Question about Sloan Home
How can i make the toilet flush longer - Sloan Home
  • 24 Answers
Flush twice and/or hold the flush valve down while the refill valve continues to run water into the bowl.
Posted on Dec 10, 2009
3 Suggested Answers
SOURCE: toto toilet with gmax flushing system blue top
I have the same problem and can not find a solution. The toilet flushes fine but then a delay in filling up the tank occurs. Is there a part I can replace? Does something need to be cleaned or cleared?
Posted on Jan 15, 2010
  • 298 Answers
SOURCE: One of the plastic stems that extends down inside
Service kits with a selection of common parts can sometimes be found at DIY stores but you might have to replace the whole flush mechanism
Posted on Feb 22, 2011
I have a Kohler dual flush cartridge toilet and on small flush there isnt enough water being released to wash any paper away. We have two toilets like this and one flushes much more than the other. Can the...
not really as the flush time is set by the manufacturer in the design
what can be adjusted is the water level in the cistern
the more water , the longer the flush before the reset ( shut off)action is activated adjust that by the float screw ot water level adjust screw on the inlet stem
Feb 27, 2015 | Kohler Home
I had the same issue wit my champion toilet the issue was finally resolved by using a plastic drain snake and cleaning out the flush tube at bottom of drain (1" hole at bottom of drain facing toward front of toilet) mine was restricted down to 1/2" "bad casting I think"
May 14, 2014 | American Standard Cadet 3 FloWise...
Flapper valve closes too quickly
Fill the breather hole (1/8" hole) inside the flapper.This is designed to let air out so the flapper will sink. Now it floats longer letting in more water. 25%percent more in my case.
Apr 22, 2012 | Home
I recently bought (9 months ago ) an american standard brand model CADET 3 one piece unit and recently 1 month ago , after flushing the toilet the water fills the up the water tank but there is...
theres probably debrie in flush valve, mite also try putting food dye in tank (any color) if it appears in bowl the flapper is seeping water and activating flush valve..
Nov 21, 2010 | American Standard Cadet 3 Right Height...
2 new toilets installed. customer complaint of occasional clogs. no apparent problem although i feel the flush valve closes very fast. any changes or adjustments for this
Often I change the flapper to get the toilet flapper to stay up longer, giving a longer flush....
Check for a generic flapper that wiill work with the toilets you installed...
heatman101
Aug 04, 2010 | Mansfield Plumbing Products Home
I have a toto toilet that doesn't start to refill until a couple of minutes after I flush. Any ideas. Thanks.
Several ideas. Start to fill? Have you looked inside the tank to see what's going on? If it just filling very slowly, then you most likely have some calcuim build up inside your flush valve blocking some flow, if this is the case you will have to clean the flush valve. If your flush valve is staying up and the toilet is "running" unitil the float drops. The float (either the arm ballcock style, or newer fluidmaster) is rubbing on either the flush lever or side of the tank, and taking longer to drop to let the water start flowing. I
Jun 23, 2010 | Toto Toilets ST784S 12 Sedona Beige...
Incomplete flush.. Water level is the proper height, it appears that the flapper is closing too early. What can be done to improve that?
If the flapper has a small cup attached to it that drains out slowly while the toilet is flushing, it could be emptying too fast. There should be some small pins attached to the cup that are there to be torn off and used to plug holes in the bottom of the cup. This will slow the drainage down and allow a longer flush.
If not that, look for something similar that will accomplish the same thing by allowing the flapper to remain open longer.
Oct 08, 2009 | Eljer Toilet Onepiece Canterbury ...
Toto toilet with gmax flushing system blue top
Jun 20, 2009 | Toto Drake ADA Compliant Toilet with...
Toilet flushing
you either have the wrong flapper or it is not adjusted right try moving the chain to shorter or longer lenght the other thing to check is that your handle is not loose if you have to tighten handle be careful it is a reversed thread also check water level in tank
Apr 07, 2009 | American Standard Cadet 3 Right Height...
Home Logo
357 people viewed this question
Top Sloan Home Experts
richochet
Andrew Taylor
Andrew Taylor
frankdanfelt
Are you a Sloan Home Expert? Answer questions, earn points and help others
