Question about Samsung LN-S4692D 46 in. LCD HDTV
I have a 50" DLP Samsung that keeps turning off by itself
I have a 50" Samsung DLP and it keeps turns off by itself and needs to be turn back on for few minutes before it stops. Can you help?
  • 10,865 Answers
There can be several causes for this, few of which you can do anything about. However, a few things to try:
1) Replace the batteries on your remote control.
2) Try resetting the logic functions on your tv by unplugging it for a minute, then plugging it back in.
3) Try covering up the infra-red receptor on the front of your TV to see if you're getting unwanted signals from the receptor. taping a piece of foil over that area is perfect. If it doesn't stop after doing these two things you'll probably need to take it to a shop.
4) If this does stop it, then look for unexpected signal sources. Have you added a remote control extender? Added a new device to your audio-video system? Changed to a new remote?
I hope this helps. Joe
Posted on Mar 31, 2010
Samsung HL-S5086W 50-Inch DLP HDTV keeps turning off for no reason
After turning off do the LEDs on the front panel blink on and off?
If so, you may have an issue with the lamp. Probably needs replaced or repaired.
Dec 26, 2011 | Samsung HL-S5086W 50" HDTV
I have a Samsung 50" HDTV DLP TV that I purchased 10/12/2008. I turned the set on the other day and it would come on generate a normal picture then power itself off. I unplugged the set for a few hours...
Lamp could still be going out they only last for 5,000 hrs some 8,000 playing hours.
Check the Lamp Fan if it stops running when Lamp turns on set will turn OFF.
But if you have never replaced Lamp Problem will be the Lamp Mats Has them for $99.00
1-800-628-1118
Oct 23, 2010 | Samsung SP50L3HX 50" DLP TV
SAMSUNG DLP SLIM 50" AFTER I TURN IT OFF IT WONT TURN BACK ON TILL 30 TO 50 MINS LATER THE THREE LIGHTS IN THE FRONT BLINK. iT ACTS LIKE ITS GONA TURN ON BUT IT DOESNT IT JUST MAKES THE NOISE AND FLASHING...
Chris,
I had the same problem. I bought my tv at Best Buy and my warranty included a new bulb for the lamp. They only last about 2 yrs or so depending on how much you watch the tv. You can also buy replacement bulbs online that don't cost too much. BUT, you will need to replace every couple of years. The things you listed are exactly what happens when the bulb goes out. Hope this helps!
Sep 14, 2010 | Samsung 50" Slim-Depth DLP HDTV
We have a Samsung DLP 69'' TV and as above, it keeps shutting off. We just replaced the lamp, which did not fix the problem. It will go on for a minute or two, then the TV shuts off and all three lights...
Previous answers are wrong unfortunately. And I'm sorry you've spent the kind of money you have to fix it. Its actually a very basic, tiny, annoying cause. So much so you'll be quite angry when you hear it: When you open the lamp door on the back of the TV, youll see a small toggle type switch that gets pushed in when the door gets re-installed and allows the TV to turn on. This is to make the power shut off in case someone tries to access the lamp with the set on. If memory serves, the toggle on my 50" samsung was blue I think. You can use duct tape or something but I actually used a very small zip tie to hold the toggle in place for a neater, less ghetto-fabulous fix. NEVER had it shut off by itself since.
Jun 20, 2009 | Samsung DLP HL-P5663W 56" TV
My Samsung 50" DLP HDTV keeps humming when the DLP lamp comes on.
Hi, you have one of two problems, either the color wheel is going or one of the cooling fans are going, the color wheels are a very common problem in samsung dlp`s, sorry I can`t nail it to a specific part but I`d bet it`s the color wheel as they are notorious for failing in samsungs, video-tek
Mar 17, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Turn tv on and then it will turn itself of can immedately turn back on it is a 50 inch SamSung one year old can any one help with this problem
do a voltage check the transformer & the bridge rectifier and the whole off the power supply use a meter ther may be power starvation
Mar 11, 2009 | Samsung HL-S5087W DLP TV
Samsung dlp HL56A65 turns off and on by itself
It looks power board problem.
You need to get service from Samsung.
Mar 04, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung LN-S4692D 46 in. LCD HDTV Logo
128 people viewed this question
Jerry Greenberg
Jerry Greenberg
