Intermittent headphone jack
I have a Delphi xm2go satelite radio. The headphone jack is intermittent. The sound will come and go as I touch the jack. It works the same with several headphhones so I know it is the radio and not the headphone. How can I get the radio repaired?
  • 509 Answers
Cheap and dirty way to fix it is to buy a 'headphone splitter' and plug it into the radio; when you get it 'just right" superglue it and hold it in position. Then you can use the two other plugs for your headphones until those two wear out. Ugly, but efficient way to fix it without tearing apart the radio, which has surface mount parts and is very difficult to solder to.
Posted on Jan 27, 2010
SOURCE:
The radio will not turn on ,not manually and not with remote
power suplay Transformer dies...
Try to find another suitable transformer and try running it
Nov 24, 2013 | Delphi Myfi Xm2go Portable Satellite Radio...
My delphi myfi xm2go will not recharge. What do I
New battery - make sure it's WHITE and not a black one as the black ones were recalled.
Nov 21, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
HP Mini 1033CL intermittent or no sound
Probably something was touching the speaker cone and you snapped the speaker back so it no longer touches.
Oct 22, 2009 | HP Mini 1033CL Netbook
ITouch 2nd g only plays music throuhg left side of all headphones
Try playing with the headphone plug, until you can also hear the right
channel and also try a different set of headphones as it is probably a
matter of an intermittent headphone jack, or plug, owing to sudden
snatching of the headphone plug from same, a very common problem.
Eliminate this cause before submitting your Touch for much more
expensive remedies
Apr 16, 2009 | Apple iPod touch
Intermittent audio...picture fine
Does this model have a headphone jack? If so, plug a pair of headphones or external speaker into the jack, turn the volume to an acceptable listening level and see if the problem goes away. If so, the headphone jack may be bad.
Mar 02, 2009 | RCA E09344 Under Counter Kitchen TV 9"...
Static sound or no sound with FM Trans and with Audio Plug
I agree with you. It sounds like an internal audio circuit problem, especially if the tape adapter does the same thing. Have you tries headphones on the unit? If they work, then get the sure connect as it plugs into the headphone jack (Aux out jack)
By the way, you as an XM customer for years, usually XM will just give you another unit to keep you as a customer. I've seen it many times. Couldn't hurt to ask!
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 23, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
XM2GO remote doesn't work
hi i have same radio try turning the radio off and taking the battery out for a minute or so and putting it back and turning it back on worked for me
Nov 27, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
My tao xm2go will not turn on
Dear Glen,
My Tao solution is to buy the Delphi MyFi which appears to have an identical interface. See page 10 here: http://file.xm411.com/manuals/MyFiUserGuide411.pdf . This is expensive but service in not available.
digitally,
(/\/\<erwin
Nov 21, 2008 | Tao XM2go Satellite Radio Receiver
Atenna connection when using Altec Speaker or Car Kit
Dear xm2go,
I could not find any service options for my own Tao XM2go unit. The only option appears to be the Delphi MyFi unit which appears to be identical (see page 10 here: http://file.xm411.com/manuals/MyFiUserGuide411.pdf )
digitally,
(/\/\<erwin
Oct 07, 2008 | Tao XM2go Satellite Radio Receiver
125 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
