Question about Nokia N95 Cellular Phone
Nokia n95 screen problem cannto read the screen slanted lettersetc
Pls how can i flash my nokia N95
No matter what network your Nokia N95 phone currently runs on, you can unlock it---or "flash" it---to run on any GSM network. You will only be able to use your unlocked Nokia N95 phone on networks that use SIM cards---such as T-Mobile and AT&T---and not on CDMA networks such as Sprint and Verizon, which do not provide SIM cards.
Read more: How to Flash a Nokia N95
Unlocking the Handset
Remove the back cover and the battery from your cell phone. Locate a silver sticker with a bar code on it. Take note of the 15-digit IMEI number printed on it. At this time, also remove the SIM card and write down the numbers printed on the back of it. The SIM card is the small, white data chip in the silver cradle right next to the sticker. You will need these numbers to obtain your Nokia unlock code.
Request a Nokia N95 unlock code from your service provider. If they cannot provide you with an unlock code, you can buy one online.
Replace the SIM card, battery and cover. Fully charge your handset.
Turn on your handset and type "#PW+".
5
Enter the unlock code given from your phone company or website. Make sure you dial the number exactly as it was given to you. If you dial this number incorrectly three times, you will be permanently locked out of your handset.
6
Dial "+1#". At this point, the screen on your Nokia N95 should read "SIM Restriction Off."
Inserting SIM Card
Switch your handset off and remove the back cover and battery.
Remove the SIM card.
Insert the new SIM card into the SIM card slot. Now that the phone has been unlocked, this can be a SIM card from any U.S. service provider that uses SIM cards.
Replace the back cover and battery and switch the cell phone on. The screen should now read the name of the new service provider
Nov 30, 2011 | Nokia N95 Cellular Phone
My n95 nokia all ok but White Screen , Please
You don't need a Nokia N95 diagram.
The white screen means that the ribbon cable that attaches your main phone circuit board and the screen has become damaged or come loose.
A good phone repair shop should be able to repair this for you.
Or if you are brave and don't mind taking a risk of damaging your handset further you can replace it yourself.
I hold no responsibilty for any damage you do to yourself or your handset though.
You can get a ribbon cable and tools to attempt a repair for around £10
Jul 16, 2010 | Nokia N95 Cellular Phone
N95 replacement screen flickers after 20 mins of
remove the screen and reinsert it.....may be some loose connections.. try using another screen...if problem persists then update the firmware or else change the screen....
Nov 24, 2009 | Nokia N95 Cellular Phone
N95 Nokia Screen light
goto light setting and enable ur back light
Aug 18, 2009 | Nokia N95 Cellular Phone
Nokia n95
sir... lcd replacement could solve your problem...
Feb 05, 2009 | Nokia N95 Cellular Phone
Nokia N95 Lcd Screen
there are several repair shops out there who give a free quote.......I bought a replacement off ebay and it was dud....go to the experts!
Aug 21, 2008 | Nokia N95 Cellular Phone
Nokia n95 problem
The connection might have worked loose. The problem is, with the Nokia N95 a number of parts have to be renewed when dismantling, including screws.
Mar 04, 2008 | Nokia N95 Cellular Phone
Nokia n95 lcd screen
Send me your mail ID and i will send it to you. This site not giving permission of sending larger file.
Jan 09, 2008 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
41 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
