Question about Porter Cable Portable Generator BSV750
I can not find the positive and negative terminals/leads on my porter cable 7500 watt BSV750-W generator. I need to flash it as it has sat in storage for two years.
    Champion:
  • 225 Answers
I beleive that this unit is a generator only,to flash it go to the armature and flash it there.
Posted on Feb 09, 2010
SOURCE:
Will not start
That is either valve timing or a failed ignition stator. The stator will send the fire signal to the spark plug at the wrong time and hence the backfire.
Dec 06, 2011 | Porter Cable BSV750W 7500 Watt Electric...
Throttle on generator question
The idle control switch allows the generator to go into idle when there is no demand form the appliances connected. This saves gas and increases the life of the generator. Damage can occur for some appliances like a refrigerator/freezer because the voltage and frequency are not prepared for the load resulting in a low voltage bad startup that will damage the appliance. Suggest that you leave the idle control switch off while any motor/electronic devices are connected.
The throttle control is likely a choke function for starting. These generators are designed for only one running speed to produce the necessary 60 cycles per second and voltage.
The following link is to a Canadian web site that later in the detail report describes the concern of idle control. In addition it provides good insight to the operation and use of portable generators
Hope this helps?
Understanding Portable Generators
The user manual see pages:
http://www.mikestools.com/download/Porter-Cable-Manuals/Porter-Cable-CTE300.pdf
May 06, 2017 | Porter Cable Portable Generator BSV750
I need reset switch i started unit under load blew breakers
We really need a complete model number to get to an IPL that has your parts. This generator has 4 variations Type 0, 1, 2, & 3.
(Type 1 link below)
http://www.ereplacementparts.com/porter-cable-bsv750w-type-gas-powered-generator-parts-c-129_1825_2153.html
Parts manual pdf: (Detail A)
http://www.ereplacementparts.com/images/Porter_Cable/BSV750-W_TYPE_1.pdf
Breakers are item 206:
206 Z-GS-0026 BREAKER CIRCUIT 125/ 1
206 Z-GS-0681 BREAKER CIRCUIT 125/ 1
206 Z-D21508 BREAKER CIRCUIT125/2 1
Thanks for choosing FixYa,
Kelly
Sep 12, 2011 | Porter Cable Portable Generator BSV750
Where can I get parts for a GG 5500 series gas generator? Thanks Van Holton
here is the url for the parts site that porter-cable uses for consumer parts ordering
http://servicenet.deltaportercable.com/
Aug 08, 2011 | Porter Cable Portable Generator BSV750
Do you know which is the positive and negative prong on a 19.2 porter cable drill battery
Get a volt meter and make sure red is on v/ohm and black cable plugged into common or ground. measure the battery. if the meter is reading a negative reading then polarity is backwards. look for a positive value of 19v +/- a volt. red will be positive. if there is 3 leads I would think the temp lead would measure different. Usually common would be the negative side.
Jun 17, 2010 | Porter Cable 19.2V Drill/Driver
I am trying to connect battery terminals to my EQT generator.
Connect the black lead (negative) to the frame of the generator.
Connect the red lead (positive) to the big post on the starter solenoid. There are 2 big post terminals on the solenoid. Connect the battery positive lead to the one that DOES NOT go to the starter motor.
Dec 26, 2009 | Honda Mmd 5000 Watt Electric Start...
I have a Porter Cable BSV750 generator with no electrical output. How do I test the capacitor?
You need an multi meter, on the ohms scale. Short the two prongs on the cap out, removing any voltage on it. Put your meter to a mid range ohms scale. Touch the leads to the prongs on cap and watch your meter. It should start climbing in value and then go to 'OL' if it's digital. If it's an analog meter(with a needle) it will go all the way over to 'infinite. This means it's good.
If it's bad, it will just read 'OL' or go right to 'zero' meaning it's either shorted or open.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 23, 2009 | Porter Cable Portable Generator BSV750
Porter Cable Portable Generator BSV750 Logo
177 people viewed this question
Top Porter Cable Welding Tools Experts
Marvin
Marvin
Bill Boyd
Are you a Porter Cable Welding Tool Expert? Answer questions, earn points and help others
