Question about Compaq Computers & Internet
Computer left outside, is it damaged? - Compaq Computers & Internet
  • 755 Answers
If you didn't plug it in wet and you brought it in and gave it a few days to temperize and dry off. No. It shouldn't be damaged. Laptops have to live in all kinds of weather conditions so they have a bit of weather protection built into them.
Your owners manual should show the limits of temperature for operating AND storing your laptop.
Posted on Dec 09, 2009
What could the problem be for this? Have a treadmill that's been outside for a while. The cord was chewed up and I have replaced it, but it goes on for a couple seconds then turns off. What could the...
If it was outside, was it under cover? If it was not, then the console circuitry are corroded and not fully up to themselves. If it was under cover, same thing can happen. temperature and humidity, moisture and cold can also impair the performance of the unit. It may be a difficult problem to trace unless you can open the console and see for yourself the state of the printed circuit board/s. If it looks like silvery powder around the IC's (integrated circuits) pins, then tht's some air and moisture damage. If you live by the sea, same thing will happen on appliances left outside. And to find the cable chewed, looks like it's been outside for a long time and may definitely have rust on the circuit board, in other words - moisture damaged. If there is no silver rust (powdered ash-type rust) and the printed circuit board looks clean, then try and locate the treadmill manufacturer or its supplier websites and email them the problem you're having.
Jul 26, 2014 | HEALTHRIDER S300i Treadmill Motor Control...
Nissan pathfinder problems
Check childproof lock if you can open it from the inside, but usually the connection between the handle and the lock for the outside door handle breaks.
if you can't open the door using either inside or outside door handles, go to a locksmith, auto electrician or a Nissan dealer or risk severely damaging the interior door panelling trying to do this yourself...
Please get back to us with the solution you found worked as it may help someone else in the future, thanks.
Jul 07, 2014 | Nissan Pathfinder Cars & Trucks
My iphone short circuited from water damage
You have to take the iPhone to an apple authorized dealer, it has to be replaced.
Feb 06, 2014 | Apple iPhone Smartphone
Fan outside isn't running and when turned on the unit outside is running very loud.
The fan outside keeps your compressor cool, the compressor, if left running without the fan running to cool it down can get damaged, the fan normally gets its power from a switch box located outside or near
it. or the motor on the fan could have just gone bad. the fan motor is not as expensive as the compressor to replace. its easy to replace. sometimes what goes out 1st on these motors is the capacitor,the capacitor stores enough voltage to give the motor that extra push to turn. many times its just the capacitor that goes out. when you purchase a motor make sure you also get the matching capacitor.if you can turn the fan and it starts running, its the capacitor, if it starts running and has any kind of bearing noise then you will have to replace the motor. good luck!
Aug 08, 2011 | Heating & Cooling
When i turn on my camera it makes a weird noise and then the screen is all blurry and ive never drpped my camera :/
Sounds like the camera was dropped, or got too HOT. If you left it in the car or outside in the sun the camera can get damaged. I would take it back to the place you purchased it for a pro evaluation on it to be sure. if you screen is blurry that usually means the CCD is damaged.
May 03, 2010 | Nikon Coolpix S210 Digital Camera
What may be causing the right and left buttons on the outside of a ds console to not work at all?
has the unit been dropped ,,, these buttons are very fragile and the lighest drop can damage the board inside and kill these buttons
Mar 18, 2010 | Nintendo DS Console
I left it outside and it wont turn on and its got charge
open the back where the battery is, pull out the battery. you should see either a white, or reddish to pinkish color sticker. if its red, then your phone has gotten water damage and it prob wont work.
Oct 19, 2009 | Cell Phones
Screen damaged from fall, colored vert lines on left side from the damge
Unfortunately the LCD panel would need to be replaced. Even if there is not any signs of damage to the outside portion of the panel, one of the inner screens may have been fractured. I am not sure if the panel would be available because if i'm not mistaken Sharp just started making replacement panels.
Apr 22, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
1997 328 tail light failure
Hello!
You should check the wiring loom on the left trunk hinge.
It gets damaged very often on these bmw's you won't be able to see if there is damage from outside, you need to pull the protective rubber covering pretty far down to inspect.
If it's damaged any decent audio shop can repair it (or you can do it yourself if you're good at soldering)
after it's fixed replace any burnt fuses and it should be ok
Hope this helps!
Sep 28, 2008 | 1997 BMW 328
Computers & Internet Logo
32 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
