Question about Technics SL-1200MK2 Turntable
My Technic 1200 when powered on will spin one way then the other and keepp doing this?
  • 135 Answers
Usually the drive I.C ref IC101 - around £30.00 to buy.
mail@technicsdjuk.com for details
Posted on Jul 05, 2010
Replace Power Cord - Technics 1200 MK2
It's an ac cord. there is no positive and negative. the solid black side is "hot" and the ribbed or striped side is "neutral".
Apr 28, 2013 | Technics SL-1200MK2 Turntable
Need to replace power cord - Technics 1200 MK2
As long as the only thing damaged is the power cord, this should be easy. You said that you needed to know how to tell which side is positive and which is negative? The power cord carries alternating current not direct current. So in this case, polarity really isn't important. The same applies to the two yellow wires supplying the main motor board. They are A/C too. As long as the replacement cord you use is of equal or higher power handeling, and you make sure your connections are solid, it will work fine regardless of polarity. Just be sure the only problem is the cord. Check this link to be sure. Good luck, EW.
This link is a must have for anybody diagnosing a problem with a SL1200/1210. Take a look:
http://www.deckdoctor.com.au/TECHNIC%20SL1200%20PCB.pdf
I’m happy to help further over the phone at https://www.6ya.com/expert/erik_149c4c1c216e42f2
WHY DOES MY TECHNIC 1200 MK3 GO IN REVERSE IF I HIT THE START BUTTON TWICE?
There is a mod you can do to the 1200 to make it spin in reverse with a double-tap on the start / stop switch - exactly as you're describing. Likely, the previous owner installed said mod. It's awesome, embrace it.
Jul 29, 2012 | Technics SL-1200M3D Turntable
How to calibrate control on a technic 1200 by sight
Put the pitch slider to +6 and adjust the internal preset until the top set of dots on the platter are stationary.
Check again with the pitch at +3.3 if the dots are stationary then job done!, if not then the pitch slider is worn and perfect calibration won't be possible until the pitch slider is replaced.
http://stores.ebay.co.uk/methleykev
Jul 14, 2010 | Technics SL-1200 Turntable
Why my technic 1200 is playing 45 at 33 and 33 at 45?
Have the buttons been swapped around?. 33 should be on the left.
Mar 27, 2010 | Technics SL-1200 Turntable
When i turn on my technic 1200 turntable it the lights flicker and looses audio sometimes
Hi, i doubt the 2 are related as the T 1200 doesnt have a preamp, only speed control.
Maybe try checking to if there are any loose ground wires in the turntable (ONLY if you are comfortable to open)
Other than that it the sound issue might be either on the head, or on the phono outs not connecting properly.
If the speed is remaining good, then the issue is just with the LEDS themselves, maybe loose solder, if it is changng pitch as well, then dry joints in the power supply/pitch control
Hope that helps
Jul 15, 2009 | Technics SL-1200 Turntable
Technics 1200 MK2 displaying irregular speed to include dragging and slowing
It sounds like the pitch slider needs to be replaced...
Mikey's Hook-up
88-90 North 6th
Brooklyn, NY 11211
Cover insured UPS charges both ways and you will get sorted.
Oct 23, 2007 | Technics SL-1200MK2 Turntable
Technic 1200 mk2 turntable wont spin
need to know if it powers up. Does it try to spin, do you hear it trying to spin? More than likely the on/off switch went bad. No, I am not referring to the ON/OFF knob. THere is a switch this engages when turned. The part is S601. You might also want to replace the Start/Stop switch as well. If neither work, then the issue is on the main PC board, and probably IC101, or IC201 with the problem. At this stage, you will have to have a service tech look at your unit.
Oct 19, 2007 | Technics SL-1200MK2 Turntable
Technics SL-1200MK2 Turntable Logo
105 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Morne Olivier
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
