Question about Kitchen Ranges
Hi, MY name is Ben I have problem with my Kenmore (GE) gas range. the oven does not start up...I've replaced the igniter, but no luck. I measured the voltage across the the two wires at the inigter and their is 120v presesnt as the oven is turned on but goes aways in about 10 to 15 secs. Help! How do you trouble shoot after replacing the igniter, if it's the thermostat or if it's the gas valve is at fault?
  • Kitchen Ranges Master
  • 5,138 Answers
Gas Regulator is stopped up replace it.theirs a little vaule inside of it that goes bad.one side is for burners the other goes to oven the side feeding oven is not allowing gas to pump through.
Posted on Dec 17, 2009
My GE xl44 gas range broiler won't work,
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 02, 2011 | GE Profile JGB900 Gas Kitchen Range
Tip
Hi, MY name is Ben I have problem with my Kenmore (GE) gas range. the oven does...
This advice is for GAS ovens with glow bar type igniters. This is a fairly simple repair that MOST do-it-yourselfers can accomplish with just a little guidance. But, first, here’s a little gas oven theory to help you better understand how to determine if an igniter is bad:
The way the ignition system in most of today’s ovens work is like this:
  1. Set the oven or broiler temperature.
  2. The igniter begins to glow.
  3. Once the igniter reaches a certain current potential, the gas safety valve opens.
  4. Gas is introduced into the manifold and you have ignition.
  5. NOTE: It can take roughly 30 – 90 seconds from the time you set your oven temp to the time it takes for the gas to ignite.
NOTE: This is a designed safety feature of the oven to prevent free flowing gas from accumulating in your home without ignition. That’s why you typically don’t hear any gas flowing when you have an igniter problem. You might think you have a gas problem when actually you have an ignition problem.
TWO BASIC IGNITER TYPES:
Carborundum (Cylindrical in shape) – needs to produce 2.5 to 3.0 amps for the gas safety valve to work.
Norton (Rectangular in shape) – needs to produce 3.2 to 3.7 amps for the gas safety valve to work.
NOTE: There is a UNIVERSAL FLAT BAR igniter on the market as well, that can be used as a substitute if the igniter type that came with your range is not available.
An easy way to determine if you may have an igniter problem is to check BOTH your oven features. If the oven doesn’t light, check the broiler and vice versa. Since both the BROIL manifold and BAKE manifold are fed from the same gas source, but have separate igniters, it’s an easy assumption to make that the igniter may be bad, if one or the other doesn’t light.
The igniter typically goes bad in one of two ways, the igniter either stops glowing completely, or becomes weak over time and doesn’t produce enough current to open the gas safety valve (in this case the igniter will still glow but the oven still won’t light). Longer ignition times can be another symptom of an igniter possibly going bad.
For this solution, however, we’re going to assume you have a bad igniter and need to replace it. Follows these steps:
NOTE: The same method applies to both the broiler and bake manifold.
  1. UNPLUG the range and turn the gas off if you have a local gas cut-out valve (it is recommended that you do).
  2. Open oven door and remove (if possible). Refer to your owner’s manual to see if there are instructions on how to remove the oven door. Some have spring-loaded locking hinges, while others just lift out. If you cannot figure out how to remove the oven door, use care not to lean on the door or put too much weight on it. A common complaint following any kind of oven maintenance is that the oven door doesn’t shut correctly any longer. This is usually caused by bending the hinges or springs coming loose.
  3. Remove the oven racks, and remove the oven pan. (There are usually two screws either in the back or front of the oven holding the pan in place).
  4. Remove the Flame Spreader. This is a metal plate on top of the manifold.
  5. The igniter will be mounted directly to the gas manifold. Follow the wires that lead to igniter. It will either be plugged into a connector, or be connected together with ceramic wire lugs. Your replacement igniter should come with extra ceramic wire lugs. In the event the plug does not match the one on your range, cut the wires and connect using the ceramic wire lugs. DO NOT use standard wire lugs, they are not heat resistant and will melt.
  6. Unplug the old igniter and remove the mounting screw holding it to the gas manifold.
  7. Install new igniter on gas manifold using care not to handle the element on the igniter with your hands. The oil from your hands can cause damage and/or premature failure. The igniter is also considered FRAGILE.
  8. Reconnect the wires using the recommendations mentioned in Step 5.
  9. Plug in the range, turn the gas valve back on and do a visual test by setting the oven temperature to the desired range. Allow 30 – 90 seconds for the igniter to light the gas. Turn oven off and allow sufficient time to cool. If the oven has only been lit for a minute or so, the cool down period will be brief.
  10. Reinstall the flame spreader, oven pan, and racks. Reinstall door if necessary.
Most igniters cost around $50. Prices will vary with models. I hope this information is helpful.
on Dec 09, 2009 | Kitchen Ranges
Kenmore oven starts getting hot, then quits after a while..
heatman101 ..
Oct 10, 2010 | Kenmore 75022 / 75024 / 75029 Gas Kitchen...
Xl44 GE GAS RANGE OVEN WONT WORK, RED LIGHT IN
heatman101
czvb
May 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Me GE Gas oven is not working, but broiler and range do ?
I am working with model JGBP26WEH1WW GE Gas range: You do not need to remove the back or even turn over, just remove the storage pan at the base of the unit and disconect the two plugs (unique plugs). You will need to splice your old conectors to your new igniter. Yes you have the correct igniter for that model.
Apr 06, 2010 | GE Profile JGBP79 Gas Kitchen Range
Hi, MY name is Ben I have problem with my Kenmore (GE) gas range. the oven does not start up...I've replaced the igniter, but no luck. I measured the voltage across the the two wires at the inigter and...
A burner works only intermittently If one of your burner heating elements works only intermittently, it's probably because of worn or bad contacts in the receptacle that the element plugs into. On most electric ranges, you can remove the element by lifting it up several inches and firmly pulling it away from its attachment (receptacle). Read your owner's manual to learn the correct technique for your range. If, after removing the element, you see that the ends of the element that were plugged in are pitted, corroded, burned, scarred, or rusted, replace both the element and the receptacle.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 09, 2009 | Microwave Ovens
GE Gas Range Over Won't Heat
Hello, Yes this is going to be the bake igniter. If you remove the lower panel in the oven you will see the bake igniter. It may still be working when you switch on the oven but it is not getting up to the correct temp in order to ignite the gas. Replace the igniter and you will be all set. If you have any other questions please feel free to comment. Good Luck! Mike
Oct 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven not heating up to temp. Sometimes get small explosion inside when starting. Sometimes small slight gas when lighting. Top burners work fine. Model GE JGBP26GEJAWH
heatman101
gk
Aug 13, 2009 | GE JGBP26 Gas Kitchen Range
Broiler Still Not Working
does the board control both ignitors and if so your right the ignition board is bad.
Aug 27, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE oven
Yup...I believe this may have been an issue with some GE models. I seem to remember a problem where some models had problems staying lit after preheating. The fix was replacing the oven thermostat. Now...the normal cycle for an oven lighting is just what you described. The glow igniter will glow first, followed by the gas valve opening, followed by ignition. Once the oven reaches optimum temperature it is normal for the gas to shut off and come back on to maintain oven temperature. However, if this is going on in a frequent fashion with the oven never getting warm, your guess is probably a correct one. Good luck to you.
Jul 31, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
23 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
