Question about Intel CTL E09L 2goPC Laptop
Replacement Backlight inverter
I need a replacement Backlight inverter for my Intel 2go Pc, where can I find one?Every website I have gone to does not have the model. Can anyone suggest a good website where I can purchase the backlight inverter?
  • 71 Answers
Ebay may be a good place to look?
Posted on Dec 09, 2009
SOURCE:
The screen on the laptop has gone extrmely dim and the fn button with the brightness button will not work.
It sounds like your display backlight has gone out. This is usually because the inverter board in the display, which provides power for the lamp, has gone bad. Replacement inverters are available for most brands of laptops, and they aren't hard to change. Search for your specific brand and model and "replacement inverter" and you should find several sources for the part, and sites with details of how to change it.
Jul 17, 2011 | Acer Computers & Internet
Hp g5000 sreen does not light up as usal, i can see a the start up when i shine a torch at the sreen, what do i need to do to get working.
An LCD screen cannot produce enough light by itself. It needs an additional source of light.
A Backlight is used as the additional light source.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to the Fluorescent lighting used in homes and businesses, but on a MUCH smaller scale.
The LCD screen is a composite of layers, surrounded by a thin metal frame that resembles a picture frame.
To one side of the LCD screen layers, and under the frame is usually where the Backlight is mounted.
[Note* Two Backlights are used in some models]
Replacing a Backlight is more labor intensive than replacing an Inverter.
Due to this, and the cost, the LCD screen itself is replaced as a unit most of the time, when it comes to Backlight replacement.
Example of a replacement LCD screen for the HP G5000 series of Notebook PC's,
https://www.screentekinc.com/HP_G5000_Series--15.4-inch--1280x800-wxga-laptop-lcd-screen.shtml
[Note* Stating HP G5000 is just stating the model series. When buying replacement parts the EXACT Model Number should be used. This information is located on the bottom of the laptop, in a white Service Tag.
When replacing an LCD screen, the model number of the replacement LCD screen should be matched to the existing LCD screen's Model Number.
Inverters and LCD screens are matched together. Make sure you get the correct part]
An Inverter is used to provide power from the laptop to the LCD screen, and to the Backlight.
Note* 90 Percent of the time the problem is a bad Inverter.
Example of an Inverter for an HP G5000 series notebook PC,
http://www.zlectronic.com/product/INVERTER-FOR-HP-DAC-07B035-DAC-09B017-DV5000-G5000.html
The LCD screen, Top Cover, Display Bezel, Inverter, Backlight, and various screws, make up the Display Assembly.
The Display Bezel made of plastic surrounding the LCD screen, and in front of the LCD screen is removable.
Behind it is easy access to the Inverter.
The Inverter is approximately 4 inches long, and the width of a No.1 pencil.
Usually located at the bottom of the LCD screen, and right behind the Bezel.
This article shows replacing an Inverter and LCD screen on a Compaq Presario v2000 series Notebook PC,
http://www.insidemylaptop.com/replace-lcd-screen-inverter-compaq-presario-v2000-laptop/
This pictorial guide is not for the HP G5000 series Notebook PC, but the models are very similar when it comes to Inverter replacement.
The above link is to show you what is involved.
Please post questions in a Comment.
Regards,
joecoolvette
Apr 03, 2011 | Computers & Internet
No picture
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board will get ur picture back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter baklight board for the replacement.It a long board in shape.
Mar 18, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
Video comes on but I lose the picture in 3-5 minutes, screen goes blank.
U still have sound,when screen go black?Than ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board,will get ur picture back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.
Mar 17, 2010 | Vizio L37 Television
I have sound but no picture.
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board will get ur picture back.It a long board in shape.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.
Mar 17, 2010 | Sansui HDLCD3210 32 in. LCD TV
Picture goes black, have sound, red light comes on at the on button, 60'' phillips tv
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board,will get ur picture back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.It a long board in shape.
Mar 16, 2010 | Televison & Video
I can not see my desktop its too dim
The backlight in your display has gone out. Usually this is due to a bad inverter, although sometimes the lamp itself goes bad.
Replacing the inverter is fairly easy. It's a small circuit board at the bottom of the display. Remove the display bezel, unplug a couple of cables, put the replacement inverter board in and reassemble. There are several sources for inverters. eBay is a good place to start; here's a sale going on now.
Replacing the backlight itself is much more difficult (it's built into the display), and it's usually easier to replace the entire display panel. Again there are several sources with prices in the range of $110 to $150.
Hope this helps. Thanks for using Fixya!
Feb 26, 2010 | Gateway M-6750 PC Notebook
Dell inspiron 1300 back light problem
All laptops have a backlight and an inverter to power it, and the problem you have is very common. Usually replacing the inverter board in the display fixes the trouble. There are a number of vendors online offering replacement parts. Here is one that just popped up after a Google search. You can also find videos on youtube showing the procedure for opening up the display to install the new part. It's a simple process that most people can handle with a little patience and some small tools.
It's also possible the light itself has gone bad, but the inverter failure is more common. The backlight on some displays is not replaceable separately. So try the less expensive inverter replacement first.
Mar 26, 2009 | Dell Inspiron 1300 Notebook
Raymarine smart pilot st6002 backlight is too dim
Get a new backlight, inverter is probably ok.
The way to check that the inverter is ok:
disconnect the backlight and if you hear a high pitched noise, the inverter is still good.
replacement backlight is available from a company called Being Seen Technologies.
there website is www.beingseen.com
Mar 12, 2009 | Raymarine Smartpilot Autopilot St6002 S1g...
Picture gone from TV Model LE46M51B
I suspect that your backlight has gone out. If you shine a light on the screen can you see remnants of the picture that should be displaying? If so, it's definitely the backlight, and most likely the power inverter for the backlight. You can probably find a replacement inverter, but you may need a repair manual to install it. I'd recommend checking the warranty status first and sending it in for repair if you can.
Feb 17, 2008 | Televison & Video
Intel CTL E09L 2goPC Laptop Logo
53 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Joe Negus
Joe Negus
Thomas F. Schneider
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
