The photo paper does not feed into printer. I
The photo paper does not feed into printer. I makes the motion but doesn't feed. If I put it under the roller feed, it will print 2 pictures, then again says out of paper.
I have the G600 printer dock .
In talking to a friend, she is having the same problem.
  • 428 Answers
Get hold of the photocard and try, with your fingers, to curve the end that goes into the printer first so that it doesnt resist as the machine tries to pick it. Just curve/bend it little upwards, not downwards. Usually this kind of problem is temporal and happens especially when the card is a bit too hard for the machine.
Posted on Dec 09, 2009
PHOTO PAPER NOT FEEDING
adjust the paper thickness of the printer as photo paper is thicker than ordinary print paper
Jul 30, 2016 | Office Equipment & Supplies
Canon ip4300 manual
hello,maybe the paper feed is jammed try to see if it has something that stops the paper to go in and if you are asking for the service manual for the ip4300 printer you can download it from the below link:
http://goo.gl/ZYxxU
Good luck
May 25, 2013 | Canon PIXMA iP4300 InkJet Photo Printer
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
Paper moving fault
If the paper is moving freely in the printer and you are not experiencing any paper jams etc it may be possible the error is being indicated falsely.I would recommend firstly to ensure the tractor feeds on the printer are clean and free from a build up of paper dust etc. As the paper motion sensors are located on the tractor feeds.
If after the printer is cleaned the error is still see the problem may be related for a setting for the Paper Motion Threshold in the printer. this is the point at which the printer detects an error. This value is dependant on a number of factors; Paper Type, condition of the printer etc.
  1. Put the printer OFFLINE
  2. Press and Hold down LINE FEED and ENTER until TECH ACCESS ON is displayed (approx. 5 seconds)
  3. Press the MODE button
  4. Press the DOWN ARROW until TEST is displayed
  5. Press button 1
  6. Press the DOWN ARROW until DIAG is displayed
  7. Press button 2
  8. Press the DOWN ARROW until PMOTTHR is displayed
  9. Press button 3
  10. Press the Either ARROW to set the value to 170 and then press ENTER to save the value.
Once you have completed the above sequence press and hold down the LINE FEED and ENTER KEYS to turn tech access off, you can then test the printer. If the above does not clear the message try increasing the value further.
If the problem persits you may have a faulty paper motion sensor.
Nov 23, 2011 | Tally Line Matrix T6050 Printer
Canon ip3600: New Printer doesn t recognize that
Possible solution:
In Preferences/Properties, make sure that "Automatically Select" is selected in "Paper Source"
Mar 31, 2009 | Canon PIXMA iP3600 Photo Printer
Epson Stylus 580rx won't identify vellum paper
Ran into the same problem. The problem is that the printer's paper sensor sees through the vellum and therefore doesn't think any paper moved into the print position. To use vellum, fold up 1/4" edge on a standard peice of print paper and place the leading edge of the vellum under the flap. Place the paper and vellum into the printer and print. The printer will pull in the paper and the vellum together. Make the paper fold tight and straight to prevent jamming. You will need to feed one sheet at a time. Also the Epson inks take a long time to dry on vellum. I let mine dry overnight.
Jan 05, 2009 | Epson Stylus RX580 InkJet Photo Printer
The paper feed on my canon pixma iP3000 is not working
You can search on internet for service manual, in order to find how you can open the printer and fix the issue.
Dec 09, 2017 | Canon PIXMA iP3000 InkJet Photo Printer
Paper Feed Problem
Hey I had this problem too for about 6 months. Just press the "Feed Switch" button under the main display to switch it from feeding from the tray under the printer.
Sep 20, 2008 | Canon MP610 Photo All-In-One Printer
Paper Feed Problem for 8.5x11 Photo Paper Pro
Please check out the roller and paper setup on the tray, Clean it thoroughly.
Also make the Printer to put it on a Horizontal table if any inclination there.
Regards
Ellin
Apr 25, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
96 people viewed this question
k24674
Marvin
Marvin
