Question about Canon Rebel XT / EOS 350D Digital Camera
Shutter speed My Canon XTI will not let me adjust the shutter speed in manual mode. Anyone know what the problem might be? The camera has been idle for the last month.
  • Andy May 11, 2010
    When you set the mode dial to another Creative Zone mode (P, Av, or Tv) does the command dial respond to changes (i.e. does your aperture change in Av, does your shutter speed change in Tv, or do both shift in P) as you move it?
I've experienced the same problem, I take out the battaries and wait for a minute or so, and usually it resolves the issue
Posted on Mar 21, 2008
I'm having problems with the settings on my Canon EOS 400D. When I take pictures in AV mode I can get quality pictures but in TV or M modes the pictures always come out so dark even when taking them...
You need to understand the relationship and teractivity of aperture, shutter speed and iso. In Av mod, you choose the aperture and the camera makes thw shutter speed agjustment, In Tv mode, you set the shutter speed and the camera makes the aperture adjustment, In manual, you have to set both shutter speed and aperture manually. If the ISO mode is set to AUTO, the camera chooses the sensors sensitivity to light automatically. Change to specific ISO
(200-400 for daylight and 799-1600 for night). Take a picture in AV mode and note what shutter speed the camera chose. Then switch to TC mode choose the same shutter speed and see if camera chose the same aperture(f-stop) you chose in first shot. Change to Manual and choose same f-stop and shutter speed the camera chose for you in the other modes. Compare all three photos. They should be almost if not exactly the same exposure wise.
In Tv mode choose a dlowers shutter speed, In Manual choose a combo of slower shuuter and wider f-stop(smaller number). Read your manual.
Jan 02, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
Cannot adjust aperture or shutter speed in manual modes
Suggestion.... try to reset all settings to default. See what happens then.
Sep 08, 2009 | Canon Cameras
Canon Rebel XTi over exposes images in auto setting
Try in reset the camera to factory settings.
If still you have a problem, then try with a different lens.
Best regards,
Jul 09, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Blurry sports pictures that are inside and are fast moving b(basketball). Is the problem my lens? I am using a Canon XTI. I am a pure amateur just wanting pics of my daughter playing ball.
If you're shooting in the full Auto mode, you are not taking advantage of the capabilities of your digital SLR. Your pictures are blurry because the shutter has to stay open long enough to properly expose the picture, but the people are moving while the shutter is open. You need to increase your shutter speed or increase your ISO, which means you have to select another mode on your camera. You could invest in a "faster" lens, which means that it can allow more light into your camera, but is also more expensive. Try this excellent tutorial on using a digital SLR, then try it out with your camera (use your camera manual to find the correct mode selections, etc.)
http://www.photonhead.com/beginners/
Look at the topics under Photographic Concepts to get an understanding of the relationship between shutter speed, aperture, and film speed (ISO).
Jun 23, 2009 | Canon Digital Rebel XT / EOS 350D Body...
Shutter speed won't go above 200
I have two possible solutions:
First, are you shooting with the flash up or an external flash connected to it? If so, the camera likely needs to synchronize at 1/200 or slower otherwise it won't be able to take a full photo. As a safety feature to prevent that, many new cameras just restrict the ability to pick a faster shutter speed.
Second, if its not related to the flash, it might be related to the mode you are using. Turn the camera off the automatic modes and put it on an all manual setting. Change the ISO to 400 or so, got outside and aim up at the day's sky, put it on manual mode and then adjust the shutter speed. Open up the aperture on your lens all the way (turn it to the smallest number). Now adjust the shutter speeds. It should be able to go past 200 now.
Nov 25, 2008 | Canon EOS Rebel G 35mm SLR Camera
Manually setting shutter speed and aperture..
http://web.canon.jp/imaging/eosd/eosdigital4/specifications.html
First off, welcome to the world of photography! Good luck and have fun!!!
Like any slr, you have the option of Manual exposure. I'm not familiar w/ modern Canons (I use Nikon). According to this page, however, you also have aperture priority and shutter priority. I'm pretty sure ALL modern Canons have bracketing modes as well (Use this for HDR).
I couldn't find the 450 manual (I'm assuming Canon's web devs are behind), but I did find the instruction manual for the 400 :
http://gdlp01.c-wss.com/gds/0900000357/EOSDRXTi400DIM-EN.pdf
Should be similar, probably w/o some of the functions. Although you SHOULD have a book w/ your camera ;). Read it thoroughly.
Ok, according to the 400 manual, put your camera into Manual mode, then adjust the regular dial to adjust shutter speed. Then, to adjust aperture, hold in the A/V button while you adjust the same dial.
Like I said, may be a bit different. I think the dial may even be digital buttons rather than analog...
hope this helps!!!
Nov 22, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS 400D
Gosh Megz, That's prolly more than anyone wants to type. Go to the Library or a book store. I'll try to explain white balance for you. Inside the camera is a program that evaluates the light during exposure. It tries to determine what is white and adjust the other colors in the photos accordingly by adjusting tint and temperature. Your eyes and brain do this for you. If you have a tripod try taking a photo in automatic mode and write down what the shutter speed and f stop was for that photo. Adjust your camera to those settings manually and take the same photo over. This way you will get a consistent photo to look at. Then change your color balance to different settings like daylight, cloudy, shade, tungsten (which is incandescent lighting) and fluorescent and view the difference in colors after you download to your image viewer on your computer. You'll think you went back to the late 60's.
Sep 13, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Speedlite 540EZ and EOS 400D
540EZ will not work on digital Canons in auto reading mode. It will only work on manual flash settings.
Mar 15, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Dark shadow on right side of picture
sounds like a shutter leaf dropping into the image. however, they are usually horizontal and more likely to manifest when in landscape mode. (horizontal, normal)
try using flash pointed up to ceiling.
also, could need to check for auto sync speed setting. usually 1/125 to 1/60. if its off, it could be catching the shutter in the wrong place.
check manual for settings for using flash.
mark
Dec 09, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
Shutter priority mode?
s I understand it from what I have seen on the Web, the 3000Z can operate in several modes: 1. Fully automatic (camera select both 2. Manual (user sets both aperture and shutter speed). 3. Aperture Priority mode - user sets aperture and camera chooses correct shutter speed to get a good exposure Apparently there is no Shutter Priority mode (user cannot set only the shutter er speed and allow the camera to set the aperature to get a good exposure). This option is available on the Epson 850Z camera and this seems like a silly ommision to make on a "high-end" camera like the 3000Z.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
49 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
