Question about Motorola Mobility i580 Cellular Phone
Display text flip around All text become, "Mirror image". They fliped around.
I want hp laserjet p2055d printer mirror printing solution
Mirror solution can be achieved by the position of inserted paper in the machine's tray.
Reference is printing in the latter head.
Feb 19, 2017 | HP Office Equipment & Supplies
How do I create mirror image letters?
I will assume you need to print part of page backwards or upside down.
This is pretty easy using a Text Box. A text box can have a border, be opaque or transparent, force the text to flow around it or not.
To create a text box, go to the Insert tab, click Text Box and then I like to choose "Draw Text Box." You can draw it in the general area you need it. It's ok to use one of the preset Text Boxes, too.
Type your text inside.
To flip the text around, double-click your text box to activate it, and then look for the Rotate button in the "Arrange" section on the Ribbon. You can flip it horizontally or vertically as many times as you need to make your text upside-down or a mirror image.
Then edit your box - border, color, text wrapping, position, etc.
Sep 19, 2014 | Microsoft Office Word 2007 Full Version...
I just bought this printer and I have a newer HP Photosmart Plus all in one printer. Unfortunately, I cannot get either printer to print in mirror image. Can you tell me what I need to do to get at least...
Usually you use your software to flip the image before you send the file to the printer. Thus, what program are you using to create the fabric transfers?
This is easiest if you are dealing with an image. Find the command section for layouts and then choose flip or rotate horizontally. For example in Paint, the Rotate drop-down is part of the main ribbon below Crop and Resize. If you are trying to do a line of text, use a drawing program and write the line of text. Select it and then flip it. Write all of the lines of text and repeat the rotation for each one. Similarly do this for any images or lines of images.
When finished, print a test page on regular paper before using the fabric transfer paper.
(Publisher in Office or similar programs will also do this well.)
If you are using images from a file, import it into an appropriate software program to do the rotation then save it to a new file name before printing.
I hope this helps.
(some printers have the mirror image option in the Advanced Settings. Not many of the ones that I have used have the feature.)
Sep 15, 2011 | HP DeskJet 1000cxi InkJet Printer
How do I do mirror (or reverse) printing for a t-shirt transfer? Thanks.
If you are printing text only, you can create it using wordart in word and then use rotate or flip command to reverse the text.
If you are printing a JPG with text, the easiest way will be to use photoshop to edit the image and add text if desired, then use the mirror utility, The picture and text get reversed and the transfer is printed in reverse to become "positive" when you iron it on the Tshirt.
hope this helps.
Mar 07, 2011 | Canon PIXMA MX870 Wireless Office...
I have a Pixma mp500 and I want to print or copy some text in mirror image. (making an iron on t-shirt)...Have no idea how to flip it in word either
you can actually use any graphics program to apply mirror effects. It is usually under rotate ie. go to Paint which is under programs, applications. add a picture and go to rotate and rotate horizontally and you have a mirror image.
Dec 26, 2009 | Office Equipment & Supplies
How to print mirror image with Cannon Pixma ip2000
  1. Click the Printer and Paper tab.
  2. Under Paper, in the Size box, select Letter.
  3. Click OK.
  4. Do one of the following:
    • If your design is a picture, clip art, or WordArt, flip it horizontally.
    default.aspx?assetid=za790050011033How?
    1. On the Arrange menu, point to Rotate or Flip.
    2. Click Flip Horizontal.
    • If your design includes text in a text box or table, turn it into a picture first, and then flip it horizontally.
    1. Select the text in the text box or table in your design.
    2. On the Edit menu, click Cut.
    3. On the Objects toolbar (toolbar: A bar with buttons and options that you use to carry out commands. To display a toolbar, click Customize on the Tools menu, and then click the Toolbars tab.), click Insert WordArt default.aspx?assetid=za060452451033.
    4. Under Select a WordArt style, click a style, and then click OK.
    5. Press CTRL+V to paste your text into the WordArt Text box.
    6. Format the text, and then click OK.
    7. If necessary, resize the WordArt, or use the WordArt toolbar to format it, and place it in the design.
    8. Select all the objects in the design, including the WordArt.
    9. Click Group Objects default.aspx?assetid=za060447801033.
    10. On the Arrange menu, point to Rotate or Flip, and then click Flip Horizontal.
  5. Print your design on plain paper first to make sure it looks the way you want it to.
  6. Make any adjustments to your design after seeing the test printout.
  7. Make sure thermal t-shirt transfer paper is in the printer.
  8. On the File menu, click Print.
  9. Select the options you want.
  10. Click OK.
Source
Cheers
Jun 20, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
I need to have a mirror image of text in power point .
If you are using PowerPoint 2007, here is how you can accomplish this:
Select the text, Then right click and select Format Shape, Then select 3-D Rotation, then change the X value to 190 degrees.
In PowerPoint 2003, you can't create mirrored text,, you can however use WordArtto create a graphic image of text that you can mirror by using the Rotate or Flip command.
To create mirrored text with WordArt, follow these steps:
  1. On the Drawing toolbar, click Insert WordArt.
  2. In the WordArt Gallery, select the WordArt style that is closest to the effect that you want to use, and then click OK.
  3. In the Edit WordArt Text dialog box, type the text that you want.
  4. Click OK.
  5. Use the tools on the Drawing and WordArt toolbars to format the text the way that you want.
  6. On the Drawing toolbar, click Draw, point to Rotate Or Flip, and then click Flip Horizontal.
You will see a mirror image of your text.
Apr 07, 2009 | Microsoft Computers & Internet
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
Motorola Mobility i580 Cellular Phone Logo
59 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
