Question about Panasonic Lumix DMC-FX9 Digital Camera
I have put a sim card into my camera that I have used in the past but it says memory card error. I have also tried a brand new card and the message says the same. The only card that does not give the message is one I have in a digital photoframe with photos already on it. Do you know what the problem can be please ?
Trying to upload photos off the sim card on a sony camera. when the computer is posting the thumbnail shots it gets about half of the 600 or so and says "devise can not display thumbnail copies, device is busy?" Not sure how to extract the photos off this card any suggestions?
Posted on Aug 16, 2011
  • 687 Answers
No but a good idea is to copy the photos to optical disc with a known good PC then reformat the card on your Panasonic Camera, some times SD cards get confused with the formatting.
Posted on Dec 09, 2009
I have a Kodak EasyShare C330. I have a new memory card Kodak SD Card 128MB. When I insert it in the camera, a message displays stating memory full. When I try to format the card to the camera I received...
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
Try to format the memmory card using a card reader and the PC this should solve your problem if not you have to replace the memmory card.
Mar 11, 2011 | Kodak EasyShare C330 Digital Camera
Hi there. i have a canon ixus 30 camera. i brought a brand new 4gb memory card for it. when i put it in the camera it says 'memory card error'. i read somewhere that formatting it helps but when i tried to...
Many people are unaware that the newer SDHC format cannot be used with most older cameras. Your camera was manufactured well before the SDHC format came out. I'm sorry, but there's no way that a 4GB SDHC card will work with your camera, it just doesn't understand the new format of the card. The max size card that you can use with your camera is a standard 2GB SD card. More info may be found at this link.
Nov 18, 2010 | Canon PowerShot SD200 / IXUS 30 Digital...
Error on formating new memory card in camera error says memory card is full brand new card i tried 2 in faact same error kodak c310
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Feb 08, 2010 | Kodak Easyshare C813 Digital Camera
2GB SD card is brand new but camera says it is full.
Some of the older cameras will not take the bigger cards. You can use the bigger card with your computer to store your photos.
Jun 03, 2009 | Kodak EasyShare C330 Digital Camera
Memory card error with new memory card
Hi there, welcome to FixYa.
Let's work on the camera first.
1) Turn the camera off and remove the battery and the card.
2) Put the battery back in without the card and turn it on.
3) Turn the camera off and insert the CF card.
4) Turn the camera back on again.
See if that takes the message away.
If it doesn't leave me a comment and we go to step 2.
If it does, thanks for coming to FixYa.
Rob
Mar 14, 2009 | Canon PowerShot A75 Digital Camera
The camera doesn't accept new memory card put into the camera
Sorry that this answer is far too late to be of use to you, but it may help others searching for advice with the same fault. I only stumbled across your unanswered question by accident.
8GB is an SDHC card. Your camera was designed to use the earlier SD cards instead with a maximum 1GB capacity.
Dec 07, 2008 | Kodak EasyShare C533 Digital Camera
Error message on san disk sd card
You may have answered your own question. There is a good chance that your memory card has reached the end of its life. You might try reformatting the card with the computer and then do the format in the camera. This has worked for me before.
Jul 18, 2008 | Cameras
Error 10 message
The error 10 message is trying to tell you that the new memory card you have tried to put in is not compatable with your camera. AS you have already tried turning it off/on, replacing batteries etc, you can try taking all cards out, and attempt to get it to fuction correctly with original cmaera memory. After taking out all cards, and with a fully new set of batteries in, use your cameras menu to format the camera memory. Now try and take photos with just normal memory. Is it working? If it does, and error is gone, put in old memory card and reformat it. Does camera pick it up and recognise it. Can you now use it. The new card you tried to install may have been an incompatable brand. Check your manual for approved brands or your local dealer. The card could also be faulty.
Aug 08, 2007 | Nikon Coolpix 4600 Digital Camera
"Memory card is locked"
This error message means that the memory card is write-protected. To take a picture, turn off the camera. Then insert a new card or change the storage location to internal memory
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Panasonic Lumix DMC-FX9 Digital Camera Logo
268 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
