Question about Samsung RESF3330D Electric Kitchen Range
I have samsung ceramic top range and the inner burner is not working on the main multi burner. Do you know how to fix it.
    New Friend:
Well, after only a year, my front right burner was on all the way and wouldn't lower. Samsung repaired the rheostat. Three months later, the left burner is doing the same thing. This time off warranty, even though the bill says '5 year warranty on parts.' No dice. So we may have to junk this stove. Anyone know better ones?
Posted on Dec 03, 2013
5 Suggested Answers
ginko
  • 19396 Answers
SOURCE: replace ceramic glass top maytag eletric range
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 01, 2009
jsrock516
  • 5911 Answers
SOURCE: Gemini Range Dual Burner
Unfortunately, you cannot repair one element of a dual burner. It all comes as one unit. When one portion of a dual or triple element goes bad, you must replace the whole element. I believe the part number is 1032746 and runs about $70. You will have to lift the glass top to access the burner elements. If you decide to pursue this on your own follow these steps: 1. Unplug range and/or turn off main breaker. 2. Open oven door to access screws under front edge of cooktop. Remove two screws and the top should tilt up. 3. The top will not stay up on it's own, so you will need some assistance holding it up. Some ranges have a couple of disconnect plugs that you can unplug, so you remove the entire top and lay it somewhere to work on. If this is the case with yours (as I suspect it is), lay some soft towels down on the kitchen table or counter top and lay the cooktop upside down. This will make it much easier to work on. 4. Remove affected element by disconnecting the wires first. You may want to write down how they came off, so you can be sure to reconnect them in the right order. 5. Remove mounting brackets holding element in place. Pay particular attention to the numbering scheme on the bottom of the element and where the brackets are mounted. The new element usually doesn't come with new brackets which means you have to take the brackets off the old element and put them on the new element. Make sure you install them in the same numbered holes as they were located before. 6. Reconnect wires and reinstall cooktop, making sure you reconnect the disconnect plugs if equipped. Now, be careful when working on the cooktop while it is upside down. Make sure you don't apply too much pressure on the glass or you could crack it. Also, use extreme care NOT to touch the element surface as the oils from you hands can cause hot spots and effectively ruin it. The bake light material in which the element is mounted is also very fragile. DO NOT put to much pressure on it or it may crack and break. Once you get the cooktop reinstalled and power reapplied, op test it to make sure BOTH elements are working. It is normal to see a little bit of sparking at first with new elements and/or an odor. Test the entire range of the element and make sure it regulates like it should. I hope this helps you.
Posted on Aug 04, 2007
  • 184 Answers
SOURCE: No power on right hand side burners
WHEN THE SURFACE SWITCHES ARE IN A ROW ON THE CONSOLE, THEY ARE USUALLY WIRED IN PARALLEL FOR THE INPUT VOLTAGES(RED AND BLACK WIRES ATTACHED TO EACH OTHER). IF THERE IS A BURN OUT OF ONE OF THE WIRES, IT WILL AFFECT THE OTHER SWITCH INPUTS DOWN THE LINE.
TAKE OFF THE BACK PANEL OF THE CONSOLE AFTER UNPLUGGING IT AND CHECK FOR VISIBLE SIGNS OF WIRES BURNT. REPAIR OR REPLACE IF NEEDED. SOMETIMES, THEY WILL DAMAGE THE TERMINAL OF THE SWITCH THEY ARE ATTACHED TO. IF THIS IS THE CASE, THE SWITCH WILL ALSO HAVE TO BE REPLACED.
Posted on Apr 04, 2008
jsrock516
  • 5911 Answers
SOURCE: How do I change the element on a Whirlpool Gold range?
If you have replaced the dual element with a new one, and have verified that you have the wiring installed correctly, it may be the infinite switch that controls the element that is bad. That would be the switch behind the control knob for the element in question.
Posted on Sep 19, 2008
A burner on my ceramic stove top doesn't work
Without the brand and model number, it is difficult to answer your question. There should be a reference number somewhere in your stove top. That would be your starting point, and from there, seek the needed info using the model number and make. Try a new ceramic burner assembly at that location....it's plug and play.
Jan 08, 2015 | Kitchen Ranges
Spectra GE model JBP64W0B4WW stove top burner stopped working
Which element is it? Try to switch the infinite switch from another element. This will tell you if it is the element or the switch problem.
Apr 06, 2013 | GE Spectra JBP78 Electric Kitchen Range
Kenmore 79096011407 ceramic cook top. When front left burner is turned on, it goes to high and does not turn off. Had to use main breaker panel to turn off electric to the range. Can not find parts list...
Sounds like the switch for that burner needs to be replaced. Its possible that something else may be shorting out but usually its just the switch. Your ranges burners and switches are standard switches and burners for this type of range so the switch should fix it. Hope that helps.
Aug 29, 2011 | Kitchen Ranges
I have a kenmore ceramic top electric stove and one of the burners quit getting hot. what could be the problem
It is a kenmore glass top stove about18 years old. One of the burners stop working just wondering if I can fix it myself?
Aug 06, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
Range Ceramic Cooktop 1 burner not working
I would try replacing switch for that burner. But it also could be a defective burner.
Oct 20, 2017 | KitchenAid Kitchen Ranges
Element on ceramic Frigidaire Gallery cooktop won't go off.
take knob off and check the middle is not split and hence not turning the shaft
Nov 20, 2008 | Frigidaire Cooktops
Left Side of range top won't work
it is either the wiring to the switch the main terminal block or the switch that is bad have to look and see or call a different servicer
May 13, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Ceramic/glass top stove
Lift the ceramic top and look at the burnner to see if it is bad or not.
You only have to take 2 screws in the front of the ceramic top at the bottom, just open the oven door and look at the corners.
Don't forget to unplug the stove first
May 09, 2008 | Kitchen Ranges
Model JBP79 FFFcode
FFF Control Error, Failed EEPROM Replace Control
Unfortunately when you get this code the oven control will need to be replaced.
Nov 12, 2007 | GE Profile Spectra JBP95 Electric Kitchen...
Samsung RESF3330D Electric Kitchen Range Logo
234 people viewed this question
Top Samsung Kitchen Ranges Experts
Oloyede Monsuru
Are you a Samsung Kitchen Range Expert? Answer questions, earn points and help others
