Question about Western Digital Passport WDPS021 (XML600UEBN) Power Supply
I have a Western Digital external hard drive that will not work. It will not turn on, the power cable is bad on these? Where to buy new cable?
  • 40 Answers
Western Digital drives comes with 3 years warranty, they should be able to replace it for you
check if it is covered here http://support.wdc.com/warranty/index_end.asp?lang=en
if it is not covered under warranty. take it to radio shack or equivalent and they should be able to match up one for you.
Posted on Dec 09, 2009
  • 6,831 Answers
Hello
Well, it does nor necasarilyTake it to a computer hardware shop and let them have a look at it before you spend money on a power cable which might not be broken.
Kind regards
Andrea
Western Digital Hard Drive WD2500B015 getting power but will not turn on...Suggestions?
Buy a new external hd enclosure and reuse the hd from the failed enclosure. Hard drive enclosers are cheap BTW. Try newegg!
Dec 06, 2014 | Western Digital Computers & Internet
Computer is dead, need access to hard drive content
your best bet would be to goto ebay and buy a kit which turns your hardrive into an external drive ..... determine what kind of hard drive it is and buy a kit .... ide or sata etc either way you will need to buy the coverter
Mar 29, 2014 | Western Digital Computers & Internet
Pc does not recognise external drive
There are a few reasons this would happen, The options are a bad USB cable, a faulty driver in your PC, a failed circuit board in the enclosure or a failed circuit in the drive itself.
First try the drive on a different PC and see if it works. If it does reply back and we can look into the failed driver. If it doesn't then take it to your local PC shop and have the technicians test it with a new USB cable, if it works buy the new cable. If that also fails to work have the technicians move the hard drive into a new enclosure.
If it works in the new enclosure buy the enclosure and your on the way. If it doesn't, then the hard drive itself is the problem. If that is the case you will need the help of a data recovery pro to retrieve your data. If this is the case reply with your location(Country, State and City) and I will assist you in finding a reputable pro to assist you.
Hope this helps FixYa,
Chris
Nov 04, 2009 | Western Digital Elements powered by WD 320...
Western Digital external USB 2.0 Problem
Buy an External USB 2.0 Hub with the 5.0V power supply. I have a TARGUS 4 Port Hub. MY WD2500XMSB works fine thru the HUB, but will not work using any cable (even the one that came with it) when directly connected to the USB port on my computer. The power consumption of passports sometimes exceeds the .5 milliwat rating for the ports and ccause the port power to interrupt (see USB 2.0 specifications). The external hubs with external power have a higher power output usually an can power the passport drives. CW Rumsey
Oct 07, 2009 | Western Digital 250GB MyBook External USB...
My external hard drive wont conect to my computer.
Is this a new drive? has it worked before? the usual sequence is to connect the external drive to a power source first, and then connect the usb cables to the PC. IF you know the usb cables are good and have verified that they are connected properly, try connect to a different usb port on the PC, sometimes ports go bad. If that still doesn't work, the most likely the hard drive has gone bad.
Oct 03, 2009 | Computers & Internet
WD External Hard drive does not work no power to it
External drives tend to use power supplies at 12V DC and 1 amp or just a little bit over. You could read the output of the power supply with a digital volt meter. If you have power and the enclosure still refuses to turn on, you could buy another enclosure, another power supply, or just a naked USB to IDE adapter and pull the drive out of the existing enclosure.
Chances are, the drive you get out of the housing will never be going back into that case.
Jul 11, 2009 | Western Digital External USB 2.0 80 GB...
Western digital passport 160gb external ( device not recognize
As you did not specify 2.5" or 3.5" I will give you both sets of steps:
If it is a full sized hard drive and requires power, it may not be getting enough power, have the AC adapter tested at a computer shop. If it is dead/dying replace it, if not move onto the next step.
Try a new usb cable, also available at most computer shops. If the new cable works at the shop try your old cable as well. If the old one doesn't work, buy the new cable, problem solved if it does work the problem is either in the caddy or your computer.
Assuming it's in the caddy, now have the people at the shop swap the HDD from your shell into a new one and test the drive again, as with the above if it works you're done. If it doesn't the problem is internal to the actual HDD. Time to buy a new external drive and send the old one for recovery if it has any crucial data on it.
Let me know how you make out and if needed I will provide additional steps. Also if you need data recovery help let me know your region and city and I will recommend an appropriate facility.
Chris
Jun 02, 2009 | Western Digital Passport 160GB External...
My external hard drive won't turn on
Ok, this just happened to me, my western digital my book studio external drive was not booting up, i could hear the disk spinning, but it would then cut out and the light on the drive was never turning on. i called Western Digital customer support and found out that the proper way to connect a drive is to plug in the power cable FIRST then the data cable. Also, with the My Book Studio Edition you should never have to press the power button, the drive just turns on when you plug it in. Hope this helps somebody...
Feb 18, 2009 | Western Digital 500GB My Book Pro-External...
Western Digital Passport  WDPS021 (XML600UEBN) Power Supply Logo
129 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
