Question about Soyo 19" LCD Flat Panel Monitor
My Soyo model MT-NI-DYLM1998 19" LCD monitor won't power up. Suggestions?
2 Suggested Answers
S1LV3R
  • 22 Answers
SOURCE: My Soyo 19" TFT monitor
Thank you for answering those questions. That usually indicates it has a bad power inverter. From what i can tell, that monitor is a few years old. You can attempt to find an inverter online to replace it yourself (usually about $50 if you can find one) since its no longer covered under warranty, or put that money into getting a new monitor.
Posted on Sep 06, 2010
Testimonial: "Thank you. Now on to repair!"
This monitor gives me a complete blank white screen when plugged in even after checking with multiple computers what part would need fixing or replacing for it to function properly?
check first any broken ribbon wire going to lcd panel or broken screen display. if those are good, the cause of white screen would be bad lcd controller board.
Dec 28, 2012 | Computers & Internet
Soyo monitor MT-NI-DYLM1998 "out of range."
Your windows 7 screen resolution is set too high and your display doesn't support it. There are 3 possible solutions to this problem:
1. Press F8 during startup and choose "Enable row-resolution video"
2. Press F8 during startup and choose "Safe mode" and change screen resolution there, then reboot.
3. You can always use another display (if you have one) to set screen resolution to lower value.
Oct 15, 2012 | Soyo Computers & Internet
I have a Soyo 19" TFT LCD Monitor MT-NI-DYLM1998 when i power on the computer the monitor come on then after a very short time (less than 10 seconds) the display goes off but the power and signal are still...
medproducts, Nothing new here. Check internal "switch-mode-power-supply board" only after devoting about 1-2 hours of viewing "lcd monitor disassembly" and "lcd monitor repair" video clips at YOUTUBE!!! Then you will need to make big decision!!! Let me and all who read this know what your plan of action is.
12fixlouie
Sep 16, 2010 | Soyo 19" LCD Flat Panel Monitor
My Soyo 19" TFT monitor Model:MT-NI-DYLM1998 comes on at power up but goes black after a few seconds. But on repeating turning power off then on again, the monitor comes on and then goes black again after...
Sep 06, 2010 | Soyo DYLM24D6 LCD Monitor
SOYO 19 TFT LCD Will not come on. Says "no input signal" Re-bot does not work. Everything is plugged in.
if the monitor has more than 1 source then make sure it is in the correct one. make sure the cable is fully inserted in the monitor and Pc. try another monitor to rule out a graphics card fault on the PC
Aug 02, 2010 | Soyo MT-NI-DYLM2058 Monitor
I have a Soyo Monitor, Model MT-NI-DYLM1998. It had been working OK, but I put my computer in storage for 2 weeks and then tried to reconnect. The Soyo monitor stays blank (black) except when it is turned...
i have encountered this same issue with a monitor like yours its very common especially for lcd monitors there is a bad diode on your monitor board and you will not be able to fix this yourself you can buy another or use just a regular crt monitor or your best bet is to have it repaired im sorry and i hope this helps
Dec 19, 2009 | Soyo DYLM1998 Monitor
My TFT LCD Monitor, serial #MT-NI-DYLM2286 produces a light pink backround, but prints clear. Is there some way to return the monitor to a clear white backround?
rjmusvi, Sometimes the VGA connector at the rear of the PC needs to have it RESEATED 4-8 times to see if it returns the screen to NORMAL colors being displayed on the LCD panel!!! Do this with the POWER OFF to both PC and LCD monitor!!! Also check to see if any of the pins in the monitor to pc plug are bent or pushed down into the connector body. 12fixlouie on fixya
Dec 03, 2009 | Soyo Computers & Internet
Have a 22'' Soyo LCD MT-NI-DYLM2286 and without any warning the the disply is blank ... power light comes on solid ... but no pic???
Try another known working monitor on the computer to make sure you are getting video.
If you do get video with the known working monitor then you know the original monitor is bad.
If you don't get video with the known working monitor then you know that its a problem with the computer.
Aug 28, 2009 | Computers & Internet
Soyo monitors
your monitor doesnt have drivers for it.. and doesnt need drivers for that matter. It sounds like you dont have the right drivers installed for your graphics card. here is a link to the drivers you need.
http://www.nvidia.com/object/winxp_169.21_whql.html
hop this helps, good luck.
Jan 22, 2008 | Soyo Dymond DYLM017A 17" LCD Monitor
Soyo 19" LCD Flat Panel Monitor Logo
139 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
