Question about GE Dryers
How do i get the cover off to get to the heating element of a GE dryer model DDE7206MCL
    Sergeant:
    Champion:
  • 278 Answers
Howdy: Some of these modles the cover is underneath the unit. Have to lay down the unit nd unscrew bottom cover. They don't make it easy!!!
Good lock - Doug
Posted on Dec 09, 2009
How to install a heating element in the GE wall mount dryer
GE Dryer design (Most or almost)....
Heating element access is from the front.
1. Remove the Front Door
2. Remove the belt.
3. Remove the Drum.
You see the heating element. Very simple design
Apr 06, 2015 | GE Dryers
GE profile dryer,Runs fine but no heat
need to have the heat element checked with a multimeter and visually if u can and look for burns and corrosion and breaking of the wire connections. Also have the thermostats checked, Im assuming its electric and not gas? the thermal cut off may be bad and the hi-lo thermostat, these can shut heat off from the dryer. Ive replaced the element on my G.E profile and it wasn't all that hard rather simple.
Sep 13, 2014 | GE Profile Gas Dryer Model Dpsb513gb0ww
How do I replace heating coils
Most GE models goes like this....
Remove top cover.
Remove front door panel
Remove belt.
Remove drum cyinder.
You will see the heating element.
Jul 31, 2014 | GE DBSR453EBWW Electric Dryer
Remove and replace heating element in GE Dryer
Not enough info! what is model number?
GE dryers has many models and each one has different procedure to remove heating element
Apr 20, 2014 | GE Washing Machines
GE dryer, no heat?
Your heating element is most likely burned out . Have you made certain all of your lint vents for the dryer are not clogged ? Also , be certain to clean the lint filter every time you use the dryer. A buildup of lint in the dryer , in the hoses & on the back of the dryer inside in between the drum & the outer covering can get so hot it will catch on fire when the heat is working , and also , without a fire will burn up your heating element.
May 18, 2012 | Dryers
Hi I have a ge adora dryer that won't heat up
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Jan 26, 2011 | GE Dryers
Not heating up
This looks like it is an older model. The normal place I check for parts doesn't stock the heating element. I found an alternative place but the part is $90.
The element is in the large round area that surrounds the drum assembly. Here's a diagram. The heating element is part number 512. The line doesn't reach all the way there but I think the element is the two dark rings inside the housing. Here the page with the parts listing. You'll note that the model number is the same but the brand is GE. GE makes hotpoint.
Sep 25, 2008 | Roper REX4634KQ Electric Dryer
How to get to heating element on ge dryer
Most heating elements can be accessed by removing the back cover of the dryer. Please unplufg the dryer first before starting this project.
Oct 25, 2007 | GE DBXR463EBWW Electric Dryer
Dryers Logo
43 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
