Question about GE WBSE3120B Top Load Washer
Water leaks from bottom of machine when even when letting soak with lid raised, as well as when washing. Is this a hose (I can't see any cracks or holes),or is it the water pump, or something else?
Pump blew the side out in the front righthand corner probly from coins. take off two hoses and wire and get some good epoxy.
Posted on Dec 09, 2009
How do I get my washer to just soak the clothes without draining?
The washing machine cannot operate at all with the lid up, unless the lid switch is stuck in the closed/on position. Draining water out when it should not is controlled by the circuit board of electronic components. Thus it is defective too.
Nov 22, 2015 | Washing Machines
While using washing machine water leaks out
sounds like the lower pipe or pump pipe is leaking or come away. you need to pull the washer out and place it on its side (left as you look at front) and check the pipes on the bottom, they have pincer clamps on the pipes, if the pipes are cracked or damaged replace them but usually its just they have come loose from drum movement. and just need fitting back on. also the drain pipe needs to be at least 3 inches from the top level with the water in pipes height of the washer so the water does not just come out.
Jan 13, 2018 | Washing Machines
I have a WD1457RD LG front loader and i am trying to clear an AE code.
It indicates a leak has activated the flood protection device in the base. Lean the machine forward (or backward) & see if water runs out of the base. If it does you may be able to restart...but the source of the leak will need to be identified & fixed. I think it would be wise to remove the lid & check if the inlet valve has popped first.
Nov 02, 2012 | Washing Machines
Leaking water from bottom draw
To put machine into test mode: Press and hold keylock, then press and hold start button. Hold both in until machine beeps (if you have display, it will show all symbols). Press power button- display should now show HO. Press start button until LD shows in display- this tests lid motors. Activate lid motors by pressing keylock button- if you open drawer about 3 inches, you should see lid come down. Pressing keylock again will raise lid. Raise and lower lid several times by pressing keylock button to ensure lid is working properly- if not, lid motors need replacing. Good luck!!
Mar 18, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
MILDEW SMELL COMES FROM WASHER
. Set the washing machine on the highest water level, temperature on hot and the wash cycle to normal.
2. Fill a gallon jug with hot tap water. Once the cycle begins, let it run for a minute or two, then stop the cycle, open the lid and slowly add the gallon of hot tap water. Don't overfill — you just want to raise the water level so that it is able to reach and clean the inside top rim.
3. Add 2 to 4 cups of household chlorine bleach and restart the cycle. In a couple of minutes, stop it again and just let it sit for at least 30 minutes. Afterward, let the cycle finish, and open the lid to air out the inside.
Jul 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The washer fills with water but will not complete the cycle. Since it started this, it did finish 2 or 3 loads sporatically, but doesn't seem that it will even do that now.
We had the same problem. Luckily, we bought a 3 yr extended warranty. The appliance tech came in, pulled out a screw driver and tightened the lid. He said the left side frequently comes loose and that is where the sensor is that tells the machine the lid is closed. Tighten up the lid and see if that solves it. This washing machine BLOWS. We have had the warranty people out 4 times since we bought it. It's only two years old. First there was no hot water, the tech opened the machine and the connecter to tell the machine to use hot water was never connected at the factory. Water leaking from the bottom, don't remember what that was. Oil leaking from the bottom, replaced trnsmission seal. Fills with water and stops, loose lid. What a lemon.
Mar 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore washer machine cylce stopped in mid cycle
If your washer doesn't seem to work at all, check these:
  • No power
  • Lid switch
No power
Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch
If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
 check these, if still the problem persists then let me know for further help.
Mar 22, 2009 | Kenmore HE2 Plus Front Load Washer
I have a problem with my washing machine..
Basic Washer Problems
No fill:
Bad water valve
kinked hoses
unpaid water bill faulty electronics. Overfill:
trash in water level switch tube
bad water valve
bad water level switch faulty electronics. Washes but don't spin:
bad lid switch
bad drive coupling or belt
bad motor faulty electronics Spins pumps but don't wash:
bad timer
bad motor
bad luck faulty electronics. Leaks:
bad hoses
bad pump
bad tub gasket faulty electronics. Fills washes but never advances:
bad lid switch
locked up pump
bad motor
bad timer faulty electronics. Goes through complete cycle but clothes soaking wet:
bad belt
bad pump
bad thrust bearing faulty electronics*. *electronics in appliances ****. My opinion.
Dec 28, 2008 | Washing Machines
GE Top load washer.
Hello rschneeweis
Welcome,
Sounds like a seal or drain hose is leaking or the clamp on a hose has vibrated loose.
Water leaking out the bottom of the machine when washing machine begins agitation cycle. If the machine is turned off the water stops leaking even with the tub full of water.
Let me know if you found it and how you do.
Huuum
Please remember to leave a rating
Oct 04, 2008 | GE WBSR3140D Top Load Washer
The washing machine filled with water, put the soap in and then some towels, after I closed the lid and the machine stopped working.
sounds like lid switch went ..try raising lid and listening for click when closed ..even if it does click could still be switch there is a small fuse and contacts inside switch 3 screws along top of console to be removed and console will lean forward to allow access to switch
Sep 07, 2008 | Maytag Washing Machines
GE WBSE3120B Top Load Washer Logo
89 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
