Question about Rangemaster Broan 614804 BALLISTA 48IN HOOD1 BRAND IN STOCK
Our APP2540 hygena Chimney extractor 90cms has stopped working it is 4 years old the light is working, last week it was working intermittently now it has stopped
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
This sound like the pcb for all your cooker hood spares visit our site
You-Tube video "8eLuShj-RAg" placeholder (do not delete)
Posted on Jan 08, 2010
Our buck stove smoke even when damper is open it’s probably 15 yrs old didn’t do it til last 3 yrs
eeks...the chimney is probably getting restricted by creosote. get the chimney cleaned if you already haven't recently. You don't want a chimney fire. Not trying to scare you but it's important to make sure the chimney is clean.
please disregard if you have had the chimney cleaned with in the last 3 years or so,
Dec 31, 2017 | Refrigerators
Rangemaster part 2995 A119
Hi Gerald,
for old Rangemasters it is difficult to find the original parts, as they have their outside model.
But when you open the switch carefully, you will find 2 switches on a board, one for the light and one for the fan.
These parts are common for a lot of cooker hoods. The switches look like the one of link 1
Genuine Creda CRV10W Light Bulb Switch Cooker Hood eBay
the second link gives you a complete unit, so the light switch and the vent switch on a board
https://shop.ukwhitegoods.co.uk/08086215-hygena-cooker-extractor-hood-switch-pcb
I hope you will find the right part.
Kind regards, Dik
Jan 17, 2017 | Rangemaster Kitchen Ranges
Fl3 code. heater working fine when i closed last year. will not start this year. showing fl 3- does not ignite , does not do anything ..help please
3.
Spillage at A.Cold chimney A.Allow heater to operate 5 minutes to create draft action.
draft hood B. Vent pipe pitches down to chimney B. Reinstall vent pipe to pitch up from heater to chimney.
C. Blocked chimney C. Remove blockage.
D. Draft hood altered D. Install factory-provided draft hood.
E. Prefabricated chimney with incorrect cap E. Install a Nationally Recognized Testing Lab (NRTL) listed vent
http://www.jandy-downloads.com/pdfs/Lite2_LJ_IO_H0248900F.pdf
I tried to copy the FL3 write up from the chart but it screwed it up a little. Look at Page 35 of the manual for a clear copy
Jun 10, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
Hygena APP2500 cooker extractor hood?the lights on the hood work but the extractor itself does not work, is this likely to be the motor that needs replacing or the switch unit ? Plz advice
if u have a meter u can check the switch and the motor,By putting it on the continuity mode and check to see if u have a bad motor or switch
Apr 02, 2011 | Dryers
Hi, I am a caretaker in a 12 suite apartment block. The building has an old gas-fired hydronic Weil McLean boiler (maybe 10-20 years old). The gas pilot switch was regularly flipping (about 2 times at...
IS ANYONE CHECKING GAS PRESSURES? A BLOWING PILOT COULD BE UNSTABLE AND LIFTING OFF.IF IT IS WIND RELATED TRY A PIECE OF TIN FOR A "WIND SHIELD" AROUND THE PILOT
Jan 05, 2011 | Heating & Cooling
My hygena/schreiber tall intergrated larder fridge has stopped getting very cold. I thought the thermostat had stopped working .As insructed I turned it off waited 30 minutes and turned it back on. I...
Check where the compressor is and right next to the compressor should be a fan .Check to see if fan is running ,if it is then check the final type coil to make sure they are clean .
Sounds like your unit is shutting off on high head pressure
Jun 22, 2017 | Refrigerators
Bosch dke 935 90cm hood. light and extractor not working
The fuse will be located in the switch or socket that the hood is connected to. This is sometimes inside the flue on the back wall. There should be two small screws either side of the chimney located at the top, unscrew and slide one part of the chimney down, please be careful as stainless steel has very sharp edges.
Dec 09, 2009 | Bosch DKE93xxUC Stainless Steel Kitchen...
Toshiba Camileo h20 battery problem Toshiba Camileo H20 camcorder bought in July O9 Worked fine on 2 week holiday and have recharged the battery 2 or 3 times since. Latterly battery charge didn't last very...
It's eight years old now, and if as you say it has had intermittent use, then the battery will probably have died unless charged at last once a month.
Mar 27, 2017 | Toshiba Video Cameras
My Hygena cooker hood fan (model APP2540) stopped working.
this sound like the pcb for all your cooker hood spares visit our site
Feb 22, 2009 | Rangemaster Broan 614804 BALLISTA 48IN...
Rangemaster Broan 614804 BALLISTA 48IN HOOD1 BRAND IN STOCK Logo
1,040 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
