Maytag Neptune front Loader Washer : Squeaks at the beginning of the wash cycle, worse with heavy load ???? Not on spin or rinse...
  • roger_bri797
    roger_bri797 Dec 09, 2009
    Thanks, I will order parts and tool today..thanks again.
  • 3,741 Answers
The spin brake is slipping during agitation, causing a squeaking noise. the brake assy is the cause of the squeak.the cost of this part is near to $40 and you can get it from
www.repairclinic.com
This problem is normally attributed to a combination of two things: A worn out snubber ring, and a worn brake assembly.
The snubber ring assembly is a white teflon ring that sits under the wash tub at the base (called the milk stool, because it looks like an upside down milk stool). The entire wash tub assembly will rest on the snubber as it helps get rid of vibration while the tub agitates and spins. When the snubber starts to wear down, you will notice an increase in tub vibration during the spin cycle and it will sometimes begin to squeak. NOTE: YOU CANNOT OIL THE SNUBBER! DOING SO CAN CAUSE MORE DAMAGE.
The brake assembly is mounted between the pulley wheel and transmission under the washer. As the brake assembly ages, the pad (which is mounted along the rim of a metal disc) begins to glaze over. As it glazes, it will also squeak and cause the sudden "slamming" to a stop. The glazing, coupled with humidity in the air can make this condition worse.
this problem occur normally with this model washer and can be attributed to normal wear and tear. I recommend replacing the brake assembly and snubber at the same time. You will need, however, a special Maytag brake removal tool and spring removal tool if you decide to attempt this repair yourself other wise a local repair technician is adsvisable.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Dec 09, 2009
Someone put some heavy things in it and it stopped mid-cycle. We removed the heavy objects, and then attempted to drain the leftover water by putting it on "rinse and spin." It never really...
The ND error code on a digital Neptune front load washer. The ND code means 'No Drain' and it is probably just something caught in the pump. Sometimes this is a early sign of the pump going out or a control board issue.
Nov 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag front loader HE washer.
cheak your tube if there is a nail or an object is stuck in one of the holes
Jan 24, 2010 | Maytag MAH6700A Neptune High Efficiency...
Strange growling sounds on rinse and spin cycle
I would check the motor control board located near the floor on the right side for burnt components. The motor is a 3 phase unit and if one of the phases are working the motor will growl and won't be able to supply the proper torque.
See www.neptunehelp.com for disassembly photos and for more info on the faulty door latch wax motor.
Jan 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune rinse cycle doesn't start.
cold water valve screen plugged or bad valve, just check it!
Aug 06, 2008 | Maytag Neptune MAH6500A Front Load Washer
MAYTAG PREFORMA 2 SPEED 10 CYCLES 2004 TOP LOADER
Check your lid switch, some machines stay running when you add clothes when it agitates, but will shut off if you lift the lid in rinse and spin, lid switch may be broken.
Jul 15, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Maytag neptune won;t rinse
Check latch mechanism for alignment. Often operation of machine loosens latch mechanism causing internal switch for "door open (or ajar)" preventing rinse or spin cycle. Opening and closing door presses latch mechanism closing internal switch allowing for continue processing to rinse or spin cycles.
Mar 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
