Question about Sharp FO 6600 Plain Paper Laser Fax
We are getting a lot of COM. E-31 errors on
All of a sudden we are getting a lot of COM. E-31 errors on incoming faxes. Any ideas? Sharp FO-6600 SuperG3 DualLine.
Thanks for any input!
Pascale
  • 622 Answers
Plug out your fax and plug in a regular phone in to the line and dial your cell... if you can talk for 2 minutes with no distortion or noise on the line then all is well... if you cann't get through you have a problem...
connect your fax and call multiple fax machines... if you have the same error with multiple fax machines then your fax or your phone line is the problem...
change the fax cable... if you are getting the same error.... call your cell from the fax... if you can get the voice mail... your fax is ok... and the phone line is ok... the guy on the other end has a problem...
if the guy on the other end always has a problem and you can dial out and get your cell... connect another fax that you know works and try all these tests...
if it has the same problem then its your fax line call call the phone company
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Posted on Dec 09, 2009
Fo-2081
I am a tech that Services Sharp. Enter simulation mode using # * c * after you are in run test command 66-10 This problem happens from you getting a bad fax mostly from noise or interference to the line. if it happens a lot to you then try getting a power filter with network and fax ports.
I’m happy to help further over the phone at https://www.6ya.com/expert/ethan_e84416e0b13809d2
Dec 13, 2013 | Sharp FO-2081 Copier
Sharp FO-2081 clear memory error
I service Sharps for a living.
Jan 17, 2013 | Sharp FO-2081 Copier
Sharp FO-3150 polygon error
You have a bad laser unit that can't be replaced.
Jan 16, 2010 | Sharp FO 2950M Plain Paper Laser Fax
I need to change the company's name on the printout page when someone receives it.
The 6600 opeations are very similar to the 6700. Go to the Sharp site at
http://www.sharpusa.com/products/TypeManuals/0,1083,23,00.html
download the FO-6700 manual, follow the instructions for setting the sender name and phone number beginning on page 29 of the manual.
Please make sure to rate this solution.
May 15, 2009 | Sharp FO 6600 Plain Paper Laser Fax
Sharp fo 4700 display error ( polygon )
You have a bad printhead unit(laser unit) . The polygon mirror is not rotating within a specific amount of time. I recommend you to replace your fax unless your willing to spend between 200 to 500 dollars.
May 03, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Sharp FO5700
I have never seen this error code on a sharp FO 5700 are you sure that is the right model # or error code. I even did a search in the FO5700 service manual(no luck). I believe I have seen this code before on a sharp copier.
Sep 05, 2008 | Sharp FO 5700 Plain Paper Laser Fax
Ask a model
<a href="http://www.fajrshahab.com">www.fajrshahab.com</a>
Apr 01, 2008 | Sharp FO 6600 Plain Paper Laser Fax
The document feeder keeps trying to feed
You have a bad Document transfer sensor. Sensor is located under the doc. transfer roller.
Nov 15, 2006 | Sharp FO 6600 Plain Paper Laser Fax
Sharp FO 6600 Plain Paper Laser Fax Logo
215 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
