Question about Refrigerators
Got a GE refrigerator SC4SS. The freezer always completely freezes up over a period of a couple of months. There is one thermostat in the upper right rear of the interior of the box. Is this just for the freezer or is is for the complete refrigerator? I do not need to use the freezer. If I turn this thermostat to OFF, what will it do to the refrigerator part?
  • 478 Answers
That controles the whole freezer and refridge
Posted on Dec 10, 2009
Refrigerator works for periods of time. The inside freezes up on the freezer side and then the refrigerator and freezer stops working. Unplugged it for 24 hours and then it worked again for 10 days and...
That is a common problem that comes with your model when the defrost heater part number, Click Here=> WR51X10030 Defrost Heater Assembly
Click Here=> Location of the Defrost Heater and Defrost Thermostat
You do not always need to change the defrost thermostat but it is a good idea while inside replacing the defrost heater, but it is a good idea to replace because they also can cause problems. Click here for the=> WR50X10015 Defrost Thermostat Here is a link to the Service Manual=> HERE And if you have any questions please let me know so I can help you complete this repair. The above parts links have easy how tutorials on how to test the parts I posted here today, Thanks, Sea Breeze Please rate this if helpful, Thanks
sea_breeze_215.jpgWR50X10015 Defrost Thermostat
Jul 11, 2011 | GE GSS25LGM Side by Side Refrigerator
My GE TFX26GRDA side-by-side refrigerator periodically freezes up the coils so completely that no air circulates and the fresh food compartment gets WAY too warm. It does this over a period of anywhere...
replace the defrost timer located in the upper area of the fresh food section with new timer part # AP2061695 its behind the cover in the fresh food section they do get intermittant in operation especially the timer motor inside this part
Apr 10, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Water dispenser freezes-up periodicly even when used regurlay
Make sure you have not turned your freezer thermostat too high. If it's over factory setting it can freeze up your water line.
Nov 26, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE SIDE BY SIDE MODEL #GSH22JFRE CC FREEZER COIL FREEZING AND REFRIG NOT COOLING. DEFROST MANUALLY AND REFRIG COOLS FOR A COUPLE DAYS, THEN FREEZER COILS FREEZE AGAIN
We have a GE side by side that was only 4 years old before it starting giving us problems-coiling freezing over. The warranty period was only one year on all parts, including the compressor. Through our research we learned that profile appliances have or did have a better warranty. I believe it is 5 years on all or certain components. Either way it may be worth contacting GE customer service to help you with the issue and determine if repairs and parts for your appliance are still covered under warranty. They were very helpful in our case and ultimately discounted the parts I ordered and replaced myself. Replaced the the temperature sensors on the freezer side, the defroster thermostat and defroster heater before finally breaking down and replacing the control board. The control board was the problem. It was very easy to replace. While working through the issue, we would defrost the coils located on the inside of the freezer side with a hair dryer. It would get us by until the parts came in or they frosted over again and prevented air from circulating over them, thus causing the freezer not to cool. Good luck. Hope this helps you.
Nov 23, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Not getting any water out of the dispenser, but its making ice
The water dispenser on my GE profile fridge stopped working for a couple days. The refrigerator and freezer temperatures have fluctuated over the past several months causing fridge items to periodically freeze and freezer items to periodically thaw. GE tech came today identified a bad circuit board, which he replaced for a cool $300. Ouch. Fridge is only three years old. Oh yeah, the icemaker also has a broken tab which causes it to jam every couple weeks. We have GE Profile appliances throughout our kitchen and they all work great except for the fridge :-( I hope GE engineers read this post. If so, get to work! LOL
Feb 03, 2010 | GE Profile PSW26P Stainless Steel Side by...
Freezer side not freezing
Turn off the refrigerator.Remove the freezer shelves/bins and rear panel.
Take a hair dyer and thaw the ice completely. The defrost heater will be across the bottom of the freezer coil. The defrost thermostat will be attached to a refrigerant coil at the top of the freezer coil.It is about the size of a quarter and 1/2 inch thick.There will be wires from top to bottom on the sides of the coil.
May 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The freezer is freezing up every 3-4 weeks
likewise, sorry no solution but have the same problem. freezer develops ice build up and also stops fans from going. solution would be welcome - tried defrsting and yes works but oly for a while.
Jan 21, 2009 | GE GSH22JFT Side by Side Refrigerator
GE PSS26MGPWW
Yes the refrigerator knob is just a damper between the freezer and the refrigerator. All the heat removal is done in the freezer section. it just dumps air through to the refrigerator. So drop the thermostat down to about 5 and try that. If food is still freezing
drop the thermostat a little more. If food continues to freeze then your thermostat could be bad. Not sensing temp properly and allowing the refrigeration system to run to long.
Hope this helps
May 23, 2008 | GE PSS26MGPWW Side by Side Refrigerator
Freezer and fresh food sides not staying cool.
If you truely have a leak in the system that would need to be properly taken care of if you ever want to return to normal operation. If the defrost timer goes bad usually you will completely freeze up the coils which causes air circulation problems and only the very lowest part of the freezer (and sometimes fridge) sections will freeze. The upper top of the unit won't be very cold. Same thing happens if the evap. fan (above the coils) goes out (no air circ.).
Jan 15, 2007 | GE GSS22JEM Side by Side Refrigerator
Refrigerators Logo
239 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
