10 yr old Kenmore 70 series top load washer
Last night I put a medium load in the wash and went downstrairs. A few minutes later I noticed a water dripping sound and ran up to the washroom that was flooded with water. The washer was still filling up and water was spilling over the top. I cleaned up and started again and had no problem. What could cause this?
  • 447 Answers
Sounds like either the water level sensor (called a pressure switch ) is malfunctioning or there is a mechanical problem with the switch meaning that the tube that goes from the switch is
a) Kinked or crushed
b) has a small hole
c) Has become clogged
d) Air dome (where tube goes to on outer tub) is clogged
Posted on Jan 19, 2008
6ya staff
SOURCE:
70 series top loading washer
probably no parts for a machine that old
consider getting a new unit that is more power and water efficient
Jun 25, 2017 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore 70 series. I just replace the door switch The machine was working and it agitated just fine. It was not draining though, but I could hear the water pupmp working just no water. A minute...
Them capacitors do die. I replaced one just last week:
Tip go by the micro farads and you can get one cheaper than buying the OEM. I paid $3
I have a dedicated page from lid switch to transmission on
your machine with videos and service manuals HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 09, 2011 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series slow agitator
You have burned the clutch this must be replaced
Jun 09, 2009 | Kenmore 15864/15862 Top Load Washer
Kenmore 70 series top loader washer machine smells like its burni
you had the clutch coupling replaced sometimes i have noticed that the smell will last a few loads but no more than that
Apr 22, 2009 | Washing Machines
During washing the kenmore 70 series washer squeals
Re-check the motor coupler.
If it was not seated flush on both post it will bind and squeal.
Feb 21, 2009 | Kenmore 22422 Top Load Washer
Slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
Dec 30, 2008 | Kenmore 22422 Top Load Washer
Kenmore 70 series will not drain or spin
It sounds like the lid switch. If it ws the coupler the water would drain. Check to see if the lid switch is clicking when you put the lid down. replace the lid switch. You have a great washer. Fairly cheap fix.
Nov 20, 2008 | Kenmore 20722
Kemore 70 series
Its possible that your trans. is going to need replaced. Maybe have some bad seals on the trans. As far as the water leak goes. Could be a tub seal, maybe some worn inlet hoses, maybe a leaky inlet valve.
We hope this gives you a start on your appliance repair. Anymore questions please feel free to reply back.
Mar 26, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
166 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
