Question about Sony Ericsson Walkman® W995 Cell Phone
Problem with the phone service network and battery meter
Phone says no service network recieved but sim works on other phones
If people dont know on w995 phones sony have placed the ariel on the bottom right of the handset (NOT ON THE TOP AS MOST HANDSETS) so holding the phone on the side and little finger underneath to support it WILL HELP the reception better not fluctuate the signalas much d taylor
Posted on Jun 26, 2010
No this wont solve it you need to update your phone on the sonny ericsson site just down load the up date servise and follow instructions it worket for me :)
Posted on Dec 13, 2009
Htc 1s service is disconnected
Hello Dear:
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Dec 18, 2012 | Cell Phones
Insert smart sim
Insert sim error happen if the phone is not acknowledging the existence of sim card inserted in the phone.
1. Check if the sim is properly inserted.
2. Turn off mobile phone
3. Remove battery
4. Remove memory card
5. Remove sim card
6. Check the copper pins of the sim if there are dirts stucked on it
7. Ure clean cloth to wipe sim gently
8. Wait for at least two minutes
9. Gently and properly insert the memory and sim card
10. Insert the battery
11. Turn on mobile phone
13. Check if you will still recieve insert sim error
14. If you still recieved the same error you need to call your service provider and check the status and availability of your sim card.
Dec 09, 2011 | AT&T LG CU720 Cell Phone - Silver
Will not call or recieve calls has new battery and sims, everything works but can't make calls or recieve calls.
If the phone works fine as you said but cannot make calls or receive, this could be a network problem, you will need to contact your network service provider of the sim you are using, it could be that they are yet to activate the sim, giving them call to explain the problem will help to activate the sim. Try use a friend phone to call the customer care line to give the details of the problem, by so doing, they will help activate your sim so that you can make calls and receive calls.
Jul 27, 2011 | Samsung Rugby SGH-a837 Cell Phone
Am trying to use 3 sim and a lebara sim in google nexus one.But its not working at all. i have no idea what's wrong with it.When ever i insert a sim card it is showing a network but not connecting or...
Firstly you need to make sure that the phone is unlocked i.e. it is not tied to another network. Secondly, perform a manual network search. You do this by going into your menu and selecting: (i)settings, (ii) network services, (iii) network selection, then (iv) manual. It will then search for available networks: click on any network first, and then go back into it again and click on Lebara. If that still does not work try the SIM in a different handset.#
Lebara Customer Service
Nov 21, 2010 | Google Nexus One Smartphone
Phone works but says "no service" iFOE Mod. # P168
suggestions:
  • try inserting a new SIMcard of similar network, and if this work with your phone, secure a good signal.. then try sending a simple message.. then recieving a message..
  • try inserting a new SIMcard of different network, and if this work with your phone, secure a good signal.. then try sending a simple message.. then recieving a message..
  • if both/either this doesn't work, try getting back your original phone settings...
  • still doesnt work? have your phone serviced by a qualified cellphone technician..
Nov 28, 2008 | Dual Electronics CECT P168 Cellular Phone
I have a siemens gigaset A140 phone, i cant hear the line and dial tone. i hearing a recieving call tone but i cant answer.
Try a harware reset! dont worry this will not delete anything on your handset. it is a simple procedure:
while the phone is on take out the battery and then the sim
then insert the battery by itself and power it up.
It should ask to insert a sim or something along those line.
when it does take the battery out again while the phone is on.
put it all back together and power the phone up again.
If this does not work.
Try MnuL ROm in network settings. search manualy and select a different network to what you are on and then do the same and go back to your service provider. then reset back to automatic.
if that does not work there is one more thing.
if the handset is 3G try setting to GSM mode only.
Sep 30, 2008 | Siemens Cell Phones
"limited service"
check the "network settings" and make sure your set to auto or something similar. you dont say who your provider is but is sounds like your not on your "home' network, that is your service providers network.
Mar 18, 2008 | Samsung SGH-E900 Cellular Phone
Se k800i cant recieve sms
I think the problem is your phone has some settings that disabled your SMS functions so I suggest you to try and put your SIM card in another phone and try sendng SMS. If it works, try Reset Settings from the K800i. If it doesn't work, try changing a SIM card from your service provider.
Aug 30, 2007 | Sony Ericsson K800i Cellular Phone
Sony Ericsson Walkman® W995 Cell Phone Logo
230 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Marvin
Marvin
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
