Question about Technics SC-DV290 System
Stereo does'nt stay on you turn it on and it just clicks n goes off technics dv290 system
Problem with amplifier contact dealer,i have the samne problem with mine,its shows F61 on the diplay and when i check my user manual it states there is a problem with the amplifier
Posted on Jan 03, 2010
How to connect a mp3 to a Technics SC-DV290 5 Disc DVD/CD Home Hi-Fi
get audio lead to fit mp3 and connect to back of the stereo and set to aux
Jun 26, 2014 | Technics SC-DV290 System
How do i connect technics turntable model SL-QD33 to technics stereo model SC-DV290 and what do i need to switch to on stereo to play records.
Have a look on the back input panel of the sc-dv290. Check for a "PHONO" input. If there is no phono input it will not play turntable. If there is: then plug it the turntable in and switch the SC-DV290 to PHONO mode.
Another way would be to purchase a "phono preamplifier" from ebay: Hook the turntable into the phono preamplifier, and the preamplifer into the SC-DV290 AUX input.
Feb 26, 2011 | Technics SC-DV290 System
Hello there, I have a problem with my Technics SC-DV290 System. The problem i have is that when i go to turn it on it buzzes and it cuts out after a second or two and there is no display on the stereo...
ok. there is a MAJOR problem with the power wiring. i suggest not turning it on again until either you have fixed it or a trained professional has.
Jan 24, 2011 | Technics SC-DV290 System
Technics SA-DV290 Amp. Sound cuts out as volume is increased
hello it sound like the output ic may be in trouble you may have just dry joint on the ic which just resolder it . or there could be a capacitor leaking or they may have swelled up in which you will have to replace. it's best to do some visual checks first i'e look for any burnt parts any capacitor with bulging tops
regards
shaun
Apr 04, 2010 | Technics SC-DV290 System
I have a Technics stereo integrated amplifier SU G75. The cooling fan began making chirping noises then stopped. Now every time I turn the stereo on I get a overload message. Could it be the cooling fan...
It chirped because the bearings were worn out, then it froze up and isn't moving any air. Get it replaced. DO NOT run the unit if it keeps overloading or you will have a bigger problem.
Dec 27, 2009 | Technics SC-DV290 System
Technics hi fi
The audio amplifier IC damaged
May 09, 2009 | Technics SC-DV290 System
Technics DVD Stereo SC-DV290
never done this myself, but I would guess you take phono jacks from your TV (L & R out) and plug them into the back of the sound processor, iether VDP(AUX) or VCR(EXT) IN
then go to your remote and press (vcr(ext)/vdp(aux) repeat pressing until you hear you tv
each time you press button it should go through a selector menu
TUNER->DVD->TAPE>VCR(EXT)->VDP(AUX)
hope this helps
Feb 02, 2009 | Technics SC-DV290 System
Pdf Download for Technics SH-DV 290 Hi Fi Instructions Manual
The number of the system is actually SC-DV290 the number you gave is actually the reg number of one of the component parts. To download the full user manual, go here ........ http://www.panasonic.co.uk/html/en_GB/Support/Downloads/220239/index.html#anker_220239 .... In the box " Enter model number, if known", enter SC-DV290 and press "search". Agree to the terms and view / download the manual. Hope this helps.
Sep 13, 2008 | Technics SC-DV290 System
Technics ho2 no play error
u need a new motor in yr dvd player i had same problem so had new motor fitted cost 50 pound works now
Sep 20, 2007 | Technics SC-DV290 System
Technics SC-DV290 System Logo
251 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Morne Olivier
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
