Question about Cozy Enclosed Front Console Heater 20,000 btuh Propane
Pilot light has gone out and can't seem to relight following instructions. Is there a reset button or something I need to push before I can't light the pilot again following the instructions?
  • 396 Answers
Replace the thermo couple.
Posted on Dec 09, 2009
Wher is pilot light
Why will my pilot light on the gas water heater not stay lit for ...
diy.stackexchange.com/questions/.../why-will-my-pilot-light-on-the-gas-...
Jul 28, 2011 - The pilot light went out on my gas water heater. I followed the ... This could be from a valve not being all the way open. It could also be from a ...
How To Relight Your Pilot Light On Your Water Heater ...
? 7:54
https://www.youtube.com/watch?v=gqM7kMkkFAI
Apr 15, 2013 - Uploaded by TipsNNTricks
How To Relight Your Pilot Light On Your Water Heater. TipsNNTricks .... I answer the following questions in this video. How can I relight my pilot ...
How to Light a Water Heater (with Pictures) - wikiHow
www.wikihow.com/Light-a-Water-Heater
wikiHowJump to Questions and Answers - If the pilot light doesn't relight or goes out immediately after ... if you are unable to light the water heater after several attempts.
Jan 13, 2016 | Water Heaters
Light pilot light
Many heaters have pilot flames can be relighted with a match or push button operation. Many employ safeguards to prevent unburnt fuel from accumulating in the space or allowing an unstable pilot flame from "proving".
Most appliances have instructions printed or embossed on or near the pilot, gas valve or protective cover. It is very important to closely follow these instructions for your safety and that of others in the area. If you are unable to locate the instructions or follow them and relight the pilot, you should contact the gas company for assistance. This can be in indication of an issue with fuel, thermocouple, gas valve, etc., and would require a service person to correct.
I have included a link to a video to light a gas heater - yours may be the same or similar:
How To Light The Pilot Light On Gas Heater
Feb 23, 2015 | Heating & Cooling
Vulcan oven pilot light how to relight
Hello Lynne,
To relight the pilots,start by removing the floor of the oven,then remove the small access panel below the doors. On the main oven burner will be a small pilot burner that probably looks something like this 10_26_2011_9_29_16_pm.jpg
on the gas valve behind that small panel under the doors will be a red button,push that red button and hold it in while lighting that pilot burner...continue tohold that red button for 30 seconds,release it and the pilot should be lit.
Good luck,GENE
Oct 26, 2011 | Vulcan 60XLC Gas Kitchen Range
Pilot light has gone out we have no hot water how do we relight it the auto relight isnt working either
Hello, Thank You for using FixYa. I will be helping you today.Set the knob to pilot and push in on the knob and hold it in then push the ignitor button while still holding in the knob when it lights keep holding in the knob after a few seconds let go of the knob if the pilot stays on turn the setting to on.
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | Kitchen Ranges
I have no hot water, and there does not seem to be a button to relight the pilot as there is a srewed on panel which seems that it needs ro come off. Please advise. I've been without hot water. I am...
Karen, behind that screwed on panel are the controls to light the pilot. Then follow the instructions for lighting the pilot, which should be on the back of that removable panel.
Hope this helps you.
May 04, 2011 | Heating & Cooling
Have a Model #21V40-7 Natural Gas Rheem water heater and the pilot has apparently gone out. Can you tell me how to restart the pilot and what position the controls should be in for this model and...
The main control knob will have a "Pilot" position. Set it there, then light the pilot. You may have to press and hold the control knob to do that. There may be a striker button that will relight the pilot while you're holding the control knob or you may need to use a match or a candle lighter.
Once the pilot is on for 30 seconds or so, it will remain lit when you release pressure on the control knob.
Dec 27, 2017 | Kitchen Ranges
Pilot light has gone out how do i relight it?
Hi .. look at the control valve on the burner .,. there is a knob you can turn. It has markings for pilot and run, or something like that. turn the knob to pilot and push and hold it in. Light the pilot wit a long fireplace match. After the pilot is lit, wait about half a minute and relese the knob,, the lp[ilot should stay lit.
Apr 03, 2010 | Water Heaters
Pilot light gone out. How do I relight? Which
In general, large button from gas valve push in & hold 20-30 secs at same time push electronic lighter/ignition button to light pilot. Remember to hold in only gas button. the pilot light heats up a thermo couple [u can see this in the flame] and when hot enough allows the main gas through and the pilot to remain on.
If not then either thermo couple not heated for long enough or
it may need replacing
Oct 22, 2009 | Bosch Water Heaters
The pilot light on my vokera mynute 14-48-SE has gone out how do i relight it?
turn honeywell gas control clockwise and push in then spark egniter hold for 20secs then ease off button slowly pilot sound remain alight
Oct 08, 2009 | Water Heaters
My pilot light also just went out on my water wizard 13P when you relight ensure all buttons are equal in height or none depressed then hold far left button down whilst striking ignition button till pilot light ignites keep left hand button depressed for a further 3 seconds after pilot light has ignited I hope you have hot water then
May 22, 2009 | Audiovox Bosch 718 World Cellular Phone
Heating & Cooling Logo
120 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
Paul
Paul
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
