Question about Microsoft Xbox 360 Console
Disc tray does not stay in it keeps openind and shuting every time i plug it in
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 99 Answers
Might be that you have a modded xbox, and the firmware is messed up, or your disc reader is messed up. Contact microsoft asap. (1-800-4MY-XBOX)
Posted on Dec 10, 2009
My nokia c3-01's keypad keeps freezing and
If it is the flip top ph I opened mine very carefully and find that after time opening and shuting them the wee computer plug comes aprt from the flip part... it is like a male and female plug I couldn't bleve thats all it was after mths of it playing up then stop'n all together it sat in the draw for nearly a year be4,
I pulled it apart and find the problem its from opening and close'n the ph just open it and plug it careflly back in
May 04, 2013 | Cell Phones
Water Shute freezing up in ice maker
freezer maybe turnedup to high ck manufacturing recommendations
Feb 06, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Panasonic SA-PT460 disc tray keeps opening. When system switched on disc tray opens, then closes and then opens and stays open. can't play a disc.
SA-PT460
Original fault tray would not stay closed,opened up 460 case and then removed 2 screws on rear of drive. unplug 2 ribbon cables.
unscrew 1 screw in micro switch pcb rotate and spay cleaner into switch and rock switch several times until the reading across switch is 0 ohms before you start you will find the switch has about 2.5 k of resistance across it witch is too high.
as long as you have about 4ohms it will work.
Aug 14, 2011 | Audio Players & Recorders
Tray closed, but keeps saying tray open
You are having tray sticking problems, you can solve this temporarily by keeping a disc in the tray at all times, even when the console is off or you can give the console a gentle pat close to the front part where the disc tray is, not advisable though because the 360 already has SMD dry joint problems, do this occasionally, try and remove dust also around the grooves under the disc tray, hope this helps
Oct 25, 2010 | Microsoft Xbox 360 Console
DMR-EZ48V- DVD drive not working
Check Panasonic.com for Firmware updates. If it has a reset button reset it. Take off the cover remove dust and lint, also clean laser eye with rubbing alcohol. DO NOT LOOK DIRECTLY AT THE LASER LENS IF YOU PLUG IT IN, DURING THE OPERATION.
Sep 10, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
My computer keep shuting saying monitor going to
start button >settings >control panel > Power Option > set time for monitor to sleep if inactive...if you dont want the computer to sleep go up to the hibernate tab and uncheck it. If you want the computer to stay on regardless, move all drop down menus to "never" instead of a time.
Sep 01, 2009 | HP w1907 LCD Monitor
Disc tray???
Did you recently open the ps2/modify it?
Found this which may help (and will void your warrenty):
When you take the top cover off of the PS2, you can see where the Reset/Eject ribbon cable plugs into the system itself. Right next to and slightly below here are three wires with three tiny color-coded plug-ins attached. They are just pressed into place and have a tendency to work themselves out over time. And depending on which one came undone, the disc tray will either always want to stay closed or always want to stay open. Either way, the operation of the disc tray will be erratic and problematic.
So it's a matter of using a pair of needle-nosed pliers to grasp and make sure that all three of these tiny plug-ins are fully inserted into the slots where they belong. Sometimes it's even necessary to very slightly lift the PS2 out of the bottom half of it's shell to gain better access to them. After they're all clearly in place, then it's a good idea to use the same needle-nosed pliers to make sure that the ribbon cable did not slightly pull out of place from where it is plugged in as well, or the Reset/Eject buttons will not work.
After all this, you can put the PS2 back together and voila...you should be good to go!
Sep 06, 2008 | Sony PlayStation 2 (PS2) Console
Disc tray problems
Redeem your warranty, this issue happens with the tray is going bad, first this small problem next reading problems
May 19, 2008 | Microsoft Xbox 360 Console
Disc Tray Won't Open
I have contacted Venturer Electronics Inc. (which have recently purchased RCA); they are in Toronto, Ontario. They suggested to perform a Manufacturer Reset (as follows); and if it works; system should power up [this means there was a glitch in the software]...(this usually happens when system is plugged into a power bar or surge protector) if not, contact them @ 1-800-721-4007. They honor the manufacturer's (RCA) 1 year warranty... with receipt.
To reset Unit:
Unplug Unit from AC power (other wires can stay connected)
Press the On/Standby button in front of Unit 15 times
Wait 30 minutes
Replug Unit to AC power
Press the On/Standby button to power up unit
Wait couple of minutes for unit to do its thing
**If unit works properly, then ensure not to plug unit into power bar or surge protector, keep plugged into wall.
**If unit will not power up properly, contact them for further instructions.
Hope this is helpful....
My Unit powered up wonderfully and is currenlty working like a charm.
Dec 29, 2007 | RCA RTD258 System
Microsoft Xbox 360 Console Logo
21 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
