Question about Canon imageRUNNER 5020i Copier
Check toner level
Who to check toner level
  • 231 Answers
RTFM
Read the operators manual
You should be able to replenish the toner yourself.
Posted on Dec 09, 2009
How do I get a toner coverage report from a Sharp 2610C?
How do I monitor toner levels in my Sharp copier or MFP? You can monitor the toner levels in your Sharp copier or MFP by pressing and holding down the COPY function key . Two pieces of information will then be displayed.
The Total Copy count on the device
and
The remaining toner levels. This will be shown in 25% increments. When you get down to 25% capacity check to see if you have spare toner on hand. If not, give us a call and we will promptly deliver.
How do monitor toner levels in my Sharp copier or MFP
check out the user manual too:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=8&ved=0ahUKEwja6dWd9fLMAhXGlx4KHegRC24QFghIMAc&url=http%3A%2F%2Fwww.wisconsinimaging.com%2Fdownloads%2Fmx3610nManual.pdf&usg=AFQjCNEyIj_mysubFXRIlvDoqEKBw3L4zQ&sig2=0jtdA8-CGBc2ej3tWvEdHg
it stated
To view the approximate amount of toner remaining, continually touch the [Home Screen] key ....
May 24, 2016 | Sharp Office Equipment & Supplies
What is code F2-40in a MX-M264N Copier?
F2-40 = ATC sensor abnormality ,
your toner is depleted , or is unable to replenish toner level in developer after X amount of time . a simple crop 14 should clear the error , but if it persists then you have bigger issues , try to check developer unit gears if they still function as they should, and check your toner level, and check your toner motor,
and if all is said and done try another toner cartridge, but be aware that the F2-40 usually fries the chip on the toner cartridge (not always though)
Jan 22, 2015 | Sharp MX-M264N Copier: MX264N : M264N
Can you reset toner level in Xerox DocuColor 260?
Usualy what i did i use toner chip (100%) fix it to toner cartridge then insert to machine, check the amount if 100% then pull out the toner cartridge and replace old chip insert back to the machine, check it will be 75%.
Sep 05, 2014 | Xerox DocuColor 242-252-260 PS
0F54H Fatal Error
Witam,
An error occurs on the toner level sensor for each color:
0F52H Toner level sensor /Y malfunction
0F53H Toner level sensor /M malfunction
0F54H Toner level sensor /C malfunction
0F55H Toner level sensor /K malfunction
Relevant electrical parts:
Toner level sensor/Y (PS13)
Toner level sensor/M (PS14)
Toner level sensor/C (PS15)
Toner level sensor/K (PS16)
Printer control board (PRCB)
Step Action:
1 Check the connector between each sensor- PRCB PJ21 for proper connection and correct as necessary.
2 Replace the toner level sensor of the corresponding color.
3 Change PRCB.
Feb 11, 2014 | Konica Minolta Magicolor 3730 Dn Color...
Replaced black toner..now printer won't print any
In this case, actually it is not the Black toner that got depleted. Here the message being displayed indicate that one of the color Toner supply need to be replaced as it got depleted and currently the printer is printing in Black and white using the Black toner cartridge.
in this case, to troubleshoot these issues please try performing the following and check for the results.
* 1. Check for the level of the toner cartridges:
a) Check from the HP Toolbox application. Here are the steps to be performed from your PC:
* Access the Toolbox software.
* Select the Status tab.
* Select the Device status option.
Here you can check for the supplies status in terms of the % remaining for each toner cartridges.
b) By checking the supplies status from the printer control panel display.
On the printer display when printer is in Ready mode the supplies status can be checked from the supplies level indicator. Each toner cartridge and the Imaging drum level will be indicated by a bar which varies according to the level of the supplies present.
c) Print the supplies status page from the printer.
* On the printer control panel menu, press Menu .
* Use the (Right Arrow) button to select Reports, and then press Enter .
* Use the (Right Arrow) button to select Supplies Status, and then press Enter .
If any of the color toner cartridges and the Imaging drum have a low supply level replace them with genuine HP print cartridges.
The part numbers of the consumables are as follows:
* Black print cartridge - Q3960A
* Cyan print cartridge - Q3971A
* Magenta print cartridge - Q3973A
* Yellow print cartridge - Q3972A
* Imaging Drum - Q3964A
Sep 23, 2009 | HP LaserJet 2840 Printer
Ir 3570 error e000024-0000
E024 The developing assembly connector is disconnected/Disconnection of Toner sensor.
0000 The connection detection signal is absent
continuously for 100 msec. Replace the developing assembly toner sensor. Connect the connector. Replace the DC controller
PCB.
0001 Disconnection of the wire used for detecting the
connection of the toner level sensor is found.
When the disconnection of the wire used for
detecting the connection of the toner level sensor
has been detected for 7.5 min without
interruption (12.5 min in the manual /envelop
cassette feeding).
has been detected for 12.5 min without
interruption.
-iR4570/3570/3530
cassette feeding).
-iR2870/2270/2230
interruption.
Correct the cable. Replace the sensor.
TRY THIS:
Remove toner and check for broken parts on tube, check the connection of toner assy, reconect all connectors on dc controller pcb.
If you removed the toner assy before the error occcured check if all connectors are properly inserted.
Jun 15, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Brother MFC-9840CDW - checking toner level
On my APPLE the MAC OS driver depicts the toner levels when I check the printer status under the settings and preferences - printers icon - supply levels is an optional choice. I have not found a way to check the levels on an XP system.
Apr 17, 2009 | Brother MFC-9840CDW Laser Printer
Toner levels
Install Smart Panel monitor for the printer and from the software you can check the toner level.
Check this link if you need any software / drivers / firmware etc....
http://www.samsung.com/us/function/search/resultList.do?searchWord=clp+300
Jul 18, 2008 | Samsung CLP 300 Laser Printer
Add toner led is red
to go to ready status toner level inside must be in optimum level-check toner bottlle many times and apply toner.
Mar 04, 2008 | Kyocera KM-1505 Copier
Canon imageRUNNER 5020i Copier Logo
145 people viewed this question
old marine
old marine
