Question about Craftsman Air Tools & Compressors
I have a 3hp 20gal sears craftsman air compressor. that starts pumping, but when it gets up to 40pounds it blows a breaker and then the motor just hums when i start it back up. but if i disconect the belt the motor will run all day.
    New Friend:
    Problem Solver:
  • 6 Answers
Don't forget the off--loader. If the pressure on the head is not relieved, it will not be able to restart.
Posted on Apr 07, 2010
    Scholar:
  • 169 Answers
Here is the trick, you have to figure out if there is something wrong with the pump or the motor, yes the motor may still run without the belt on it just fine, but there is also no load being applied either. if the pump seems to roll over ok by hand, I would have the motor checked out by a motor shop, could be that the start switch or capacitor is at fault. once the motor checks out thenlook into the pump.
Posted on Dec 09, 2009
SOURCE:
Sears troubleshooting
Sounds like motor is frozen; it happens. Most likely its bad brushes and/or commutator. It will be cheaper to buy new motor or compressor.
Jul 30, 2014 | Craftsman 25 gal Air Compressor 3 12 hp...
I have a model #919.167200 5hp, 20gal. air compressor. It has been working great for years, but when I went to turn it on today it blew the breaker. I pulled cover and cleaned contacts on pressure switch,...
Hi dtsorrell...
If your somewhat of a mechanic/electrician then you can by-pass the pressure switch by hooking the color coded motor wires together with the incoming color coded wires from your power cord in the proper order.
Plug it in and then check to see if it blows the breaker again, if it does then it is your motor that is faulty.
Please take time to rate me.
Jul 28, 2011 | Craftsman 15 gal Air Compressor 3 hp UMC...
Compressor fills air tank and when it cycle to refill tank it kicks a 20 amp dedicated circuit breaker. Sears looked at it twice and said it is OK. Changed breaker with new one because Sears said it...
try this. When compressor shuts off. TURN OFF POWER. then spin the compressor backwards or forwards until it is off the compression stroke. Turn unit back on. If it doesn't blow the breaker, then it is worth looking into the type of compressor (pump) you have. Many have a "reed valve" and that might be failing, holding the compressor itself under load when it shuts off so that on restart it is under heavy load and the motor draws too many amps to get it started hence blowing the breaker anyway hope this helps
Feb 17, 2011 | Craftsman 25 gal Air Compressor 3 12 hp...
I have an 80 gal Craftsman air compressor who just shut down, the pressure is dropping, it made a smoke smell and it blew my circuit breaker. I tried starting my circuit breaker but it kept flipping off....
Usually related to the in-tank check valve. Follow the discharge hose from the pump to the tank. At the tank the hose attaches to a brass valve (or metal valve). This brass fitting is the check valve. It's purpose is to hold air in the tank and not allow the air to load the compressor when motor is trying to start. Easy to test. Use another compressor to pump air into your tank thru the quick disconnect or remove the safety valve and install hose there. Pump in about 75 psi and looks for leaks with soapy water. Remove air inlet hose from check valve and check for air leaks. If leaking, replace with generic valve available at www.grainger.com or order from sears parts. If no leaks then suspect unloader is not working at the pressure switch. If both the unloader and check valve is ok then test capacitor for reading within 95% of rated valve. Good holidays
Dec 14, 2010 | Craftsman Air Tools & Compressors
Manual for craftsman 3hp 20gal air compressor
http://www.searspartsdirect.com/partsdirect/index.action
Click that link and enter your model number. Once you do that there will be an orange button to the right of the screen that will say "View Manuals". There you will be able to download your manual and print it off.
Nov 21, 2010 | Craftsman Garden
I have a Sears 33gal vertical compressor. About 8 years old. I keep tripping circuit breakers whenever the compressor is activated and starts to pump. Please advise
either the motor is bad or the pressure relief valve is inoperative forcing the compressor motor to try to start with pressure already in the pump
Oct 15, 2010 | Craftsman Air Tools & Compressors
Craftsman 30 gal compresser trips circuit breaker
That number does not come up on Sears parts direct, how ever a start capacitor you can have tested at any motor repair shop and likely get one to replace it from them as well,,,and can almost guarantee it will be cheaper than from sears anyway.
Feb 25, 2010 | Craftsman Air Tools & Compressors
I have a 919.167780 2 Stage Twin V Portable
two different problems here! first when it trips the breaker and you try to reset the breaker and not turn off the compressor on its pressure switch it does not unload the air off the head of the pump when you try to start it again,,, ( when it shuts off normally you hear the air drain near the switch,, this unloads the pump to restart)
The most likely reason it is tripping the breaker is that the second stage (smaller cylinder) is not doing the work it needs to do and the first stage (bigger cylinder) is pumping more now!,,,, higher pressure on this side makes the motor work harder.
I would advise rebuilding both sides to get the pump back up to correct running levels it had new.
I have a craftsman 20gal. 1.5 horsepower compressor. I turn it on and it runs forever and there is no pressure in the tank. what sould to First.
The first step is an inspection. If it develops no pressure at all in the tank you probably have a mechanical failure of the pump. But before tearing into that, listen as the unit runs, does it sound different from usual? Any hissing of escaping air? Check the intake air filter for blockage. If the unit was used for spray painting, perhaps the air is choked off by dried paint. If you have not found it at this point, it must be a problem with the pump. Any chance of warranty? (you might want to ask sears)
Jan 01, 2010 | Air Tools & Compressors
Air compressor motor will not restart
Hi, The start capacitor on the motor needs replaced. Good Luck, hope this Fixsya!
Feb 22, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
430 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Craig Butler
Craig Butler
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
