Question about Epson Stylus CX4800 All-In-One InkJet Printer
Light is out on my all in one (printer, copier,scanner
Is there a way for me to replace the light myself?
    Genius:
  • 3,587 Answers
You mean the scanning bulb? Sure, it's possible with right components and service guide. you'll need the replacement part first, which you can get online, with a google search
Posted on Feb 16, 2008
What is scanner error 2 on hp laserjet 3055
Flatbed scanner is bad replace whole top half p/n q6502-60116 approx. $150 - $200
Jan 12, 2015 | HP LaserJet 3055 All-In-One Printer
Scanner error 2
Try the below one by one till the problem is resolved:
1. Clean all the mirrors of the scanner with isopropyl alcohol and lint free fabric.
2. Flat Flexible Cable from logic PCB to scanner is damaged, trim the edges by about one mm at both ends and re-try.
3. If the problem persists replace the FFC cable ( (20 pin 1mm pitch 585 mm long).
4. If problem still persists the scanner will need replacement.
The printer is writting error scanner 5
Most likely the "scanner/copier" assembly has to be replaced. Call a tech. If the printer is still on warranty call HP.
Nov 30, 2011 | HP Laserjet M2727nf Multifunction Printer
Epson SX515W black ink jet blocked. Anyway to clear it myself?
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, thenprint head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jul 20, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I am getting an error E7. I have poweroff/on still have problem.
NOT really, unless you know how to re-wrap the scanner cables, or replace the motor. Barring any physical obstruction in the scanner path that is about the only 2 solutions.
Apr 02, 2009 | Office Equipment & Supplies
Epson Stylus CX5400 Scanner
If the lamp is not working their are two main possibilities. The first is that the lamp has failed and needs to be replaced. Buying a replacement MAY be dearer than buying a new machine - you will have to price the parts locally.
The second option is that the controller board for the scanner has gone. Again this could be an expensive part, but contact a local repair center or parts supplier to price the bits.
If you are successfull in getting the parts (you may buy a faulty machine off ebay with good scanner and bad printer to strip parts from) then this service manual will help you get to the parts you need:
http://www.tradebit.com/filedetail.php/814420-Documents-eBooks-Technical
Jul 26, 2008 | Epson Stylus CX5400 All-In-One InkJet...
R40 Scanner Failure
Hello I have a little problem my printer print well for scanning it is not tell me what I have to do and the copy too doesn't work properly.
thank you for your help. May God bless you in everything that you udertake in life. keep on
Apr 16, 2008 | HP OfficeJet r40 InkJet Printer
Toshiba printer e-studio 150
There is a small clear plastic circle under where the paper comes out, it has two positions, lock and unlock, sometimes when people grab the copies they bump it to lock, use a flash light and make sure its unlocked, you can also just remove it, it was there for shipping. L-codes = scanner lock problems, real cold conditions can cause the scanner greases to not allow the scanner to move fast enough, put the copier somewhere warm. Good Luck!!!
Jan 22, 2008 | Kyocera RI-3530 Black and White Copier
Scanner needs camera device fixed -
Are you using this as stand alone or through the computer? Whichever try the other way - If standalone try it through the computer. If in the computer try stand alone. If in the computer re install software. If all the variations do not cure it then its good bye to that one and onto the next - there is nothing that will fix.
May 13, 2007 | HP PSC 1510 All-In-One InkJet Printer
Epson Stylus CX4800 All-In-One InkJet Printer Logo
56 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
