Question about Zodiac Baracuda G3 Automatic In Ground Pool Cleaner
Barracuda pool cleaner has suction but not pulsing why?
  • 366 Answers
Either the diaphragm is bad or has some debris caught in it. Remove the nut above the handle and push the white tube downward to see the diaphragm. It should be uniform in shape and should not have a very large opening inside. If it's distorted, it's best to replace it.
Posted on Dec 11, 2009
Testimonial: "thanks, there was something stuck in the diaphragm that I could not see from the outside its working fine now"
2 Suggested Answers
  • 12 Answers
SOURCE: Lots of suction, but G3 won't pulse or move around pool
theres a throat in it. Its damaged or ripped take a close look at it . you can gey at your local pool store
Posted on Oct 08, 2009
Stuck barracuda
It is probably not a problem with the shoes. These pool cleaners (and automatic pool cleaners in general) often get stuck on the main drain since the implementation on the new anti-entrapment drains. There is a ring that you can buy that goes on the drain. It is designed specifically for preventing pool cleaners from getting caught on the main drain.
http://www.backyardcitypools.com/Automatic-Pool-Cleaners/NE290-Smart-Ring-Drain-Cover.htm
Jun 08, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Barracuda not moving
You could have too much suction, something stuck in the diaprahm, a torn diaprahm could do this or if it is sticking to the drain you will have to shut the drain down.
Jan 10, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Oct 05, 2009 | Zodiac Baracuda G3 Automatic In Ground...
Barracuda don't move
what do you hook your vacuum to in the pool? does it have suction? it may be clogged. if so you can blow it out if you have the equipment. it may be you don't have enough suction and all you need to do is adjust one of your suction side valves to fix this problem. if you don't have dedicated valves you can plug one of you other suction lines to give your vacuum more suction.
Jul 24, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Barracuda not bouncing or moving to clean pool
Check suction at cleaner. Could be broken hose, bad or dirty impeller, incorrectly set valves, dirty filter, clogged line and probably a bunch more things.
May 29, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
G3 is not moving, but has suction? Please advise.
I had the same problem. come to find out there was somehting stuck in the diaphram. (a piece of mulch). Once I removed it, everything worked fine. Take your Barracuda apart and check the diaphram for blockage.
Mar 21, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Zodiac Baracuda G3 Automatic In Ground Pool Cleaner Logo
1,280 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
