Question about Boating
How much gear oil in a 1985 2 hp suzuki outboard motor? I'm only able to get a few tablespoons in.It seems like not much.
  • 677 Answers
The bottle that the g/box oil comes in should hve a tapered nozzle.You fill the g/box through the bottom drain hole untill it overflows out the top hole.With both screw plugs removed,squeeze the oil into the lower hole untill it flows out the top hole then reinsert the lower plug first.They dont take a lot of oil but this removes all the air bubbles in the g/box.Hope this helps
Posted on Dec 12, 2009
Suzuki turns over wont start 115 dt out board2 stroke
When did it last start and run well? Check for fouled spark plug. Ensure that ALL electrical contacts are CLEAN and TIGHT. Check fuel/oil mix for proper proportion and freshness.
Aug 28, 2017 | Clymer Suzuki 2-225 HP Outboards Includes...
1993 Suzuki 4hp 100.1 how much oil per gallon
the manual shows for a 100 :1 mix the ratio is 4 ounces of oil to 3 gallons of fuel
there are two engines and one is 50: 1 ratio so that would be 8 ounces of oil to 3 gallons of fuel
there is a pdf version workshop manual at www.motoren.ath.cx and it gives the ratios for all of the 4hp suzuki outboards and the oil to use
Oct 01, 2016 | Clymer Suzuki 2-225 HP Outboards Includes...
Where are the serial numbers located on a 1985 Suzuki 115 hp outboard motor??? have looked everywhere
The serial numbers are on the transom bracket where your engine bolts to the back of your boat !
If no numbers then remove the gearbox and take the impellor and its housing to a dealer and they should be able to match them !
Feb 23, 2015 | Suzuki Boating
My outboard motor will not move up. How can I fix this?.
No it wont overheat !!! Change the solinoides over on the trimand see if you can raise engine and now not lower ! if yes then replace solinoide !
Jun 15, 2014 | Clymer Suzuki 2-225 HP Outboards Includes...
1985 suzuki dt60 diagram
did you remove the pin below the carbs for the gear rod ?
Jun 02, 2014 | Light Outboard Motor Boat Bass Fishing...
I have a 1985 Evinrude 60hp outboard that i removed the oil injector so as i could run on mixed fuel. At high speeds it is bogging out and seems to be missing badly. Could this be the wrong fuel/oil mix,...
The correct mixture is 50:1, or 1 pint per 6 gallon tank. Use quality brand-name outboard TCW-II or better oil(Bombardier or Mercury eg.) to eliminate the oil as a problem.
Check your plugs for fouling. If using perma-gap / surface-gap type plugs, switch to the L77JC4 type, especially for long idling or slow speed operation. For extended high speed operation, the surface gap plugs are recommended.
Jul 12, 2011 | Clymer EvinrudeJohnson Outboard Shop...
Suzuki outboard motor 65 hp --oil sensor keeps
assuming you are not out of oil in your oil reservoir you probably have a bad sending unit in the reservoir. never bypass it or eliminate it as you could permanently damage your motor or ruin it if you ran it out of oil.
Jun 19, 2010 | Boating
No tell tale.
water pump-
crack in the housing from sitting over the winter with water in it
Apr 14, 2010 | 2006 Mercury Mariner
Need a few tricks to unlocking a motor
get marvins magic mystery oil pull the plugs out and put 3-5 tablespoons in each cylinder let it sit overnight, and turn the engine over by hand with a wrench
Jun 24, 2009 | 1994 Suzuki Sidekick
Boating Logo
241 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
