Question about Samsung LN-S3251D 32 in. LCD HDTV
Horizontal flickering lines in a samsung 32 LCD HDTV
- can see the picture but lines are there 90% of the screen
- lines on all sources
- been using it for 1.6 years, suddenly started happening
  • 1 more comment
  • ec_13 Jan 23, 2008
    I found out from the technician that the problem is caused by a damaged video board or tuner board. Still wondering how can this happen?
    Is there a way to get this board and do the repair by myself?
  • ec_13 Jan 24, 2008
    Thanks for your reply.
    I found out from the technician that I have to replace the main board.
    Any idea where can I get it from? or what's the exact part number for the mainboard so I can look for it online?
    Do you know how to get the instructions on replacing the mainboard?
    Genius:
  • 1,067 Answers
Try the wash out feture in menu see if that helps get it out its not sumthing ever day guy can fix
Posted on Jan 23, 2008
    Novelist:
  • 173 Answers
Get the professional, although this won't be an expensive fix... You likely have one or more caps in the vertical circuit that are going bad... A cap acts like a battery in a circuit taking on voltage and releasing it at an even rate. When they go bad their ESR (equivilent series resistance) rises and the cap takes longer to reach it's op temp and work properly...
A tech with an ESR meter will easily find and repair this one...
no other issues only a minor problem..
Press the ‘menu’ button on the Remote Control
  • Select ‘INSTALLATION’
  • Select ‘CONNECTIONS’
  • Select HDMI 1, 2 or 3 depending on the input you have connected the PC
  • Select ‘PC’
    But if your product is still under warranty, better contact your dealer and get the issue fixed
  • Posted on Jan 23, 2008
    • mohana sundaram Jan 24, 2008
      call Samsung directly and explain the issue and they have the nearest TV repair shop swap out your main internal board,call 1800-samsung
    Samsung 5271f. Picture usually great but sometimes when an image with horizontal lines appears (e.g. crawl at the bottom of the screen) picture jumps and flickers. Reverts back after crawl disappears.
    If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
    Feb 12, 2017 | Samsung Televison & Video
    Horizontal line about 1 from bottom of picture
    The t con board or LCD panel of the tv is faulty. Can confirm by replacing the t con board.
    If you wish to get some details; check the site linked here. Pull up older posts.
    http://electro-medical.blogspot.com/
    Apr 13, 2016 | Samsung Ln32d403 32-inch 720p 60hz Lcd...
    It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
    Samsung LCD TV with no video and high pitched sound - Digital TV ...
    www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
    Jan 7, 2010 - 26 posts - ‎15 authors
    Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
    Samsung LCD Green Screen - Forums - CNET
    www.cnet.com > Forums > Samsung
    CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
    Jun 11, 2015
    Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
    Jun 11, 2015
    Samsung DLP crackling/static noise
    Jun 11, 2015
    LCD TV making clicking/cracking sounds
    Nov 24, 2006
    More results from www.cnet.com
    Samsung LCD Loud Noise and Green Vertical lines at Start up ...
    www.badcaps.net > ... > Troubleshooting TVs and Video Sources
    Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
    Horizontal lines flickering at the bottom of screen...... SONYbrvia KDL-32L 5000
    Hi Freddy Pagan
    I like your Sony TV is defective that it cannot be fix again, better call the Customer Support to replace your Sony TV.
    I hope my solution may help you.
    Thanks for using Fixya...;-)
    May 06, 2014 | Sony Bravia L-series Kdl-32l5000 32-inch...
    Samsung ln52a650a1fxza LCD has horizontal band of dark lines across screen
    check connections on top of screen this is becoming a stockfault on samsung tvs
    Dec 01, 2012 | Televison & Video
    White horizontal flickering lines
    If still under warranty, take it back. but first check your cable input connections or cable signal may have went bad. Lastly it could be the signal module inside.
    Jan 02, 2008 | Samsung LN-S3251D 32 in. LCD HDTV
    Samsung LN-S3251D 32 in. LCD HDTV Logo
    176 people viewed this question
    Jerry Greenberg
    Jerry Greenberg
