Question about Hotpoint RGB745 Gas Kitchen Range
Only the two left spark ignitors work. I switch the wires from the left side to the right side and the ignitors worked. The wires from the right side I hooked to the left side and they did not work. Results were that the burner ignitors are working. What next?
    Novelist:
  • 112 Answers
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Posted on Jul 17, 2010
My magic chef rv range will not light the burners with the ignitor. I replaced the ignitor at the control due to the wire prong being broken off. It worked prior to the wire prong breaking off. What do...
hope this helps a little...
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/15-104--/Magic-Chef-Stove-burner-won-t-light
Jan 14, 2018 | Magic Chef Ovens
Turning left front knob to lite position turns on the gas for the left side, but the lighter for right side.
hi ,all ignitors click at the same time.if the left ignitors are not working you probebly have a bad spark modual.also check your wires.
Mar 08, 2010 | Frigidaire FGF316 Gas Kitchen Range
Spark ignitors on ge jgp636 either don't work or lght wrong burnr
Dec 19, 2009 | GE Profile JGP636 Gas Cooktop
Viking vgic3054-b left side burners do not spark right side fine
no to your comment.if all the wires look ok & the module is sparking change the wire from one that is working to the faulty one if still not working it will be the spark electrode in the burner.
Sep 14, 2009 | Viking 31 in. VGSU101 Gas Cooktop
Left side two burns do not ignite
Check the ignitor unit, If the other side works, maybe a wire has come off the ignitor feeding the left side.
Sep 03, 2009 | Thermador Pro Harmony PRG304EH (Gas)...
2005 yamaha royal star venture. Still haven't found the problem with no spark on left rear coil. I replaced the coil, but there still isn't any spark. The wires (orange and black/red have continuity to the...
If you have continuity from the coil to the ignitor, the problem lies within the ignitor. The coils function by having a constant battery voltage on the red/black wire (you'll notice that ALL the coils have a red/black wire) - the primary windings in the coil charge up, until the ignitor "grounds" the colored wire (grey and white in the front, orange and yellow in the rear). As the voltage in the primary winding drops, it creates a strong magnetic field - the magnet (laminated iron) in the center of the coil charges the secondary windings, and the very high voltages generated fire the plug. You've already determined that the voltage on the orange wire is higher than the voltage on the yellow wire; that could only be because the orange wire is not being "grounded" on a recurring basis by the ignitor. (You have to remember that the meter you're testing the leads with cannot react to changes in voltage nearly as quickly as they happen; to really "see" what's happening at the coil, you'd need to use an oscilloscope).
Aug 25, 2009 | 2005 Yamaha Royal Star Venture
Can't get any spark on rear left ignition coil
I didn't notice the year of the bike but
the orange wire comes directly from your TCI ignitor unit.
It might be a faulty pickup coil or the ignitor unit itself.
the pickup coils are in the right engine case and
have about 110 ohms resistance.
If there is no ohms reading on the pickup coil then
it is faulty.
If the pickup pulse coils are good then your
main ignitor unit is probably faulty.
Sometimes the solder joints can crack in them.
Aug 22, 2009 | Yamaha Royal Star Venture Motorcycles
Jenn-Air JDG8430 Ignitor won't stop sparking after burner ignites
Test the ignitor first, if the ignitor does not spark should be the ignitor itself.
Oct 12, 2008 | Jenn-Air 30 in. JGD8430A Gas Cooktop
Replace burner spark ignitor?
Electric igniters are usually very simple installs since they usually only come with a common and hot wire, and the igniter clips on to the burners right near the burner top for ignition. The easiest way a DIYer can do this themselves is to slowly take apart the current ignitor after lifting the top of the range up and taking note of every thing's placement. If you have the direct OEM part, then it either work or will not, based upon the fact that it's either the ignitor or the switch for it that has gone bad.
To test if your igniter has gone bad, remove it completely. (it should only be a small cylinder with two prongs, and two wires coming out the other side) Be sure not to strip any screws as heat from the oven will make them hard to remove. From there, you'll need to jump the connection on the top of the igniter with a conducting piece (ie: aluminum foil or wire), then test the common/hot wires with your circuit tester or volt meter. A solid tone or light means that your igniter is good, and the problem lies somewhere else.
Feb 29, 2008 | KitchenAid KGST307 Gas Kitchen Range
Hotpoint RGB745 Gas Kitchen Range Logo
225 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
