Question about D-Link DIR-615 Wireless Router
My d-link wireless router lights turn on properly but it is not sending any signal and when connected by lan the computer says limited connectivity
  • 755 Answers
Try resetting your broadband connection, then the router, then your computer in that order.
These devices get out of sync on their addressing occasionally and a front to back reboot is all they need.
Posted on Dec 09, 2009
  • 11,896 Answers
Unplug for 10 seconds, plug back in and everything should be fine after that. (couple minutes later after pluged back in and connection is registered)
Dear potential life savers - suddenly I can no longer pick up wireless signal on laptop. The router is connected to my ethernet connected mac in one room, and until yesterday the other computer in the...
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ONuntil the LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jun 29, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
I wont to play game in lan with my home frends bat my computer canot find a lan .the game is full . my net is with dinamic ip..what i can do?thanks
D-link router provides signals through cable wired connection where each persons computer shares signals from the only computer that has network services. For example, one of the computers that has the internet on which router is connected either has capacity to network several additional computers or not. Usually the server computer that has connections with ethernet cables makes sharing signals possible beyond dial up phone line networked cable conections.The routers splits signals between computers requesting connectivity only becomes possible when enough capacity exist to several computers. The type of network strutures makes the link possible. For example, D-link router should allow to network more than one computer else another router that makes signal expansion possible is prefered. Circumpectively, ascertain that the computer from which video game is installed has the expansive capacity either in cables connection ports, wire links where router becomes the location where each device derives resources.
Feb 22, 2011 | D-Link 802.11g Wireless Router WBR-1310...
All the lights on my router are blinking and it will not send out a signal. What do i do?
For that you need to RESET router 1 time then configure it again with below procedure.You can RESET router with RESET button press it for 10 seconds then all settings defaults. Then follow below. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . Let me know if you need further assistance. Thanks for using FixYa.
Nov 17, 2010 | Linksys WRT160N Wireless Router
Adsl wont stay on ,quick set up ,says cant find modem
Either the router is not connected properly to the modem, or the modem is not set up properly. First, unplug the router from the modem and disconnect power to both of them. Make sure the modem is connected to its data source, in this case the telephone line. Make sure the company has authorized the modem and make sure it's connected to the phone socket they specified, if they did. You should plug a CAT-5(ethernet) cable between the LAN port on the modem and the WAN port on the router. Now power on the modem. Wait until the modem's lights indicate it has a connection. If the modem doesn't indicate a connection, call your ISP. It will probably be as simple as them sending a refresh signal to it. After the modem finds a connection, power on the router. Your internet service should now be working. If not, try plugging the computer's network cable directly into the LAN port on the modem. If that computer then has internet, your problem is with the router. If the computer still doesn't have internet, then the problem is either with the settings on the computer or there's still a problem with the modem/ISP
Feb 27, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Its always show at the the monitor the " A network cable is unplugged".
If you are connecting to the Internet using a wireless connection and your LAN card in the computer does not have a LAN cable connecting it to a hub or router then you will get a message "A network cable is unplugged".
If you don't use a wireless connection and you only connect to the your network/Internet then the problem is either the LAN cable has come loose in the computer's LAN card or at the router or the LAN cable is faulty.
Nov 17, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
No signal from router
Try turning off the power to the router for 30 secs and then power it up again.
Sep 28, 2009 | Computers & Internet
I'm trying to connect my DSi to my home network through my router
if your computer can do the internet, the only thing i can suggest as i have limited knowledge is that you get a Nintendo LAN adapter which you plug into your computer when its online and it sends the WiFi signal to the DSi
Apr 11, 2009 | Nintendo DSi Black Console
Connecting DLink thru Comcast Cable Modem and Vonage box
first you see the in the internt explorer in that tools in that is give internet option in that connection>lan settings> if the proxey server is ther then remove it if not ther then go it. i think you get it.
second think is that in your dlink router reconfigure the router properly and give the isp details correct and one more thing is check the dns value.
Jun 12, 2008 | D-Link DIR-625 (790069292637) Wireless...
Wireless connection
Was there any power outages, or anything that would make the modem and router turn off and then back on?
Try this:
Do this:
(in this order)
  1. Turn off the router.
  2. Turn off the modem.
  3. take out all the Ethernet cords from the router, EXCEPT the one coming from the modem
  4. Now turn the modem on.
  5. Wait for the lights, then wait about another minute for it to settle.
  6. Turn on the router, make sure the Internet,Lan,Wlan,etc lights are on and functional if it doesn't display a light let me know.
  7. Now depending on what your wireless network (SSID) is called try to connect to it. Go to Start>Network>Click Network And Sharing Center at the top>on the left select Manage Wireless Networks>now click add, if your network is already on the list shown select it and click remove otherwise click "Add" click "add network in reange of this computer" select your network name and click connect.
Oct 19, 2007 | Intellinet Active Networking (520638)...
D-Link DIR-615 Wireless Router Logo
165 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
