Question about Toshiba E-STUDIO 450 Copier
I have an estudio 450, the call for service lite is on. i turn it off then back on and it clears, i try to copy and i have the attached carriage on the left side that staples, sorts and it has to grey trays that the copies print out on. the trays activate and the bottom tray starts moving up until it hits the upper tray and they starts making a clicking noise then the copier stops and the call for service warning comes on.
  • 3,741 Answers
remove the trays as well as other removable parts.as any of the tray part getting blocked by any other foreign object or any piece of paper or metal object or the tray is got cracked or any of the gears are got worn out.mostly removing all the parts and resetting solves this problems.but in some cases the service executive has to be called because its a actualpart getting cracked problem.try resetting first. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Dec 09, 2009
How to reset error copier mechine estudio 2006
The Toshiba eStudio 350/450 copier is one of the more popular copiers available in the marketplace. It has several features that make copying, printing and faxing easier, such as password protection and customizable settings. There are times, however, when a lost password must be recovered. Toshiba has provided a simple method to recover the password and, if need be, reset the copier settings.
By Daniel Valladares
Resetting a copier to its original settings is a simple way to fix several problems.
Step Make sure the machine is off. While holding down the "0" and "8" buttons on the keypad, turn the copier back on. Keep holding the "0"' and "8" buttons until the copier lets out a long beep. This will activate "Test Mode D."
Step Type in '263' on the keypad and press the green start button. The password should now show up on the copier's screen. At this point, you can type in a new password if you choose to do so.
Step Press 'Set' to set the new password. Turn the machine off, wait fifteen seconds, and then turn it back on.
Step Go to the functions you wish to reset through the main menu and press "Function Clear." If prompted, type in the password. Repeat for any function you wish to reset.
Oct 11, 2017 | Office Equipment & Supplies
Estudio 450 admin password
Go to 08 mode. Enter 263 and press START. It will show the current password. To change press C to clear and enter the new password.
Oct 24, 2012 | Toshiba E-STUDIO 450 Copier
Remove hard drive from estudio 450
Pull off the back cover, then the metal cover that has the two wire fan plug going in to it. The hard drive is under there.
TOSHIBA PARTS AND SUPPLIES
Sep 04, 2012 | Toshiba Office Equipment & Supplies
Forgot password toshiba estudio 450
The default password is either 12345 or 123456.
If neither of those work then, turn machine off then power on while pressing the 0 & 8 keys then enter 263, then press Start. It will then display the Admin Password.
Oct 23, 2009 | Toshiba Estudio 200L Copier
We have forgotten the Administration password for our EStudio 350 & 450. Is there any way of resetting? Thanks Ben
restart machine ,then press the 0 & 8 keys,enter 263, then press Start. You should see admin password on the screen.
May 05, 2009 | Toshiba Estudio 200L Copier
E studio 202L copier won't copy unless interrupt button is lit
Sounds as if when your hitting the interupt button you are interupting a copy job the machine "thinks" it is doing, try clearing the print que on the copier.
Apr 13, 2009 | Toshiba Estudio 200L Copier
48 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
