Question about Canon PowerShot A80 Digital Camera
My Canon powershot a80 will not come on.
Hi. I own a Canon powershot a80. My camera will not power on with the memory card in the camera. With the memory card out of the camera it will come on. Help! sincerely,Georgie
  • Canon Master
  • 4,738 Answers
Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, don't fret. Although professional repair would be more costly than the value of the camera, there is a very good chance that you can repair this yourself. Please see this link.
Posted on Dec 12, 2009
  • 10,594 Answers
It sounds memory card is defective and preventing camera to turn ON.
Check camera with another memory card or try this memory card in another Canon camera to confirm it.
Posted on Dec 09, 2009
SOURCE:
I have a cannon powershot a80 and it keeps saying no memory card on my screen when i turn the power on.
Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, don't fret. Although professional repair would be more costly than the value of the camera, there is a chance that you can repair this yourself. Please see this link.
May 19, 2010 | Canon PowerShot A80 Digital Camera
My a80 takes forever to power up then it says memory card error
Apr 13, 2010 | Canon PowerShot A80 Digital Camera
Powershot a80 does not turn on
Things to check first are battery contact points, and micro switches that are located on the battery and memory card doors. Details on what needs to be checked may be seen here. It won't work for every case, but it's worth a try.
Feb 15, 2010 | Canon PowerShot A80 Digital Camera
What is the largest memory card i can use in a
the a 80s take compact flash cards, these are now going out in favour of sds. depends on how many photos you want, but check the manual for any limits.
Dec 17, 2009 | Canon PowerShot A80 Digital Camera
I accidentally hit the button to format the memory card in my Canon Powershot A80 camera. Not only did I delete all my pictures but the images through the view finder shows distorted vertical lines. Do I...
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
As for your formatted card, see this article next.
Oct 15, 2009 | Canon PowerShot A80 Digital Camera
Pictures names
First - be sure to copy all your pictures from the camera's memory card to your computer.
Second - using the camera's menus, reformat your memory card.
It's adding the _2 suffix to the filename because it thinks there's already a picture on the memory card with that name.
Sep 16, 2009 | Canon PowerShot A80 Digital Camera
Memory card error is showing up in the window.Canon A80
Try performing a "format" on the card. That should wipe out any bad data that is confusing to your camera.
Jul 03, 2009 | Canon PowerShot A80 Digital Camera
My Canon PowerShot A80 Digital Camera on and then off
If the E18 error code comes along with unusual noises while moving the lens, there may be a problem with the mechanics. Just tap the camera on a solid surface a few times. I had the same problem and tapping helped just fine.
Mar 01, 2009 | Canon PowerShot A80 Digital Camera
LCD screen doen't display the view
So camera doesn't give live view to take picture? and you can view old / stored  pictures OK, is it?
If yes, then it is problem of CCD imager in Canon A80 and this part needs to be replaced.
Canon will repair your A80 free of cost as per announced scheme of CCD imager support.
Click Canon CCD Advisory to know how to get free repair facility.
Jan 07, 2009 | Canon PowerShot A80 Digital Camera
No memory card
Did you check the slot to see if any of the pins are bent?
Jan 25, 2008 | Canon PowerShot A80 Digital Camera
Canon PowerShot A80 Digital Camera Logo
91 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
