Question about SanDisk Sansa E280 MP3 Player
How do i get the videos to play on my sansa e280r
  • 80 Answers
Sansa Video Converter is the first professional Sansa MediaConverter software. It will help you to convert video and audio filesto Sandisk Sansa compatible format, including MP4, MP3, WAV, etc. Itaccepts a wide range of video formats - 3GPP, 3GPP2, ASF, AVI, DAT(VCD), DivX, MOV, MP4, MPEG-1, WMV and Xvid, and output to Quicktimemovie supported by Sansa.
Posted on Jan 14, 2010
E280R was froozen and is still froozen even with it plugged in pc
i'm sorry to hear that. Now, my friend u may go this site for help:
http://kb.sandisk.com/app/answers/list/
Feb 26, 2010 | SanDisk Sansa E280 MP3 Player
How can you tell if it is a version 1 or 2?
Sansa e200 series has 3 not interchangeable versions of firmware:
  • version 1: e200, firmware starts with v1.xx.xxx
  • version 2: e200v2, firmware starts with v3.xx.xxx
  • version rhapsody: e200r, firmware starts with v1.xx.xxx
Site for the difference between these versions:
http://kb.sandisk.com/app/answers/detail/a_id/193
The exact type should be on the back of the player: model e280R.
For the rhapsody there is only 1 firmware available.
The zip file can be downloaded here:
http://mp3support.sandisk.com/firmware/rhapsody-1.0.2.165.zip
When another firmware is needed, go to the download firmware wizard on next page and select your model:
http://www.sandisk.com/sandisk-support/driver-download-wizard.aspx
Sep 25, 2009 | SanDisk Sansa E280 MP3 Player
Drag droped several mb of mpeg &flv format sansa e280r wont recog
It would be possible for them to play on the computer because it has the capability to do so. It will be playing the files as if a memory stick is plugged. You need to convert those flv videos to a compatible format that the sansa can recognise.
Aug 16, 2009 | Audio Players & Recorders
Sansa e280r wont connect with laptop
On your Sansa, go to "Settings," then "System Settings," then USB Mode, change the mode to MSC, then try it. If that doesn't work try the other modes just in case.
Hope this helps!
May 06, 2009 | SanDisk Sansa e200 MP3 Player
Load main image failed SunDisk Sansa e280r rhapsody Refurb
load main image failed Switch to recovery mode e260
Aug 05, 2008 | SanDisk Sansa e260 MP3 Player
DELETING VIDEOS FROM MY MP3
Below are the instructions. I hope I've made them clear enough!
Make sure your device is under MSC instead of MTP...To do that go under Menu, settings and then usb mode...
Step 1
Open up Windows Explorer: Start > Programs > Accessories > Windows Explorer
Step 2
On the right of Windows Explorer, click on My Computer
Step 3
You should see two devices after your CDROM drive. One will be SANSA E260R and the other will be Sansa e200R Rhapsody. Chose the one on the top; the one that doesn't say Rhapsody. It may say E250R, E260R, E270R, or E280R depending on which model you have.
Step 4
Once you're viewing the device, you'll see the folders: PHOTO and VIDEO. These are the folders that contain your photos and videos. For videos, you can simply remove the video you want to delete - it will completely remove it.
I hope that helps
Please rate accordingly
Thank you
Computerrep
Apr 26, 2008 | SanDisk Sansa e250 MP3 Player
Can't download files from Overdrive files
Make sure that either your Rhapsody or Overdrive subscription is still good and resync all files in Windows Media Player.
If that fails, you'll have to start from scratch:
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Apr 13, 2008 | SanDisk Sansa E280 MP3 Player
Some songs sound lifeless on my e280r
There are many settings in Windows Media Player for Ripping music. Make sure yours are set to WMA with 192kbps or higher..
Windows Media Player>Tools>Options>Rip Music (Copy CD).
Best of Luck.
Oct 14, 2007 | SanDisk Sansa E280 MP3 Player
My video isn't syncing up right...Help?
Have you tried other video's and do they do the same thing if not it could just be that file, Also check for new firmware updates. http://www.sandisk.com/Retail/Default.aspx?CatID=1238
Jun 08, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
116 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
