Question about Whirlpool 21.8 cu. ft. Side-By-Side Refrigerator with EZ-Change Ice and Water Filter
Remove the water filter
I can not remove the water filter. Help, any advice?
  • mclen005 Sep 01, 2008
    I have removed the grill and still can't get the water filter to budge. what else can I do?
  • 447 Answers
Yes if it is the filter that is located where the bottom grill is..... It rotates 1/4 trun counter clockwise. If you cant seem to break it loose try removing the grill by pulling it towards you (it clips on) take not of the tabs on the grill and the clips on either side of the fridge. Now you can get a better grip. Also its a good time to look and see how dirty coil is under refrig.
Posted on Jan 19, 2008
6ya staff
SOURCE:
Dishwasher spray arms don't spin & spray water
Check that the water pumped on arms has enough pressure.
Aug 15, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
My filter is buzzing but no water is going through
I have this issue with my filter when I unplug it. Occasionally, I can hit the side of it a few times and it will work. The issue is that something is blocking the inside and preventing the impeller blades from spinning freely.
To fix the issue I usually do three things:
  1. I remove the bottom pipe from my filter and tap it on the ground to free the blockage.
  2. I also run water from my sink through it to clean it out.
  3. Lastly, I use Q-tips to try to get in there and remove the gunk (I have a small filter).
Time Spent? I have spent anywhere from 5 minutes to an 1 hour cleaning out the filter with the above techniques.
Advice: Change your filter cartridge every 2 weeks or when it's covered. Don't unplug it if you can help it!
Best of Luck!
Jan 06, 2013 | Aqueon Mini Bow 5 Gallon Aquarium Starter...
My kenmore fronload washer will not spin out water from cycle. when I opened the door after wash close were soaked and water in maching.
Not knowing the model of your machine, I can provide some generic advice. Please add a comment to this thread if you need more help. This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. While it's trying to get the water evacuated, you will probably see the machine doing a slow tumble for up to 8 minutes and you may also hear the empty pump running too.
You need to locate and clean the filter. Depending on the model there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom) Many models of this design also have a small hose to the left of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked.
Jul 22, 2011 | Kenmore Washing Machines
GE Fridge - The water filter bypass plug is stuck
Should just take a quarter turn CCW to remove. You may loose a few drips of water, but the water shuts off automatically when the plug or a filter is removed. A wrench should not be needed to do this.
Jul 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dripping
Turn the water off at supply valve, this will stop the water. Then you will need to replace the fill valves on the washer.
Jul 05, 2010 | Kenmore 24032\24036 Top Load Washer
KitchenAid KUDP01DLWH6 dishwasher filter clog
Follow the main water supply line. It goes to a solenoid valve which is normally located front left side under the dishwasher.
1. Turn off the main circuit breaker for the dishwasher.
2. Turn off Water supply to the dishwasher.
3. Remove lower front panel.
4. Remove Water supply line from solenoid.
5. remover wire connections from solenoid.
6. Remove 2 mounting screws from solenoid.
7. Take solenoid valve out.
8. Look inside the valve where the water supply line was connect to, You will be able to see the filter. it is just a screen and you can easily clean it.
Good Luck
Jun 27, 2009 | KitchenAid 24 in. KUDP01DL Built-in...
Hello, i have an Indesit WIXE127 showing error code FO7. Any help/advice appreciated.
F05 is where the pressure switch has not reset within 10 minutes of emptying on any part of the cycle. Basically this means the pump is not pumping the water out. This could be a blocked filter (located on front of machine at bottom behind the kickstrip). Be careful when removing the filter as it unscrews anticlockwise and if the is water in the drum then tilt the appliance back at 45 degrees and put a large bowl underneath to catch the water. If the filter does not unscrew then theres definitley something in the filter. When the filter is out put your finger inside to rotate the impellor. This should spin freely. If this does not solve your problem check for blockages where the grey drain hose connects to the sink (it could be blocked there).
Apr 17, 2009 | Washing Machines
Location of eject button for water filter
For more information or advice regarding water filters visit www.h2ofiltercentre.com it’s the best place I know to find affordable water filters and advice in the UK.
Call 01273 74 74 77
Jan 14, 2009 | KitchenAid Superba Architect KSCS25INSS...
Washer J14535 comes up with 4E error but there is no problem with the water feed all filters are clean and wastpipe is not blocked any advice?
there is problem with inbuilt water filter which is get choked,which is located inside water valve where inlet pipe attaches.remove inlet pipe from inlet valve by hand,remove filter inside the valve clean & refix it check the pressure in detergent box
Jun 01, 2008 | Samsung Washing Machines
Whirlpool 21.8 cu. ft. Side-By-Side Refrigerator with EZ-Change Ice and Water Filter Logo
196 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Bruce Denton
Norman Worley
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
