Question about Kenwood Audio Players & Recorders
Lost the lcd display on my kt2020L tuner? it was working,but now i cant get anything on the display,any ideas?.pete
Want to use samsung 2233SW LCD monitor as TV
Yes you can, if you has PC desktop, plug your lcd to it. change LCD resolution from your PC.
-- Right Click on desktop
-- Click properties >> click settings tab
-- You will see Screen Resolution, change to the lowest (800x600)
-- Nnplug VGA cable from PC
-- Now plug the cable tou your TV Tuner.
Feb 08, 2010 | Samsung SyncMaster 2233SW Monitor
I am trying to hook up a digital labs, 19'' lcd tv/dvd combo and when i do the initial channel scan it doesnt pick up anything from the satelite at all, i have hooked them toghther anyway i can think of...
Most HDTVs have ATSC, QAM and NTSC (analog) tuners. It sounds like yours does not have an NTSC (analog) tuner. QAM tuners only pick up digital cable channels. You may need to switch to your cable company's digital service if your not already on it. Call your cable company for further info
Dec 26, 2009 | Televison & Video
Cant get anything on my tuner
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock and to set the device region free procedure of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
Jul 10, 2017 | X2Gen MV37R 37 in. LCD TV
Tv tuner card is not supporting with lcd monior
I think that would be the other way around. You need to replace it with a card that supports LCD monitor.
May 03, 2017 | Acer AL1916W 19" LCD Monitor
Tv tuner card is not supporting with lcd monitor
The intex it 3488 tv tuner has known compatibility problems with this particular Acer monitor: see here.
If the tuner card is new see if you can get a refund, by claiming it as faulty, after all this is a factory fault.
Sep 08, 2008 | Acer AL1916W 19" LCD Monitor
LCD Screen Blank
hi, this usually happens with the ribon cable which is giving power and signal to LCD is becoming loose or damaged due to folding..since the LCD wiring replacemet is a skill needed task i recommend you to give it to the nearest service centre so that your cam will be ready for future shots all the best my friend sreejith
Jun 26, 2007 | JVC GR-DVL9000 DV Digital Camcorder
Lost audio & video
You say that you lost audio and video but the screen is blue. That indicates that the majority of the circuits are working OK. To display anything on the screen the high voltage and drive circuits would be working ok. Try an input other than cable (the tuner input) and see what happens. If your unit works through those inputs then you have a bad tuner or matrix IC. If that doesn't give you any results then you probably have a microprocessor issue. The bad news is that Apex does not support their equipment so if the problem is not simple it will probably not be reparable. Good luck.
Jun 13, 2006 | Apex Digital AT2008S 20" TV
55 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
