust L CW till the engine runs fairly smoothly, but allows the engine to 'follow the throttle'. Set the idle speed screw so that the chain doesn't turn, but the engine keeps running. Hope this helps!
Posted on Apr 17, 2010
Poulan " Wild Thing
It is running lean, they always need to run a little on the rich side free running, once the engine is loaded it will then need the excess fuel, it runs ok without the bar and chain because there is no load, start by replacing the fuel filter in the fuel tank, check the fuel hose up to the carb for signs of fuel leakage, replace if reqired, if the carb has standard adjuster screws, increase the H screw by 1/4 turn out ( anto clockwise ) this will richen the mixture.
Aug 22, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Tip
Poor gas milage?
Thinking you are getting poor gas milage,Your engine is running smooth,no misses,Engine runs smooth while accelerating up a hill, Still poor gas milage, Check your tire pressure. I have a 1999 Chevy Blazer 4x4, 4.3 Ltr. Auto, loaded. I have just over 154000 miles on it,I change my fluids every 5000 miles. Summer driving milage got real bad. I drive a Blazer hard. I tow a 16ft trailor usally loaded to the top with wood. Tires get hot in the summer, while in the winter, they stay mostly cool. Always check your air pressure.Most vehicals are equipted with radials now days, So if you think a tire looks low, check it, Usally they low. Usally in the winter months, nobody checks tire pressure. It really does make a difference. I went from 17.2 MPG to 19.5 MPG, while pulling the same trailor loaded with wood. I cut my own wood then stack it in my trailor to sell. I have Good Year Wranglers size: P235/75R/15 I just replace these with new ones. The old ones are going on my trailor. Counted milage on tires are 65000 Miles. Tires were rated at 40000 miles, Under normal use.
on Jan 01, 2010 | Chevrolet Blazer Cars & Trucks
Chain keeps coming off bar
The chain only comes off the bar if, the chain has become lose and de railed, or if the timber you are cutting is very springy and you are trapping it in the cut, our twisting it in the cut, if the saw is not oiling the chain correctly it will stretch and if not addressed will come off, once it has come off the drive links are usually damaged, you should realy start again with a new chain, when running close to a clean peice of wood you should a steady stream of chain oil coming from the end of the guide bar.
Feb 20, 2011 | Poulan 18" Wild Thing Chainsaw
TppOn my Poulan Wild Thing 18" chain saw the fuel line appears to have out of the hole going to the gas tank. How do you get the line back through the hole, it is a very tight fit?
Cut the end of the hose off at a steep angle, push it into the hole in the tank, now use a pair of needle nose pliers through the fuel filler hole to grab the end and pull it through.
Feb 05, 2011 | Poulan 18" Wild Thing Chainsaw
When cutting wood saw will not oil chain whats the problem
make sure oiler jet under the chain tightener plate is clean even take bar and chain off and start saw
Dec 12, 2010 | Poulan 18" Wild Thing Chainsaw
What are the high and low carburetor settings on a poulan 3416 chainsaw?
are they two separate screws? one for fast, one for slow.for the slow setting, first start the saw then screw until motor runs smooth without chain moving....if to slow the motor will stop....for fast screw....rev motor flat out then adjust so it screams its head off so to speak....it will need all its power for cutting wood so don't think you are opening it up to much as its designed for it.
Jul 23, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My pulan wil thing is dieing after I cut through a
MIne was doing the same thing. I cleaned the sponge air filter. That helped but then I poured some combustion chamber cleaner into the carb and that solved it. Now it would idle all day if I let it.
Always measure oil mixture carefully. These saws are fussy and don't like too rich an oil mixture!
Hope this helps!
Rob
Sep 22, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing starts great but as soon as I try to cut it die
The carb low idle needs to be adjusted this is fairly common among the Poulan chain saws. Once you adjust the low idle from factory setting it will work
Feb 16, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poor performance at hi revs on poulan 3314
Try turning the high idle screw out 1/8 to 1/4 turn refer to your manuel for the location of this screw.
Dec 10, 2008 | Poulan Garden
Garden Logo
64 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
