Question about Kenmore Refrigerators
1999 coldspot fridge leakingwater down into fridgebecause drain line is frozen
  • 6,784 Answers
Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged resulting in standing water inside your refrigerator. A similar drain exists in the freezer, which when clogged results in ice build up on the floor of the freezer.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
NOTE-(This may be a leveling issue as well)
It is important for the refrigerator to be level. If it is not level, doors may not open or close properly and may not seal tightly. Also, drainage from the defrost cycle might be impaired as might the ice making cycle. The appliance was engineered based on it being installed in a level position. While there may be some tolerance for out-of-level installation, the appliance will operate at its best when properly leveled.
Place a level on top of the refrigerator near the front. Do not put it on the door because the door may not be aligned with the refrigerator case. Check that the refrigerator is level from side to side. Next turn the level to check that it is level from front to back.
If it is not level, adjust one or more of the adjustable leveling feet until it is level. The feet are bolts that can be turned to raise or lower the refrigerator. If they cannot be adjusted with your fingers, use a crescent wrench or pliers.
If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An ice-maker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then re-tightening the screws.
Posted on Dec 09, 2009
SOURCE:
How do I defrost the water line to ice maker on a Kenmore Coldspot model 5151200
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Feb 24, 2015 | Kenmore Refrigerators
My kenmore coldspot refrigerator leaks water onto the floor. I am reading that it may be a frozen line. How can I repair this?
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Fix any gaps in the door seal.Pack out the seal underneath the areas where the door seal has the gaps. This can be done with a small strip of weather stripping, as shown here, or a bit of tightly rolled up paper under the door seal. Alternatively, you can heat the door seal up with a hair dryer to fix the gaps. This softens the door seal and allows you to stretch it.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick. Another trick one can use is to connect a copper tube wire with one end going into the drain hole then attach the other end to the heater wrap it around heater a few times. That will take care of the drain problem when it comes to ice build up but not food build up.
God is so good: so this is why I give free advice so please thank him not me.
Aug 27, 2014 | Kenmore Refrigerators
Why does thick ice form regularly on bottom of my samsung frost free upside down fridge .
The drain line in the bottom of the freezer is frozen over. Remove the back cover boil some water and slowly pour it down the drain to clear it.
Mar 02, 2014 | Refrigerators
Kenmore Coldspot refrigerator Model #57282791 no water from dispenser
When was the last time you changed the fridge water filter. Sounds like its blocked if no water is coming out of the hose at the bottom front. Also depending on the fridge design two other culprits are possible.the electric switch that is pressed that cativates the water valve to open and let water pass and the second the water valve itself. I would lean toward the water valve at the back of the fridge, as you said it was getting worse over time u til it just stopped.
Oct 02, 2017 | Kenmore Refrigerators
Have a 2003 Kenmore coldspot model 106.73832302 that is leaking water into the refrigerator from the condensor access opening at top of fridge, before that had frozen water on bottom of freezer...
the model # is not complete but the problem may be the drain has frozen and needs to be cleaned . using hot water . clear the drain and to keep ot clear install whirlpools heater kit to prevent it from happing again .. pt # 819043 mm hope this helps feed back pls .
Sep 18, 2011 | Refrigerators
I have a Kenmore Coldspot (mfg date 10/00), model 106.70192001. The ice maker is NOT hooked up (by choice) and for the last several weeks, there has been water draining from freezer into fridge in a cyclic...
Your drain line is frozen and is not allowing the defrost water to drain to the pan below. You will need to remove the rear panel in the freezer and thaw the drain line. Make sure ALL ice is thawed before reassembling. I would recommend installing a drain heater so it will not happen again. They are inexpensive and easy to install. They come with complete instructions.
Kelly
Mar 22, 2011 | Kenmore Refrigerators
My Kenmore coldspot 71182100 which is almost 9 years old just started leaking water from the freezer onto the shelves in the fridge. I just cleaned out the freezer and got the ice out. There was not...
I have a Kenmore Coldspot Model #69207990 and have the same problem. Water from the freezer drains into the refridgerator onto the shelves and sheets of ice form. A repairman pointed out that the tube leading down from the freezer onto the drain pan was frozen. By pouring hot water down the tube, he reopened this drain line. Problem solved for six months and the drain line froze again. My question is how to stop this drain line from freezing up again.
Dec 16, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Freezer cold fridge 52 degrees
We have a Kenmore Coldspot Model # 106.8770687 and the freezer is cold and keeping things frozen, but seems to be frosting over and the refrigerator is warm at 40 to 50 degrees ... any help regarding what to check is helpful! Or a schematic / manual
Jun 14, 2009 | Kenmore Refrigerators
The hole that drains water away at back of fridge is blocked
Ok you need to defrost this unit eg unplug and leave all doors open for 48 hours then get some "flexy curtain wire (white plastic coated, used for hanging net curtains) this wire is perfect for getting up or down the fridge drain.
Please rate my advice
Mar 25, 2009 | Hotpoint FFA80 Bottom Freezer Refrigerator
Fridge leaks
your drain is clogged,you need to get to the drain and use a hanger or shop vac to **** the clog out,let me know-mike
Jul 08, 2008 | Refrigerators
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Paul Carew
Lawrence Oravetz
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
