Question about Mitsubishi VS-50609 50" Rear Projection Television
Mitsubishi VS50609 has cobwebs behind the ribbed screen and I need to know how to remove the ribbed screen, I already removed the clear cover smooth cover. Sandy
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Set should have the clear screen cover (protective) and two more screens behind that. Easy way is to unplug set and remove back cover--cobwebs are usually behind on inner screen.
With the back off I use a swiffer like duster and reach up and get them all out--gently on the inside of the inner screen so you do not scratch or mar it.
If this helped you rate this solution as I do this here for free.
SD TECH
Posted on Dec 09, 2009
Cobwebs inside screen
you need to take the top back off the tv. and mind the glass at the top of the rear part top it is very fragile, most of the projection tv have a side cover on each side so you can clean the rear of the screen, as you not said what type screen you have i cannot tell you further.
Feb 25, 2014 | RCA Televison & Video
Cobweb behind the screen.
You can try and use a air compressor or canned air and blow inbetween screen and protective cover and see if that removes the cobweb. Give that a try and let me know if that works for you.
Good luck... HDTV GURU JAY
Mar 14, 2011 | Televison & Video
Cobwebs behind the screen of a Mitisubishi WT-55809
Wile your in there you might as well clean the mirror and the lenses *and you will see a big change in your picture!
Remove screws from upper back of tv to access this area ..be carefull with the back the mirror is connected to it!Please rate this answer
Thank You!
Jan 15, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Cobwebs behind the screen of a 55" projection screen. How do I remove screen to clean the TV? I have a Mitisubishi WS-55809.
Hello morsec,
You will need to remove the screws on the back of the top half of the TV set. This will allow you to remove the top rear half of the TV and give you access to the screen. Make sure you do not break the mirror that is attached to the rear of the TV set. Clean the screen with a damp non-abrasive cloth dry with a dry non-abrasive cloth. When finish replace the back of the TV and tighten the screws to hand tightness.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Replacing a screen on the mitusbishi
Hi NJ,
First, which screen do you need -
The lenticular screen is dark in color is rough and has ridges.
There is a fresnel screen behind it.
IF you have a screen protector that is smooth, clear and see through, it would be the very first screen you can see and feel.
If your TV is the square shaped, 4:3 ratio TV, Mitsubishi has probably stopped production on replacement lenticular screens. HOWEVER, we have a couple of those screens still in stock.
After you take the frame off, lay it on a table or put a sheet down on the floor before you lay the frame down. You may need to take the frame apart to get the lenticular screen out.
Hope that helps,
screentv
Jul 08, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Cleaning JVC rear projection screen (behind cover)
You will have to do some dissassembling of the cabinet to remove the screen and bezel assembly. If you are will to do this I can give you the directions.
Mar 22, 2008 | JVC AV-48WP30 48" Rear Projection...
Mitsubishi VS-6043 - 60 inch
These are fairly simple, remove the speaker cover and then remove the screws at the bottom of the screen, then the whole thing lifts up and off, be sure to unplug the front panel controls, this plug can usaly be found just behind the cover behind the speaker grill
Feb 07, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Exploded view diagram
1) Remove rear cover. Slide out pressed-board light shield.
2) Remove any cobwebs behind screens-(soft cloth on pole)
3) wipe lens caps with soft cloth
4) re-assemble
Oct 24, 2007 | Sony KP-57WS500 57" Rear Projection...
Pioneer SD-T50W1
Take the lower speaker grill cover in front off.Remove screws holding sreen frame on. slide screens to side to access cavity.Ask a pro or go slow!!be gentle and observant. remove webs with rag or feather duster.DO NOT spray any liquid.Dust RGB lens caps with soft cloth.Re-assemble.
Sep 17, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Mitsubishi VS-50609 50" Rear Projection Television Logo
158 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
