Question about Sony Ericsson K850i Mobile Phone
My daughters phone, when switched on just flashes its keypad lights intermittantly and will not go any further than that. any advice would be gratefully received.
How do i fix keypad
Keypads will flash when new oven or when disconnected and setting are lost. First try setting the clock
  • push CLOCK--enter numbers--push CLOCK to see if keypad becomes operational.
If not, unplug, replug and try again. As for "fixing" keypad ....that is not likely to be the problem and even it it were, keypads are not user repairable. For further info, dial the the factory customer support phone number.
Mar 14, 2015 | Microwave Ovens
Panasonic th-42pw6 plasma TV switches itself off intermittently
i think the power ic needs a replacement.
the possition is ic551 and is named strf6668
Apr 06, 2010 | Televison & Video
Nokia 6670 menu key is not working
keypad not working might be caused by:
the phone keypad is dirty,
or
the I C that control the keypad on the board of the phone is bad.
To check if the keypad is dirty, detach the front casing of the phone where the keypad is, clean with brush or a white cloth to clean of necessary dirt of the phone, then couple it back and test.
If after cleaning the keypad and is still not working, then the key pad I C on the phone board is damaged and it needs to be replaced.
Would advice if you to have the knowledge on how to open the phone, you can take it to a phone repairer to fix for you to prevent further damage on the phone.
Have a nice day.
Mar 23, 2010 | Nokia 6670 Cellular Phone
I have a nokia 6500s-1 slide phone and my 3 yr old daughter pressed something while she had it, and now i'm locked out of the phone, tried all I can to no avail. Can't give you an IMEI number as the phone...
It seems that the keypad is locked. Does your poweron? If yes then press the poweron switch and you will find an option LOCK KEYPAD or UNLOCK KEYPAD. If it is the earlier then your keypad is free. If the later then select Unlock option and free up your keypad. If former then your there is no way that you can unlock your phone except re-installing the firmware. The IMEI number is below the battery. But, it will not help despite everyone asking for a SW generated password. get the firmware re-installed. It takes about half an hour.
Aug 12, 2009 | Cell Phones
W700i wont switch on--battery fine
it can be software problem, flash u mobile .
Jun 21, 2009 | Sony Ericsson Walkman® W880i Cellular...
Oil light flashes when I accelerate
i would say your oil level might be low enough to flow away from oil pressure switch . I would the oil and filter ASAP changed, and road test to evaluaite further
Apr 03, 2009 | 1996 Toyota Camry
Need to change keypad access code for Sears garage door opener
To change the code, you need to hit the LEARN button the back of your machine. You will see a yellow light flash. Enter a 4 digit code on the keypad and press enter. The lights on the opener should flash and you should hear a click. Your keypad is programmed.
Feb 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Motorola RAZR V3 keypad works but won't light up
just take the phone to a mobile center and have them replace the flexcable on the phone.
Jun 26, 2008 | Motorola Mobility RAZR V3
Sony Ericsson K850i  Mobile Phone Logo
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
