Question about Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x
Upon starting engine screams then idles down but doesn't have power to run snowblower
    Scholar:
  • 110 Answers
SOUNDS LIKE YOUR GOVERNOR LINKAGE IS NOT ADJUSTED RIGHT , OR YOUR THROTTLE SHAFT IN THE CARB IS BINDING.
Posted on Dec 15, 2009
What is the proper gap of a spark plug on a 28 graham brothers truck
Depends. It depends upon which engine (Dodge six? Dodge eight?) the truck has. It depends upon how much compression the engine has, and upon how strong the coil is. A good starting point would be around 0.035". If that gap results in a persistent miss, especially at higher engine speeds, try 0.005" more or less - if the miss gets worse, go the other way. When the plugs fire consistently at all speeds, your gap is "correct".
Jul 14, 2014 | Tecumseh Snowblower Snow Blower Starter...
1993 Chevy truck surging then dying
i take it you mean the revs keep going up and down
this effect is called hunting
this means you have to much air getting through to your engine
solution: tighten down your carburetor
you may have to replace the inlet manifold gasket seal
then adjust the throttle as required
Mar 14, 2014 | Tecumseh Snowblower Snow Blower Starter...
I changed the engine oil, filter and spark plugs in my 1999 Volvo 940 (1996 cc). Upon starting up, the engine runs at lower rpm and "hiccups" at idling.
Engine stalls or RPM fluctuates at idle up and down.
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve but always run a OBD2 fault code as well as the cleaning procedure. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
Oct 15, 2012 | Cars & Trucks
2004 mazda mpv engine racing and cooling fan not working
coolant temp sensor tells the computer how hot or cold the engine is so it can regulate the idle and fuel mixture, when it fails there usually is no cooling fan and you will have trouble starting the engine and keeping it running.
Oct 08, 2012 | 2004 Mazda MPV
My 1998 Dodge Ram 1500 idles high upon starting it.
Check temp gauge if It doesn't get to normal heat range it won't idle. Your thermostat needs replacing.
Aug 23, 2012 | 2001 Dodge Ram 1500 Truck 2WD
MTD snowblower with Tecumseh engine 8 hp stalls out when chock is adjusted to run position
hello ,your engine is a tecumseh HMSK90-156525D, Sounds like carb. may need adjusting. Take the heat box off to expose carb. the heat box is the metal box surrounding the caeb., there should be 2 adjustment screws- 1 on the bottom of the bowl and 1 on the side of the carb just above the edge of the bowl ( depending how the carb sets off the engine - if the carb comes straight out it will be on the side facing towards the front of the snow blower or if it goes towards the handles then standing other side of the snow blower the screw will be facing you), turn both screws in til they just bottom out the turn them out 1 1/4 turns out then start the machine. While the machine is running at low idle turn the screw on the side of the carb. in (clockwise) a little at a time listening for the engine to start to rev up and then start to rev down, bog or studder then turn back slightly to bring idle back up. Once the idle is up then the screw on the very top of the carb. turn that out to lower idle to a normal idle. Repeat those adjustments till you cant get the idle to go up anymore. Now for the screw on the bottom of the bowl- move the throttle up to max and turn the screw in till you hear it rev up higher and starts to bog or sputter then turn it back slightly to bring the high rev to a smooth rev. That should take care of it. If it does not solve it then the carb may need cleaning then the adjustments done again. If you need more help on this please feel free to ask. Sometimes you have to do process of elimination and you start with the easiest first. Also the adjustments should help with the carbon build up on the plug.692509.pdf (application/pdf Object)
i have included the manual to give you a good understanding of the carb, page 7 to 25, hope this helps,don't forget the 4 thumbs up,any comments welcome,thank you.~~
Feb 23, 2012 | Tecumseh Snowblower Snow Blower Starter...
My toro snowblower keeps stalling. It starts up fine, but won't run continuously.
If you haven't already, dump out gas and put fresh in it and try this, if it doesn't work you will have to clean the carb, take it apart and clean all jets ports etc and put back together and you should be Good to Blow Snow, pretty common problem with Small Engines that set half the season.
Dec 04, 2011 | Garden
My poulan wild thing 2375 bogs out when throttle
Make sure that the air cleaner and muffler are not plugged. Check the carburetor screws and nuts for tightness. After turning both needles CW to stops (lightly), back them out CCW 1-1/2 turns each. Start the engine and allow to warm up. Open the throttle and adjust the H needle CW somewhat until the engine speeds up, but is 4-stroking. Correct adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Release the throttle and adjust L CW till the engine runs fairly smoothly, but allows the engine to 'follow the throttle'. Set the idle speed screw so that the chain doesn't turn, but the engine keeps running. Hope this helps!
Apr 15, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have a toro 3450 snowblower and it is going to full throttle when it starts and stays there. When I tuch the lever on the carb it comes back down to idle but not until I manually touch it. When I shut it...
Sounds like the adjustments need to be worked on outside the carb. If they are dry put a little bit of light oil or even WD40 on all the moving parts on the carb. Sometimes they just get dry and a little rusty from sitting.
Feb 06, 2018 | Toro Lawn Mower With Toro Power Tools
My 7.75 Hp snowblower starts, runs 15 minutes, then stops.
check your eingine compression, sounds like it is worn hence the rough idle and loss of power under load
Jan 29, 2009 | Briggs Stratton H7159 & Stratton® 5500,...
Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x Logo
350 people viewed this question
Top Tecumseh Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ArcFlash
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Are you a Tecumseh Tool and Hardware - Other Expert? Answer questions, earn points and help others
